3881 connectés
Sujet(s) à lire :
    - Who's who@Programmation
 Page :   1  2  3  4  5  ..  13007  13008  13009  ..  27404  27405  27406  27407  27408  27409
n°1661365
masklinn
Posté le 20-12-2007 à 18:05:33  profilanswer
The syntax of our invented ObjectJava is pretty bad there, );}); isn't a thing of beauty, although it's not much worse than the way some real Java looks. The Smalltalk equivalent is much neater. Continuing with our janitorial example:
Code :
  1. aDoor isAlarmed ifTrue: [self disarm: aDoor] ifFalse: [self openNormally: aDoor].
The [], conspicuously unlike the {} of Java, creates a new object, a so-called block, which contains the code to run. And the interesting thing about this is that ifTrue:ifFalse: is just a method. It's a method of the class Boolean. And Boolean has two subclasses: True and False, each of which is a Singleton. The sole instance of True is called true, and similarly for False.
The implementation of ifTrue:ifFalse: in True is:
Code :
  1. ifTrue: t ifFalse: f
  2.  ^ t value
and in False it is
Code :
  2.  ^ f value
(Note: ^ is how Smalltalk spells "return" and value is a method on blocks that returns the value of the code inside the block).
[:vapeur_cochonne]
Message édité par masklinn le 20-12-2007 à 18:05:46
n°1661366
uriel
blood pt.2
Posté le 20-12-2007 à 18:06:26  profilanswer
gooopil a écrit :
Nope, dans le loisir et le divertissement interactif...
center park [:icon9]
IVG en france
n°1661367
uriel
blood pt.2
Posté le 20-12-2007 à 18:06:54  profilanswer
stiffler a écrit :
Quelqu'un pour relire mes fautes d'orthographe ?
dis que t'as pas confiance aussi, connard [:icon8]
IVG en france
n°1661368
stiffler
Lâche mon profil putain ! :o
Posté le 20-12-2007 à 18:09:45  profilanswer
gooopil a écrit :
J'veux bien, mais je me casse du taff dans 2 minutes...
donc non
[:romf]
I'm failing as fast as I can !! -- Vision-360, vos photos en grand format -- !! -- Les nouilles c'est bon
n°1661369
stiffler
Posté le 20-12-2007 à 18:10:22  profilanswer
bah t'es pas français donc oui [:icon8]
n°1661370
Shinuza
This is unexecpected
Posté le 20-12-2007 à 18:10:23  profilanswer
Code :
Code :
  2.  ^ t value
and in False it is
Code :
  2.  ^ f value
[:vapeur_cochonne]
[:huit]
Mains power can kill, and it will hurt the entire time you’re dying from it.
n°1661371
gooopil
pfiew
Posté le 20-12-2007 à 18:11:25  profilanswer
Ben si t'as pas le temps d'attendre une heure que je rentre chez moi, en effet non [:spamafote]
n°1661372
stiffler
Posté le 20-12-2007 à 18:12:01  profilanswer
en fait si tu veux savoir la raison c'est que je t'aime pas [:icon8]
edit: Non c'est que je l'envoi de suite et que ça a déjà été relu [:romf]
Message édité par stiffler le 20-12-2007 à 18:12:37
n°1661373
gooopil
pfiew
Posté le 20-12-2007 à 18:12:16  profilanswer
[:sadnoir]
n°1661375
gooopil
pfiew
Posté le 20-12-2007 à 18:12:55  profilanswer
J'comprends pas, chuis pas méchant pourtant  :cry:
n°1661376
stiffler
Posté le 20-12-2007 à 18:13:15  profilanswer
une fabrique de cockring ?
n°1661377
gooopil
pfiew
Posté le 20-12-2007 à 18:13:24  profilanswer
Oui mais pas relu par un expert  :kaola:
n°1661378
stiffler
Posté le 20-12-2007 à 18:14:18  profilanswer
c'est de la faute à ton pseudo à la con.
Il y a certains pseudos comme ça ... florentg, uriel, tholdan, taiche, ...
n°1661379
stiffler
Posté le 20-12-2007 à 18:14:31  profilanswer
un expert du CDD ?
n°1661380
gooopil
pfiew
Posté le 20-12-2007 à 18:16:13  profilanswer
stiffler a écrit :
un expert du CDD ?
coup bas :o
n°1661381
R3g
fonctionnaire certifié ITIL
Posté le 20-12-2007 à 18:17:24  profilanswer
Bon, il est 18h, goto vacances :o
Au royaume des sourds, les borgnes sont sourds.
n°1661382
mareek
Et de 3 \o/
Posté le 20-12-2007 à 18:17:38  profilanswer
uriel a écrit :
ouais a mort, LCD et alela diane sont en fait des vendus de universal.
