1300 connectés
  HiFi & Home Cinema
  Denon AVR-1905
Denon AVR-1905
n°703087
Nobun@ga
Posté le 07-09-2004 à 11:54:04  profilanswer
http://www.denon.fr/images/menu/denon.jpg
http://multimedia.fnac.com/multimedia/images_produits/zoom/9/9/9/4560119533999.jpg
7.1 Dolby Digital Surround EX, Dolby Pro Logic IIx & DTS ES Discrete 6.1 A/V Receiver • Dolby Digital Surround EX, Pro Logic IIx decoding with Cinema,Music and Game Modes • dts ES Discrete 6.1 and Matrix 6.1 decoding • dts Neo:6 Stereo to Surround decoding • dts ES 96/24 5.1 decoding for DVD Video • Analog Devices HammerHead SHARC 32 bit floating point DSP processor • 7 Channels equal power amplifier section • 80 watts per channel (8 ohms, 20 Hz-20 kHz, <.05%THD) • 110 watts per channel (6 ohms, 1 kHz, <.7%THD) • Analog Devices, 24 bit, 192 kHz high resolution DACs on all eight channels • True 24 bit, 96 kHz Digital Interface Receiver • 24 bit, 96 kHz A/D conversion on all Stereo analog inputs (Not EXT. Inputs) • Adjustable High and Low Pass Crossover (40/60/80/100/120/150/200/250Hz) • 3 Assignable Component Video inputs (100MHz Bandwidth), with On-Screen Display • Video Conversion of Composite to S-Video and/or to Component, with on-screen display • 4 sets composite and 3 "S" video inputs • 5.1 external wide bandwidth (100 kHz) inputs for multi-channel formats, such as DVD-Audio and Super Audio CD • 5/6/7 Channel Stereo • Digitally regulated volume control with .5dB increment adjustments and step range of -80 to +15 • Personal Memory Plus • 4 assignable digital inputs (3 Optical, 1 Coaxial) • 1 Optical digital output • 8 analog inputs including built-in AM/FM tuner • True 2 Source, 2 Zone functionality with Discrete Power, Source Select and Volume control for each zone • (1)Multi-Zone stereo fixed pre-amp level audio output • Power Amplifier Assign function, lets you assign 2 of the 7 amp channels to drive Zone 2 speakers directly • 7.1 Preamp outputs • Direct Access Tuner presets by remote • Glo-Key pre-programmed remote control • Remote I/O ports • Dimensions: 17.1"w x 6.7"h x 16.4"d • SRP $499
Sur le site de la fnac on peut le voir et il y a écrit Nouveauté à venir, indisponible à ce jour.
Est-ce que quelqu'un sait quand est-ce qu'il sort? (pour info le 1705 est déja sorti)
Vendu au prix de 490,00 € je voulai savoir ce que vous en penssez? (pour l'instant j'ai le DENON AVR-1602)
http://www.usa.denon.com/catalog/p [...] 20Back.jpg
http://www.usa.denon.com/catalog/pdfs/AVR1705.pdf
n°705480
Nobun@ga
Posté le 11-09-2004 à 01:56:50  profilanswer
Ouah...!
Merci, y a personne qui s'intéresse.......... :pfff:
Trés ouvert ce forum ! :bounce:
n°705487
elbarto
Posté le 11-09-2004 à 07:36:46  profilanswer
tu as posé la question au vendeur de la Fnac ?
il devrait pouvoir te renseigner
sinon moi j'en pense rien de spécial, j'ai completement abandonné le créneau de la chaine HI-FI à élements séparés
tout se passe maintenant avec mon PC pour tout ce qui est multimédia ( TV, DVD, musique ), ça marche très bien, grande souplesse et confort, son 5.1
c'est pas la même qualité mais j'apprécie les avantages d'un tel système
Message édité par elbarto le 11-09-2004 à 07:43:03
n°705510
galactor
Posté le 11-09-2004 à 10:20:00  profilanswer
Nobun@ga a écrit :
Ouah...!
:lol:  tu as vu l'heure de ton post aussi ??? :sleep:   :sleep:   :sleep:
Tu peux siffler..., C'est énorme !
n°706031
Nobun@ga
Posté le 11-09-2004 à 23:32:28  profilanswer
Ca fait quoi l'heure? J'ai écrit le 2ème message 4 jours aprés le 1er, donc on aurait pu me répondre la journée, mais c'est pas grave... :pt1cable:
Sinon pour répondre à Elbarto je n'ai pas demandé à un vendeur de la fnac mais je pense qu'il devrait trés bientot arrivé puisque avant sur le site de denon en francais, il ne montré pas cette amplis alors que maintenant il le montre depuis hier.
Moi aussi j'utilise mon PC mais je n'ai pas mis d'ensseinte dessu mais j'ai branché avec le cable coaxial mon pc à mon amplis avec donc 5 ensseintes et un caisson de bass, l'ampli reconnai réelement le DTS et le DD
Pour les jeux, musique et divers... c'est un régale! :bounce:
Si quelqu'un veut me dire ce qu'il en pense je suis à l'écoute, ou si quelqu'un à vu un test FR ou étranger, c'est bon à savoir. :D
n°707651
xomoh
Posté le 15-09-2004 à 13:08:09  profilanswer
[:abnocte invictus] il a l'air sympa sur le papier...
il remplace pas le 1604 mais plutot le 1804 non?
