| Auteur | Sujet : [blabla@olympe] Le topic du modo, dieu de la fibre et du monde |
mareek Et de 3 \o/ | Reprise du message précédent :
--------------- "I wonder if the internal negative pressure in self pumping toothpaste tubes is adjusted for different market altitudes." John Carmack |
Publicité | Posté le 06-09-2007 à 21:17:26 ![]() ![]() |
masklinn í dag viðrar vel til loftárása |
--------------- I mean, true, a cancer will probably destroy its host organism. But what about the cells whose mutations allow them to think outside the box by throwing away the limits imposed by overbearing genetic regulations? Isn't that a good thing? |
lorill |
(genre si tu fais un Declare, sur le parametre tu peux editer 3 champs : type, variable et value)
Message édité par lorill le 06-09-2007 à 21:30:30 |
nraynaud lol |
--------------- trainoo.com, c'est fini |
Moktar1er No one replies... |
drasche |
--------------- Whichever format the fan may want to listen is fine with us – vinyl, wax cylinders, shellac, 8-track, iPod, cloud storage, cranial implants – just as long as it’s loud and rockin' (Billy Gibbons, ZZ Top) |
Publicité | Posté le 06-09-2007 à 22:11:39 ![]() ![]() |
Message cité 2 fois Message édité par mareek le 06-09-2007 à 22:14:12 --------------- "I wonder if the internal negative pressure in self pumping toothpaste tubes is adjusted for different market altitudes." John Carmack |
Edit: et accessoirement, le topic il sert aussi à poser des questions, me souviens pas avoir vu qui que ce soit de mal accueilli dessus quand j'y trainais Message cité 1 fois Message édité par masklinn le 06-09-2007 à 22:23:08 --------------- I mean, true, a cancer will probably destroy its host organism. But what about the cells whose mutations allow them to think outside the box by throwing away the limits imposed by overbearing genetic regulations? Isn't that a good thing? |
schnapsmann Zaford Beeblefect |
nraynaud lol |
nraynaud lol |
edit: et que tu le veuilles ou pas, quand des jeux sont taggés indispensables c'est un avis relativement clair. Message cité 1 fois Message édité par masklinn le 06-09-2007 à 22:42:30 --------------- I mean, true, a cancer will probably destroy its host organism. But what about the cells whose mutations allow them to think outside the box by throwing away the limits imposed by overbearing genetic regulations? Isn't that a good thing? |
cosmoschtroumpf dawa powered |
Message cité 1 fois Message édité par cosmoschtroumpf le 06-09-2007 à 22:54:54 --------------- Android/Manettes/Metroidvania/Zelda/Indés/Retrogaming/VDS jeux |
drasche |
drasche | http://www.youtube.com/watch?v=zaXPxxk3sKg Edit: j'en rajoute parce que Message cité 2 fois Message édité par drasche le 06-09-2007 à 23:07:14 --------------- Whichever format the fan may want to listen is fine with us – vinyl, wax cylinders, shellac, 8-track, iPod, cloud storage, cranial implants – just as long as it’s loud and rockin' (Billy Gibbons, ZZ Top) |
Chaos Intestinal |
Moktar1er No one replies... | Merci pour le topic cochmochtroumphe |
schnapsmann Zaford Beeblefect | THERE4S A STARMAN WAITING IN THE SKY§§§ |
el muchacho Comfortably Numb | AH AH, DANS 3H, JE PARS POUR LA RAIE AU PORC --------------- Les aéroports où il fait bon attendre, voila un topic qu'il est bien - Blocklist |
drasche |
Le seul truc qui m'a fait rire, c'est la censure, ils s'y sont mis joyeusement Message cité 2 fois Message édité par drasche le 07-09-2007 à 00:25:14 --------------- Whichever format the fan may want to listen is fine with us – vinyl, wax cylinders, shellac, 8-track, iPod, cloud storage, cranial implants – just as long as it’s loud and rockin' (Billy Gibbons, ZZ Top) |
Lam's Profil: bas. | Microsoft aurait vendu 1 million de Zunes (3% du marché). Mais il y a vraiment des gens qui achètent ça ? |
Lam's Profil: bas. | arf.
el muchacho Comfortably Numb | J'adresse mon salut aux damnés de la terre de ce topic, je me barre --------------- Les aéroports où il fait bon attendre, voila un topic qu'il est bien - Blocklist |
Shinuza This is unexecpected |
--------------- Mains power can kill, and it will hurt the entire time you’re dying from it. |
Raistlin Majere i bouh at you ! |
drasche |
| Sujets relatifs | |
| Plus de sujets relatifs à : [blabla@olympe] Le topic du modo, dieu de la fibre et du monde |