  [:theepsilon]
c'est pas parce que les inrock sont vendus à des petits labels que ça les rend meilleurs :o
cosmoschtroumpf a écrit :
quelqu'un connait microsoft project ici ?
j'ai vu utilisé mais j'ai toujours trouvé ça inutile (dans l'informatique en tout cas)
Message édité par mareek le 20-12-2007 à 18:19:26
"I wonder if the internal negative pressure in self pumping toothpaste tubes is adjusted for different market altitudes." John Carmack
n°1661383
mareek
Et de 3 \o/
Posté le 20-12-2007 à 18:19:06  profilanswer
Comme florentg :spamafote:
Bienvenue à bord [:dawa]
n°1661384
uriel
blood pt.2
Posté le 20-12-2007 à 18:19:24  profilanswer
ben si :O
 staline >> hitler
IVG en france
n°1661385
masklinn
Posté le 20-12-2007 à 18:22:46  profilanswer
Bordel j'en ais ras le bol des jsp, c'est le pire environnement de dev qui soit, les messages d'erreur ne sont que des traces java avec des bouts qui manquent, et les traces dans les logs tomcat sont aussi claires que du jus de chique :(
n°1661386
cosmoschtr​oumpf
dawa powered
Posté le 20-12-2007 à 18:26:50  profilanswer
parce que moi pas du tout :o
On a besoin d'un outil qui serve à la fois de gestion de projet au niveau développeur, et de gestion de clients au niveau entreprise, qui se relient.
Mon boss a trouvé vTiger en opensource qui fait un peu tout ça mais qui est frappé d'un syndrome GNU (c'est super complet et complètement personnalisable, mais surtout complètement imbitable). Ca répond à ses besoins de gestion de contacts, de factures et compagnie, le tout dans un seul environnement (aujourd'hui on a 15 logiciels).
Moi j'ai été conquis par FogBuz (le truc de Joel Spolsky), qui me permet, outre les tâches basiques genre bugtracking, de dire à mes patrons "non, si tu me rajoutes une tâche, je pourrais pas rendre le projet à temps", avec jolis graphiques à l'appui, et qui est très facile d'utilisation (surtout face à l'usine à gaz vtiger).
Le top, ça serait un outil qui permette de gérer les deux, et surtout de répondre à notre problématique : "on a un nouveau client/projet, quelle date de livraison réaliste peut-on lui donner ?"
Donc ne connaissant pas MS Project, je me demandais si ça répondais à mon besoin (le besoin de mon boss je n'en doute pas un instant) :o
n°1661387
uriel
blood pt.2
Posté le 20-12-2007 à 18:27:35  profilanswer
l'interview de Bolufer sur france2 de 13h [:everything4free]
 mais quel connard [:mlc]
IVG en france
n°1661388
uriel
blood pt.2
Posté le 20-12-2007 à 18:28:41  profilanswer
sarkozy qui visite le pape.... dans la delegation: jean marie bigard [:pingouino]
 c'est le 1er avril c'est pas possible [:pingouino]
IVG en france
n°1661391
stiffler
Posté le 20-12-2007 à 18:34:38  profilanswer
Ca dépend du nombre projet, de leur taille, du nombre d'intervenant dessus.
Ce genre de truc c'est bon pour des projets de 6 mois à 10 personnes (en gros) [:dawao]
n°1661393
mareek
Et de 3 \o/
Posté le 20-12-2007 à 18:37:57  profilanswer
Joel n'aime pas ms project:
Don't use anything fancy like Microsoft Project. The trouble with Microsoft Project is that it assumes that you want to spend a lot of time worrying about dependencies. A dependency is when you have two tasks, one of which must be completed before the next one can begin. I've found that with software, the dependencies are so obvious that it's just not worth the effort to formally keep track of them.
Another problem with Project is that it assumes that you're going to want to be able to press a little button and "rebalance" the schedule. Inevitably, this means that it's going to rearrange things and reassign things to different people. For software, this just doesn't make sense. Programmers are not interchangeable. It takes seven times longer for John to fix Rita's bug than for Rita to fix Rita's bug. And if you try to put your UI programmer on a WinSock problem, she'll stall and waste a week getting up to speed on WinSock programming. The bottom line is that Project is designed for building office buildings, not software.
http://www.joelonsoftware.com/arti [...] 00245.html
Résumé/lien ?
Doc gyneco était pas dispo, il avait un concert à trouville :spamafote:
Message cité 4 fois
Message édité par mareek le 20-12-2007 à 18:39:57
n°1661395
cosmoschtr​oumpf
dawa powered
Posté le 20-12-2007 à 18:38:25  profilanswer
en fait notre problème, c'est qu'on a 3 projets par mois, de 2 jours chacun, et on est 2 devs (+1 commerciale, 1.5 graphistes et 2 cdp) :/
je crois qu'on trouvera jamais de logiciel à notre échelle :'(
nraynaud, si t'as toujours pas d'idée pour ta boite, y'a un marché pour ça à mon avis [:dawao]
n°1661396
Taiche
Posté le 20-12-2007 à 18:39:30  profilanswer
Han putain j'avais pas vu :lol:
I collectionne le ridicule, Sarko, en ce moment [:petrus75] Kadhafi, Carla Bruni, Bigard chez le pape... putain, énorme :D
Everyone thinks of changing the world, but no one thinks of changing himself  |  It is the peculiar quality of a fool to perceive the faults of others and to forget his own  |  Early clumsiness is not a verdict, it’s an essential ingredient.
n°1661397
mareek
Et de 3 \o/
Posté le 20-12-2007 à 18:40:44  profilanswer
Encore  quatre neuf ans et demie [:sisicaivrai]
n°1661398
Moktar1er
No one replies...
