2324 connectés
  Photo numérique
  Appareil
  Sigma SD14
 Page :   1  2  3
Page Précédente
Sigma SD14
n°1157798
jio
to shoot or not to shoot...
Posté le 31-08-2006 à 10:25:52  profilanswer
http://www.trustedreviews.com/images/article/inline/5107-SigmaSD15FRONT.jpghttp://www.photoreview.com.au/reviews/digitalslr/SD14_front_2.jpg
http://www.photoreview.com.au/reviews/digitalslr/SD14_rear.jpghttp://www.photoreview.com.au/reviews/digitalslr/Function_menu.jpg
Le capteur Fovéon :
http://www.photoreview.com.au/reviews/digitalslr/Foveon_sensor.jpg
Site officiel
Spécs :
Image sensor: 20.7 x 13.6 Foveon X3 (CMOS)  with 14.6 million colour photo detectors (2652 rows x 1768 rows x 3 layers)
Lens mount: Sigma SA
Focal length crop factor: 1.7x
Image formats: RAW (12-bit, lossless compression); JPEG
Image Sizes: 4608 x 3072, 2640 x 1760, 1776 x 1184, 1296 x 864
Shutter speed range: 30 to 1/4000 second plus Bulb up to 30 sec.
Self-timer: 2 and 10 second delay (selectable)
Image Stabilisation: n.a.
Dust removal: Removable dust protector in front of image sensor
Exposure Compensation: +/- 3Ev in 1/3 EV steps
Focus system: TTL phase difference detection AF
Focus modes: Single, Continuous with Predict Function, Manual focus.
Exposure metering/control: 8-segment TTL full-aperture metering with evaluative, centre-weighted & spot metering; P, A, S and M exposure modes
Colour space options: sRGB, Adobe RGB
Custom functions: n.a.
ISO range: ISO 100, 200, 400, 800 (1600 with extended mode)
White balance: Auto, Sunlight, Shade, Overcast, Incandescent, Fluorescent, Flash, Custom (measurement)
Flash: Built-in, pop-up flash, GN 11, coverage to 17mm lens; S-TTL metering; +/- 3EV adjustment in 1.3Ev increments
Sequence shooting: 3.0 fps for 6 frames in Hi mode; 12 frames in Med mode, 24 frames in Low.
Storage Media: CompactFlash Type I/II or Hitachi Microdrive
Viewfinder: Eye-level pentaprism, 98% coverage
LCD monitor: 2.5-inch low-temperature polysilicon LCD with 150,000 pixels
PC interface: USB 2.0
Power supply: BP-21 Lithium-ion rechargeable battery
Dimensions (wxhxd): 144 x 107.3 x 80.5 mm
Weight: 700 grams (body only)
Résumés de reviews et liens vers des galeries :
- http://www.dphotojournal.com/sigma [...] le-photos/
Tests :
- TrustedReviews
- Photoreview
- PopPhoto
- Vidéo
Plus d'infos sur l'appareil et sa technologie :
- Sigma SD14 Resolution: 14 MP?  4.6 MP?
- dpreview
- Test du petit frère sur dpreview (explications techniques du capteur foveon)
Galeries :
- http://www.flickr.com/search/?w=al [...] d14&m=text
- http://www.pbase.com/sigmadslr/group_shoots
Message édité par jio le 15-08-2009 à 03:45:07
n°1157802
jio
Posté le 31-08-2006 à 10:28:48  profilanswer
Au passage si quelqu'un pouvait m'éclairer sur les différences de performance/rendu des capteur Foveon et Bayer, il serait le bienvenu :)
n°1157882
Toxin
Carpe Vitam
Posté le 31-08-2006 à 11:23:52  profilanswer
En théorie, vu qu'il n'y a pas besoin de faire du dématriçage, les images délivrées sont plus piquées que celles issues des autres capteurs.
D'où la convention admise que 3MPix fovéon <> 6Mpix bayer.
Mais peu de personnes ici ont testé le SD10 donc.... ce n'est que de la théorie.
Schrödinger m'a tuer.... ou pas ! Ma galerie - Ma page | Prenez le contrôle de votre EOS numérique
n°1157892
Aquineas2
Damoiseau
Posté le 31-08-2006 à 11:30:08  profilanswer
c'est bizarre comme correspondance..;vu qu'un photosite de sigma compte pour quatre photosites"classiques" (deux verts, un rouge, un bleu)...ca ferait plutot une équivalence 3Mp <> 12 Mp nan?
