3943 connectés
Sujet(s) à lire :
    - Who's who@Programmation
 Page :   1  2  3  4  5  ..  14867  14868  14869  ..  27403  27404  27405  27406  27407  27408
n°1797012
skeye
Posté le 08-10-2008 à 10:56:41  profilanswer
Vos mmachines sont pas synchro par un serveur de temps?[:pingouino]
Can't buy what I want because it's free -
n°1797013
gfive
Posté le 08-10-2008 à 10:57:56  profilanswer
[:spamafote] J'imagine que oui, mais c'est la merde, en fait. Non, mais on a un STI de grosses moules dès qu'il s'agit de linux, en fait.
n°1797014
Harkonnen
Un modo pour les bannir tous
Posté le 08-10-2008 à 10:58:22  profilanswer
Transfer a database from one collation in SQL Server 7.0 to a collation in SQL Server 2000
To change the collation of a database between SQL Server 7.0 and SQL Server 2000, you must create the database, the columns, or both with the appropriate collation on the destination server before you transfer the data. However, you can use DTS to drop and then re-create the objects when you transfer data from SQL Server 7.0 to SQL Server 2000. When doing so, you must enable the Use Collation option in DTS.
Note Do not use the DTS utility that is included in SQL Server 7.0 to transfer all objects to or from a computer that is running SQL Server 2000. You must use the DTS utility that is included in SQL Server 2000 when you have to transfer data between SQL Server 7.0 and SQL Server 2000.
To transfer a database from one collation in SQL Server 7.0 to a collation in SQL Server 2000, follow these steps:
1. Back up the source database.
2. Use SQL Server Enterprise Manager to create scripts for all the objects in the source database.
3. If the columns must have a different collation than the default collation on the destination database, make the required collation changes to the appropriate columns in the scripts.
4. Create a new database on the destination server with the appropriate collation.
5. Use SQL Query Analyzer to run the scripts that you created in step 2 on the destination server to re-create all objects in the database.
Note The new tables and columns have the same collation as the database unless you specify a different collation for the columns.
6. Use DTS or the bcp utility to transfer the data.
Note If you use DTS, verify the following:
• Make sure that the Use Collation option is enabled when you transfer data from SQL Server 7.0 to SQL Server 2000.
• Because the objects are already created on the destination server with the appropriate collation, disable the Create Destination Objects First option.
http://support.microsoft.com/kb/325335/en-us
3 bases de données à migrer de la sorte, ça va être un pur bonheur [:el g]
J'ai un string dans l'array (Paris Hilton)
n°1797015
masklinn
Posté le 08-10-2008 à 11:00:34  profilanswer
theredled a écrit :
Bon, c'est la crise dans la conception de PHP :o
Code :
  1. $arr1 = array(2, 4, 7, 8);
  2. $arr2 = array(3, 7, 65, 12);
  3.
  4. foreach ($arr1 as &$el) {
  5.  $el = 3;
  6. }
  7.
  8. // ici $arr1 vaut [3, 3, 3, 3]
  9.
  10. foreach ($arr2 as $el) {
  11.  echo 'yo';
  12. }
  13.
  14. // ici $arr1 vaut [3, 3, 3, 12]
Je comprend à peu près pourquoi mais tout de même [:robert de niro]
zomg epic PHPFail  [:prozac]
 [:roi]
n°1797019
nraynaud
lol
Posté le 08-10-2008 à 11:05:12  profilanswer
bon, je vais à la banque vider mon assurance vie [:el robert]
A+ les moules ...
trainoo.com, c'est fini
n°1797021
___alt
Posté le 08-10-2008 à 11:07:08  profilanswer
A+ les moules ...
Les pâtes ont autant augmenté que ça ?
TRIPS RIGHT BUNCH F SHUTTLE TOM AND JERRY RIGHT YELLOW
n°1797022
Lam's
Profil: bas.
Posté le 08-10-2008 à 11:10:21  profilanswer
Harkonnen a écrit :
Impossible de résoudre le conflit de classement entre 'French_CI_AS' et 'SQL_Latin1_General_CP1_CI_AS' dans l'opération difference.
Moktar, si tu me lis, rajoute 3 jours de retard sur le planning, là on est dans la merde
(ie je dois faire des alter/drop table avec récup préalable de tous les champs type char/varchar pour modifier le classement par défaut, suite à la migration SQL Server 2000/2005 qui ne conserver pas la collation précédemment utilisée)
:sweat: :sweat:
Ca va pas plus vite de recoder le serveur de bases de données ? Moi c'est ce que je ferais en tout cas. :o
(Tiens, hier, j'ai modifié la façon dont je charge mes fichiers: j'utilise mmap maintenant, ce qui va beaucoup plus vite. Mais ça reste con, parce que je continue à les parser avec Xerces au lieu d'utiliser libxml2, comme tout être humain normalement constitué).