Posté le 20-12-2007 à 18:40:57  profilanswer
Euh... On doit comprendre que de faire un Pert ça ne sert à rien, qu'on s'en fou de connaître les dépendances entre tâches et que c'est une perte de temps que d'identifier un chemin critique? :/
n°1661399
uriel
blood pt.2
Posté le 20-12-2007 à 18:41:58  profilanswer
mareek a écrit :
Résumé/lien ?
http://jt.france2.fr/13h/ c'est au debut
 en clair: il assume mais y en a plein d'autre qui assument pas, ce sont eux le salauds, et puis de toute façon c'est la faute à la mairie de paris, et puis j'suis pas tout seul (ici inserez une citation de l'evangile, non je deconne pas), et Boutin est exceptionelle...
IVG en france
n°1661400
cosmoschtr​oumpf
dawa powered
Posté le 20-12-2007 à 18:42:28  profilanswer
mareek a écrit :
Joel n'ai pas ms project:
[:romf] sauf que la partie suivante ne s'applique pas à notre cas : "I've found that with software, the dependencies are so obvious that it's just not worth the effort to formally keep track of them."
on a tellement de projets (en gros 2 ou 3 par mois au moins, qui durent chacun entre 2 et 10 jours en moyenne, étalés sur 1 ou 2 mois), que c'est indispensable pour nous de savoir quels sont nos "trous" dans lesquels ont peut caser les projets.
n°1661401
stiffler
Posté le 20-12-2007 à 18:42:54  profilanswer
Pour des si petits projets ca va vous bouffer plus de temps qu'autre chose. Il suffit d'un peu de rigueur, d'un agenda et de savoir organiser sa boite mail [:dawa]
n°1661402
mareek
Et de 3 \o/
Posté le 20-12-2007 à 18:43:28  profilanswer
Vu la taille de vos projets, vous avez pas vraiment besoin de logiciel pour gérer ça.
On doit comprendre que project n'est pas adapté au développement logiciel :spamafote:
n°1661404
stiffler
Posté le 20-12-2007 à 18:44:50  profilanswer
Vous avez pas de logiciel de gestion de planning ?
C'est plus ça qu'il vous faut.
n°1661405
uriel
blood pt.2
Posté le 20-12-2007 à 18:45:19  profilanswer
faut voir la sequence, ça vaut le detour: sarko bras dessus/dessous avec bigard qui se penche vers le pape genre grosse blague [:ciler]
 il sait pas se tenir, il touche le pape comme si c'etait son pote, c'est assez interloquent... deja on lui avait signifier son attitude familiere avec poutine et merkel, mais merde le pape [:ciler] (non je sacralise pas le pape, jm'en fous mais tu dois assumer un protocole quand même)
IVG en france
n°1661406
cosmoschtr​oumpf
dawa powered
Posté le 20-12-2007 à 18:46:33  profilanswer
J'en sais trop rien, sans doute, mais lequel dans ce cas ?
n°1661407
stiffler
Posté le 20-12-2007 à 18:47:24  profilanswer
depuis 2000 ça a évolué [:dawa]
T'as plus le second point O_O
n°1661409
mareek
Et de 3 \o/
Posté le 20-12-2007 à 18:48:04  profilanswer
Mais c'est quoi vos projets ? des one shot ? ou des trucs liés les uns aux autres ?
parce que si les projets n'ont aucun lien entre eux, t'as juste besoin d'avoir une liste de tache pour chaque dev et basta.
n°1661410
stiffler
Posté le 20-12-2007 à 18:48:41  profilanswer
Bah n'importe quoi fait l'affaire.
Un logiciel qui permet de rentrer les 10 personnes de la boite et d'y mettre les jours de boulot prévus, les jours de congés et les rendez vous. [:dawa]
n°1661412
masklinn
Posté le 20-12-2007 à 18:50:47  profilanswer
C'est une plaisanterie ou ça c'est vraiment passé comme ça? :sweat:
edit:
http://tempsreel.nouvelobs.com/dep [...] t_xvi.html
"Face à l'effacement des repères, face aux bouleversements que connaissent nos sociétés, je veux dire aussi par ma présence que nous avons besoin de la contribution de l'Eglise catholique, comme de celle des autres grands courants religieux et spirituels, pour éclairer nos choix et construire notre avenir", a-t-il poursuivi.
Attention chéri, ça va roxxer
Message édité par masklinn le 20-12-2007 à 18:53:25
n°1661413
uriel
blood pt.2
Posté le 20-12-2007 à 18:52:15  profilanswer
ben regardes le 13h, c'est au debut, apres l'interview de l'autre enculé, y a des chapitres je crois en plus. :D
IVG en france