Le marketing aussi peut être solidaire. | La passion des p'tites images
n°1157894
Toxin
Carpe Vitam
Posté le 31-08-2006 à 11:31:04  profilanswer
Je ne fais que répéter de mémoire ce qui était dit dans je ne sais plus quel truc de Chasseur d'Images.
n°1157936
Aquineas2
Damoiseau
Posté le 31-08-2006 à 11:50:25  profilanswer
Ah oki... Il fait un peu "cheap" niveau design je trouve...c'est dommage.
n°1157938
Cygne_d_et​ang
Modérateur
Punk's not dead
Posté le 31-08-2006 à 11:51:22  profilanswer
c'est un boitier de nikon ?
Morphine 'n whisky - Arrière les Esquimaux! Je rentre seul. Un matador rentre toujours seul! Plus il est grand, plus il est seul. Je vous laisse à vos banquises, à vos igloos, à vos pingouins. ¡ Por favor Señora! À quelle heure le train pour Madrid?
n°1157945
Toxin
Carpe Vitam
Posté le 31-08-2006 à 11:52:48  profilanswer
Non c'est 100% Sigma il me semble.
n°1158929
jio
Posté le 31-08-2006 à 21:18:51  profilanswer
bon alors au final je sais pas ce que ca vaut comme capteur mais en tout cas j'ai trouvé de très belles photos sur pbase et aussi des photos très nettes, piquées, sans bruit (passées au denoiser certainement?), enfin bref ça a l'air pas mal quoi ^^
http://www.pbase.com/sigmadslr/image/54403369
http://www.pbase.com/sigmadslr/image/54423347
http://www.pbase.com/sigmadslr/image/54909613
http://www.pbase.com/sigmadslr/image/54423429
n°1159624
cbl
Twingo's Powered
Posté le 01-09-2006 à 10:31:52  profilanswer
Pour ceux qui veulent connaitre la techno FOVEON:
Sur dpreview il y a les tests des SD9 et SD10
Et sur picturechallenge  aussi
CBL - http://cyrilleb.no-ip.org
n°1160675
jio
Posté le 01-09-2006 à 20:48:40  profilanswer
thx :)
n°1162468
castor66
Fidel Castrouille
Posté le 03-09-2006 à 11:34:10  profilanswer
je me demande combien coute un tel joujou ca doit pas être donné
Mon Site | Abricot66
n°1162470
castor66
Fidel Castrouille
Posté le 03-09-2006 à 11:34:44  profilanswer
en tout cas les photos postées par jlo sont très bonnes!
n°1162811
castor66
Fidel Castrouille
Posté le 03-09-2006 à 14:41:44  profilanswer
Le piqué de celle-ci c'est incroyable, j'ai pas vu un autre pan offri un tel piqué sur un format original (retouchée je ne sais pas mais jepense pas que la retouche puisse améliorer le piqué pour avoir de tel résultats)
Si le SD14 est encoreamélioré il va peut-etre cartonner qui sait !
(capteur CMOS, peut-etre une fusion avec Canon dans le futur? le probleme reste niveau caillou s'ils fusionnent un jour, vu que Sigma fait des cailloux pour les concurrents de Canon, enfin on verra bien ;))
Mais les photos je reste sur le Q
n°1179344
Lektronlib​re
Profil: de face
Posté le 12-09-2006 à 19:15:47  profilanswer
fovéon 3Mpix = entre 9 et 10 Mpix je crois( 3couches)...ainsi on aura tout dit!! :lol:
@castor: oui..excellent piqué!! :love:  mais excellentes conditions de lumière aussi!! ;)
Message édité par Lektronlibre le 12-09-2006 à 19:18:49
☻Attention au monoxyde de dihydrogène!☻  http://www.dhmo.org/translations/french/facts.html
n°1410860
castor66
Fidel Castrouille
Posté le 14-01-2007 à 22:31:06  profilanswer
Up
des news?
n°1411160
jio
Posté le 15-01-2007 à 00:00:06  profilanswer
bha ya un mec qui a posté des photos prises au sigma sur le topic K10D, à part ça..... :D
[flickr] - [Diaporama] - tilt
n°1411166
Posté le 15-01-2007 à 00:03:41  answer
Je trouve quand même que le sélecteur est mal foutu :o
n°1519372
ricoco
Posté le 09-03-2007 à 20:54:20  profilanswer
n°1553558
freeflyboy
Posté le 19-03-2007 à 18:14:52  profilanswer
Superbe panorama, vraiment...  :love:
Je fais une parenthèse avec une question : vu qu'elle a utilisé 85 photos différentes, quels sont les bons logiciels à conseiller pour faire de l'assemblage en vue de panorama ?