n°1797023
Harkonnen
Posté le 08-10-2008 à 11:11:02  profilanswer
PUTAIN MAIS PEINE DE MORT POUR SQL SERVER 2005 §§§§
edit: tiens, je suis pas le seul à avoir eu le souci [:el g]
http://forum.hardware.fr/hfr/Progr [...] 8782_1.htm
Message édité par Harkonnen le 08-10-2008 à 11:11:46
n°1797025
Dion
Acceuil
Posté le 08-10-2008 à 11:11:46  profilanswer
Quand on a un problème avec tous les softs, ca ne vient peut etre pas de "tous les softs" mais de "on", ne crois tu pas ? [:petrus75]
It is not called show art
n°1797026
gfive
Posté le 08-10-2008 à 11:12:53  profilanswer
Tiens, les experts, vous savez ce qui se passe quand la bourse suspend la cotation??
Nan, parce que la courbe est bizarre...Ca descend très raide, on ferme 1/2 heure, et hop, ça remonte :o
n°1797028
Dion
Acceuil
Posté le 08-10-2008 à 11:15:06  profilanswer
Nicolas passe botter quelques culs et ecraser deux trois paires de couilles.
Message édité par Dion le 08-10-2008 à 11:15:11
n°1797029
kadreg
profil: Utilisateur
Posté le 08-10-2008 à 11:16:23  profilanswer
tout le monde sort fumer une clope et se calme :o
brisez les rêves des gens, il en restera toujours quelque chose...  -- laissez moi troller sur discu !
n°1797030
schnapsman​n
Zaford Beeblefect
Posté le 08-10-2008 à 11:16:44  profilanswer
fixing + déclenchement d'ordres stop d'achat sur le cac40 à déclenchement à 3500 (les cons [:ula]).
n°1797033
cosmoschtr​oumpf
dawa powered
Posté le 08-10-2008 à 11:19:37  profilanswer
YEAH MOTHERFUCKER §§§§§ [:am73]
j'ai passé 2 jours bloqué sur une connerie, je viens de résoudre le problème complètement par hasard en corrigeant autre chose [:marc]
Message édité par cosmoschtroumpf le 08-10-2008 à 11:20:20
n°1797034
gfive
Posté le 08-10-2008 à 11:21:53  profilanswer
:??: Heing?
n°1797036
gfive
Posté le 08-10-2008 à 11:24:33  profilanswer
Bon, sinon, Hudson + Maven, c'est vraiment top [:bien]
[:prozac] Faudrait juste que le archiva débite un peu plus.....le download des dépendances (depuis le réseau local, donc) est plus lent que la compilation GWT
Message édité par gfive le 08-10-2008 à 11:26:20
n°1797037
Dj YeLL
$question = $to_be || !$to_be;
Posté le 08-10-2008 à 11:26:43  profilanswer
Code :
  3.
  5.  $el = 3;
  6. }
  7.
  9.
  11.  echo 'yo';
  12. }
  13.
Je vois pas le problème [:spamafote]
Dans ton premier foreach tu fais de $el une référence à chacun des éléments de $arr1 ... donc à la fin du foreach, $el est une référence au dernier élément de $arr1 ..
Dans ton 2ème foreach tu balances les valeurs dans cette référence ... je vois pas ce qu'il y a d'étonnant à ce que sa valeur soit donc mise à jour :??:
Gamertag: CoteBlack YeLL
n°1797039
lorill
Posté le 08-10-2008 à 11:29:37  profilanswer
ca te semblerait pas logique que la visibilité de la variable soit limitée au bloc du foreach qui la déclare ?
n°1797041
schnapsman​n
Zaford Beeblefect
Posté le 08-10-2008 à 11:33:43  profilanswer
10 h 37 : Le Premier ministre britannique Gordon Brown annonce avoir "invité" les autres pays de l'UE à adopter un "plan européen de financement" du système bancaire, précisant en avoir parlé en début de matinée au président français Nicolas Sarkozy.
Tain mais les anglais, ils ne doutent de rien. Démerdez vous avec la livre sterling, les connards  [:tartalap]
n°1797042
Dj YeLL
Posté le 08-10-2008 à 11:34:01  profilanswer
Ça ne me semblerait pas particulièrement "logique" non ...
Il faut pouvoir modifier cette variable à l'intérieur du foreach... et les foreach, c'est pas comme les fonctions, les variables utilisées à l'intérieur ne sont pas là uniquement le temps de boucler (sinon comment utiliser des variables qui viennent de l'extérieur...