Normalement le 1804 etait un très bon ampli dans sa gamme de prix donc le 1904 doit etre excellent... (quoi je reve)
n°709044
Nobun@ga
Posté le 17-09-2004 à 16:48:53  profilanswer
Il remplace le 1804 :sol:
Justement j'étais intéréssé pour le 1804 mais comme j'ai vu que les nouveaux modèle allé sortir, donc.... :pt1cable:
pour info ce n'est pas le 1904 mais 1905 :non: (les nouveau modèles donc)
Et aussi c'est le 1705 qui remplace le 1604. :jap:
Merci pour les commentaires, et on continu...
n°729532
aurelien20​23
Posté le 25-10-2004 à 11:41:12  profilanswer
est ce que quelqu'un a des news depuis ce temps qd meme...
j'ai trouvé un test.. mais en allemand... dcj'ai rien compris... j'ai vu qu'ils lui mettait 6 étoiles presque partout... mais à part ça... :??:
n°731941
Nobun@ga
Posté le 29-10-2004 à 19:35:46  profilanswer
6 étoiles sur combien?
n°733513
jcc34
Posté le 02-11-2004 à 16:15:42  profilanswer
je viens d'acheter le DENON 1705 chez DARTY pour 399 euros.
n°736630
Nobun@ga
Posté le 07-11-2004 à 20:29:49  profilanswer
Et dit nous tes impression sur la nouvelle game des DENON, c'est ton 1er DEONON?
n°737184
Patouf
Posté le 08-11-2004 à 20:14:52  profilanswer
J'ai fait l'aquisition d'un ampli Denon AVR-1905 d'une paire d'enceinte Eltax Millénium 200 et d'une paire d'enceinte Eltax Monitor III
N'y a t'il pas de risque à utiliser les 2 voies A et B en même temps (4 enceintes avant)sachant que ces enceintes indiquent une impédance de 4~8 ohms ?
L'ampli indique pour les voies A + B : 12~16 ohms. (c ça qui m'inquiète).
Sinon pour la qualité de restitution j'en suis assez content pour l'instant. Les Millénium 200 descendent assez bien dans les basses et les monitors III aussi.J'ai écouté le master Série de Renault (le début de "Laisse béton" )et les basses rendent bien. J'ai écouté aussi le début du Poème symphonique de Richard Strauss "Sehr Breit" musique de 2001 l'Odyssée de l'espace)où il y a des basses profondes au début.Ce qui manque c un meilleur rendement si l'on veut écouté très fort ou alors un ampli de plus de 100 Watts je pense.essai réalisé à -2 dB (volume) : j'ai pas est plus fort.
Le rendement de 88dB pour les millénium 200 et de 89 dB pour les monitors III peut paraître un peu juste mais j'aime bien la qualité d'écoute.Je pense,avec mes modestes connaissances, que prendre des enceintes avec un rendement sup à 91 dB serait mieux (Attention installation provisoire dans une chambre de 30 m² avec pas mal de meubles et moquette au sol + clic clac) .
Mais bon pour l'instant j'en suis très satisfait surtout des Monitor III. indications : les pointes des monitors III se dévissent à la moitié.
Voilà, j'attends vos réponses.
bonsoir !
Patouf Posté le 07-11-2004 à 22:11:27                 précision : L'ampli Denon restitue très bien toutes les subtilitées de la musique et les détails c dingue ! dans les chansons de Renault on entends même le gars pianoter sur son accordéon !
n°739076
elbarto
Posté le 12-11-2004 à 02:58:22  profilanswer
C'est Renaud avec un d, pas confondre avec la voiture :D
n°739289
Patouf
Posté le 12-11-2004 à 16:50:09  profilanswer
LOL oui j'ai pas fait gaffe !
n°757660
Nobun@ga
Posté le 13-12-2004 à 23:01:19  profilanswer
Je l'ai acheté, de la bombe :pt1cable:
n°758688
seb2001
Posté le 15-12-2004 à 15:59:10  profilanswer
et en comparaison avec un Harman Kardon AVR230 ? caractéristique technique et puissance ??
http://www.hifissimo.com/store/sea [...] ml&0=25916
Message édité par seb2001 le 15-12-2004 à 16:04:23
n°758724
crystalize​r
Simplement moi
Posté le 15-12-2004 à 16:36:10  profilanswer
fidele a la réputation en HC ?
n°758827
seb2001
Posté le 15-12-2004 à 19:19:20  profilanswer
qu'est ce qu'il faut comme enceintes, comme enceintes centrale, comme caisson avec ce genre d'ampli ?
Quel est l'importance d'un caisson dans une installation ?
Y'aurais pas un site qui explique tout, plutôt que de poser pleins de questions...
Message édité par seb2001 le 15-12-2004 à 19:29:01
n°767157
Nobun@ga
Posté le 28-12-2004 à 10:18:05  profilanswer
Oui fidèle à sa réputation !
Pour répondre à "seb2001", je te conseil de prendre un kit de 5 enceinte, il faut que ce soit de la même marque (pour que ce soit omogène), mais pour le caisson tu n'es pas obligé de prendre de la meme marque que les enceintes.
Le caisson de bass sert à donner + d'impact lorsqu'il y en a besoin, au moment d'explosion etc... c'est agréable aussi lorsque tu écoute de la musique avec de bonne bass.
Pour ton choix des enceintes c'est selon ton budget et selon ta pièce, à toi de voir si tu prends des satélites ou des grandes encientes (sachant que les satelites ne peuvent pas donné elles meme les bass, le caisson doit compenssé)
voila
  HiFi & Home Cinema
  Denon AVR-1905
Mini Chaine Denon 201 SA ou Teac H302?Avis TEAC H302 + enceintes Eltax Liberty 3+ ou Denon D-F101 ???
Avis ampli denon 655 + enceintesquelles enceintes pour le denon avr1804
Denon AVR 1602 vs Onkyo TXDS575Denon 1804 ou HK230?
Denon AVR 104 / Cabasse XO SystemChoix ampli Denon/Yamaha et choix enceintes
Plus de sujets relatifs à : Denon AVR-1905
