| Auteur | Sujet : [blabla@olympe] Le topic du modo, dieu de la fibre et du monde |
sligor | Reprise du message précédent : |
Publicité | Posté le 06-01-2009 à 16:46:59 ![]() ![]() |
Taiche (╯°□°)╯︵ ┻━┻ | Mots-clés : XML, diff, GUI, Windows, gratuit. Vous avez 30 secondes pour proposer un soft correct EDIT : la merde proposée en open source .Net par la MSDN n'est pas valable. Message cité 4 fois Message édité par Taiche le 06-01-2009 à 16:54:52 --------------- Everyone thinks of changing the world, but no one thinks of changing himself | It is the peculiar quality of a fool to perceive the faults of others and to forget his own | Early clumsiness is not a verdict, it’s an essential ingredient. |
schnapsmann Zaford Beeblefect |
masklinn í dag viðrar vel til loftárása |
--------------- I mean, true, a cancer will probably destroy its host organism. But what about the cells whose mutations allow them to think outside the box by throwing away the limits imposed by overbearing genetic regulations? Isn't that a good thing? |
Message cité 1 fois Message édité par Taiche le 06-01-2009 à 17:00:30 --------------- Everyone thinks of changing the world, but no one thinks of changing himself | It is the peculiar quality of a fool to perceive the faults of others and to forget his own | Early clumsiness is not a verdict, it’s an essential ingredient. |
cosmoschtroumpf dawa powered |
Message cité 2 fois Message édité par cosmoschtroumpf le 06-01-2009 à 17:00:28 --------------- Android/Manettes/Metroidvania/Zelda/Indés/Retrogaming/VDS jeux |
Lam's Profil: bas. |
Message édité par Taiche le 06-01-2009 à 17:01:24 --------------- Everyone thinks of changing the world, but no one thinks of changing himself | It is the peculiar quality of a fool to perceive the faults of others and to forget his own | Early clumsiness is not a verdict, it’s an essential ingredient. |
Publicité | Posté le 06-01-2009 à 17:01:49 ![]() ![]() |
Message cité 1 fois Message édité par Lam's le 06-01-2009 à 17:04:18 |
nraynaud lol |
--------------- trainoo.com, c'est fini |
FlorentG |
Exemple débile de fichier : * fichier 2 : Je pense pas être le premier à avoir ce type de besoin, donc je vois pas trop en quoi je demande un truc "magique qui comprenne ce que j'ai derrière la tête" Message cité 3 fois Message édité par Taiche le 06-01-2009 à 17:09:02 --------------- Everyone thinks of changing the world, but no one thinks of changing himself | It is the peculiar quality of a fool to perceive the faults of others and to forget his own | Early clumsiness is not a verdict, it’s an essential ingredient. |
Xavier_OM François Villon |
Après faut pas perdre de vue que l'ordre des balises peut avoir du sens parfois.
Message cité 1 fois Message édité par Xavier_OM le 06-01-2009 à 17:15:33 --------------- Hommes, ici n’a point de moquerie https://www.youtube.com/watch?v=5Veri-bGRAY |
ratibus |
--------------- Mon blog |
Tout ce que je peux te conseiller, c'est de resérialiser ton XML en triant les nodes comme tu veux, et differ là dessus (avec un diff textuel) en collant un tag/ligne dans la sortie. edit: ou alors <oXygen/> ou Stylus Studio ont ptet des démos gratuites, me semble que les dernières versions ont du diff XML inclus. edit2: ah tiens http://iandavis.com/blog/2002/10/morexmldifftools il y a l'air d'en avoir des gratos (mais vieux post) Message cité 1 fois Message édité par masklinn le 06-01-2009 à 17:22:30 --------------- I mean, true, a cancer will probably destroy its host organism. But what about the cells whose mutations allow them to think outside the box by throwing away the limits imposed by overbearing genetic regulations? Isn't that a good thing? |
___alt | LAAAAAAA CLUUUUSAAAAAAAAAAAAAAAZ
--------------- TRIPS RIGHT BUNCH F SHUTTLE TOM AND JERRY RIGHT YELLOW |
mareek Et de 3 \o/ |
--------------- "I wonder if the internal negative pressure in self pumping toothpaste tubes is adjusted for different market altitudes." John Carmack |
Message cité 2 fois Message édité par masklinn le 06-01-2009 à 17:55:12 --------------- I mean, true, a cancer will probably destroy its host organism. But what about the cells whose mutations allow them to think outside the box by throwing away the limits imposed by overbearing genetic regulations? Isn't that a good thing? |
gfive |
--------------- Tous les sud africains sont ségrégationistes, à part Ted. (P. Desproges) |
beel1 |
0x90 → | Y'a un moyen pour que le compilo c++ de ms ne foute pas tous ses .obj au même endroit quand les fichiers sources ont le même nom mais pas le même dossier (et donc s'écrasent) ? Message cité 3 fois Message édité par 0x90 le 06-01-2009 à 18:24:49 --------------- Me: Django Localization, Yogo Puzzle, Chrome Grapher, C++ Signals, Brainf*ck. |
BenO Profil: Chercheur | un petit coup de filemonitor pour le savoir --------------- Python Python Python |
0x90 → |
beel1 |
edit: EN FAIT TU CONNAIS PAS LES MOTS DANS LA QUESTION, TU N'ES PAS UN PROGRAMMEUR MAIS UN ESPION INFILTR2 DANS CE TOPAC§§§ TU ES UN PROGRAMMATEUR§§§ Message cité 1 fois Message édité par masklinn le 06-01-2009 à 18:41:17 --------------- I mean, true, a cancer will probably destroy its host organism. But what about the cells whose mutations allow them to think outside the box by throwing away the limits imposed by overbearing genetic regulations? Isn't that a good thing? |
nraynaud lol |
beel1 |
sligor |
Jubijub Parce que je le VD bien |
| Sujets relatifs | |
| Plus de sujets relatifs à : [blabla@olympe] Le topic du modo, dieu de la fibre et du monde |