'fin bref, je vois parfaitement de quoi vous parlez, mais non, je trouve pas ça si "illogique" :o
n°1797043
gatsu35
Blablaté par Harko
Posté le 08-10-2008 à 11:35:39  profilanswer
edit ah oui ya une grosse connerie de php là [:petrus75]
Message édité par gatsu35 le 08-10-2008 à 11:36:28
n°1797044
seabee
Posté le 08-10-2008 à 11:36:05  profilanswer
Un point regexp/grep pour celui qui me donne une fonction grep qui permet de filtrer mes logs (je veux pas de globalize_translations/globalize_languages dans la ligne, en l'occurence)
Message édité par seabee le 08-10-2008 à 11:36:23
n°1797045
kadreg
profil: Utilisateur
Posté le 08-10-2008 à 11:36:35  profilanswer
eclipse joue a 1 2 3 soleil [:roane]
quand je le regarde, il fige [:pingouino]
[:borntotroll]
Message édité par kadreg le 08-10-2008 à 11:36:45
n°1797046
___alt
Posté le 08-10-2008 à 11:38:56  profilanswer
Détail des logs ?
n°1797047
sligor
Posté le 08-10-2008 à 11:40:05  profilanswer
C'est quoi le mieux pour faire de l'UML sous nulix ?
Papier/Crayon ?
n°1797048
sligor
Posté le 08-10-2008 à 11:41:34  profilanswer
[:borntotroll]
J'ai appris çà hier:
Le nom serait une farce : le créateur de Java est Sun (en français, « soleil »), concurrent qu'IBM semble vouloir « éclipser ».
n°1797049
SekYo
Posté le 08-10-2008 à 11:41:50  profilanswer
R3g a écrit :
C'est là que je comprends pas. Les actions, elles sont deja sur le marché, donc de toute façon le produit de leur vente revient pas à l'entreprise...
Sauf que les investisseurs/futurs actionnaires, leurs fonds ils sont pas non plus entassés chez eux sous forme de lingots, mais proviennent bien souvent de parts dans d'autres sociétés. Si les actions dégringolent, ces investisseurs ont moins à investir dans d'autres boites, qui elles sont pénalisées. Sans compter le climat de méfiance généralisée.
n°1797050
kadreg
profil: Utilisateur
Posté le 08-10-2008 à 11:41:58  profilanswer
[:debarquement]
UML + linux = fail :o
n°1797051
Dion
Acceuil
Posté le 08-10-2008 à 11:42:37  profilanswer
kadreg a écrit :
[:debarquement]
C'est du desktop l'UML !
n°1797052
LePhasme
Les Belges domineront le monde
n°1797053
___alt
Posté le 08-10-2008 à 11:43:02  profilanswer
les crédits à la consommation ont reculé aux Etats-Unis pour la première fois depuis plus de dix ans
 [:fumer]  [:fumer]  [:fumer]  [:fumer]  [:fumer]  [:fumer]  [:fumer]  [:fumer]
n°1797054
skeye
Posté le 08-10-2008 à 11:43:53  profilanswer
figure 1 : un programmeur php, c'est pas comme un programmeur normal
n°1797055
seabee
Posté le 08-10-2008 à 11:44:51  profilanswer
___alt a écrit :
Détail des logs ?
Concrètement, je veux virer les lignes qui contiennent un des mots-clef.
genre
start server | grep all except (raoul|marcel)
n°1797056
Dion
Acceuil
Posté le 08-10-2008 à 11:44:53  profilanswer
MagicBuzzG  [:cerveau sadnoir]
Message édité par Dion le 08-10-2008 à 11:45:02
n°1797057
tholdan
Posté le 08-10-2008 à 11:45:54  profilanswer
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn
n°1797058
kadreg
profil: Utilisateur
Posté le 08-10-2008 à 11:46:14  profilanswer
genre
grep -v
n°1797059
___alt
Posté le 08-10-2008 à 11:46:38  profilanswer
genre
Les bonnes questions:
1) t'as quelle version de grep ?
2) t'as potentiellement beaucoup de mots-clés ?
n°1797060
Dion
Acceuil
Posté le 08-10-2008 à 11:47:15  profilanswer
pluzun
n°1797061
vapeur_coc​honne
Stig de Loisir
Posté le 08-10-2008 à 11:47:43  profilanswer
Dion a écrit :
Ca me fait de la peine qu'on se sente obliger d'expliquer quoi faire pendant une crise de confiance sur ce topic d'experts.
Le niveau a bien baissé depuis l'arrivée de VC :(
[:natas]
R3g a écrit :
Je suis fonctionnaire [:petrus75]
[:wam]
Les experts .... :/
kadreg a écrit :
putain, il y a pas un centre de controle technique a velizy ? Ville de merde :o
bah si plein :o²
[:kaio]
marilou repose sous la neige
n°1797062
ratibus
Posté le 08-10-2008 à 11:48:05  profilanswer
genre
L'option -v de grep est ton amie ;)
Edit : overburned :o
Message édité par ratibus le 08-10-2008 à 11:48:32
Mon blog
n°1797063
seabee
Posté le 08-10-2008 à 11:48:45  profilanswer
Effectivement.
Mais pour plus d'un mot-clef, y'a moyen?