A moins qu'elle se soit amusé à tout retravailler pour retrouver une exposition identique sur ses 85 clichés... ce dont je doute  ;)
merci :)
>edit> En cherchant un peu j'ai fini par trouver des posts sur les panoramas...
Message édité par freeflyboy le 20-03-2007 à 12:27:27
n°1643507
Labudouill​e
Posté le 03-05-2007 à 09:49:48  profilanswer
Quelqu'un connaitrait l'efficacite du filtre anti poussière.
D'apres ce que j'ai lu sur dpreview la poussiere ne peut pas atteindre le capteur, et si elle se depose sur le filtre il n'y aurait aucune conséquence sur les photos.
A+
Dsc-R1 - Powershot A610 - Powershot G2
n°1643835
ricoco
Posté le 03-05-2007 à 13:27:41  profilanswer
exact et tu peux enlever le filtre pour le nettoyer ...
n°1644066
IntruX
Posté le 03-05-2007 à 14:57:41  profilanswer
J'ai trouvé une test du SigmaSD14. Malheureusement il est en japonais mais on y trouve aussi un test ISO et des samples:
>test du SD14 en Japonais<
(traduction en anglais par google)
==> ça a l'air bon sauf en montée ISO où le résultat est catastrophique à 800 et 1600iso, c'est même pire que les petits capteurs de bridges. Plus que le grain, c'est l'apparition de taches vertes qui pénalise le rendu en haute sensibilité, d'autant que ces taches ne peuvent pas être traitées avec un logiciel anti-bruit.
n°1645206
ricoco
Posté le 03-05-2007 à 22:14:39  profilanswer
les 3 couches RVB, ca donne des photos  sharp et aux couleurs réalistes
par contre les couches sont superposées donc la dernière couche reçoit moins de lumière et la 2 ieme couhe reçoit moins de lumière que la première
c'est pourquoi la première version des Sigma à capteur Foveon était catastrophique à fort iso
depuis y a eu des progres, heureusement mais ce n'est pas top
tu verras que tous ceux qui plébicite Sigma sur le net, ne posteront jamais une photo au dela de 400 iso et encore c'est de taille rikiki ...
n°1646084
Labudouill​e
Posté le 04-05-2007 à 10:01:44  profilanswer
Salut a tous
Dand le dernier CI il y a un test du SD14. Pour moi le gros intérré, c'est le filtre (D'ailleurs je ne comprend pas que les autres marques n'ont pas suivi cet exemple, surtout que ça ne doit pas couter très cher, enfin).
Par contre CI ne l'apprecie guère.
ex (dernière phrase):"A ce jour, pour un produit limité et peu polyvalent, la facture est salée!"
- Le capteur ne les emballe pas. (meme manque le netteté sur les gris)
- Le filtre, une photo est c'est tout
- Rafale plus lent que le R1 a priori mais 6 vues et 50s d'enregistrement
- Af moins bon que le 300d
- Bruit prononcé a partir de 200 (Moi j'ai lu ailleurs que jusqu'a 800 c'était bon)
V'la pour Info.
a+
n°1648907
Kidplastic
Posté le 05-05-2007 à 12:40:02  profilanswer
Il n'est pas aussi dans RP ?
Je crois que pour eux, après 400iso bof bof...ils notent la même paresse de l'af...etc...
Après c'est toujours la question des usages, besoins & cie...sûrement plus pour du studio/trepied c'est sûr ;)....
n°1650322
Labudouill​e
Posté le 05-05-2007 à 20:52:09  profilanswer
Exact, il y est aussi.
Mais je ne l"ai pas encore lu.
n°1702692
loranclo
Les cons ça ose tout ! ...
Posté le 27-05-2007 à 20:06:03  profilanswer
DRAsd14PAL :D
me plaît bien moi ce concept ... à voir ce que tout cela va donner.
un SD14, 2 ou 3 objos comme il faut, un DP1 et c'est la fête :)
... C'est même à ça qu'on les reconnaît. - Site photo
n°1813729
lionoche
Posté le 14-07-2007 à 00:42:00  profilanswer
Déterrage de la mort, mais ça le vaut !
Le Sigma SD-14 comparé au Canon 5D...
http://www.ddisoftware.com/sd14-5d/
http://www.flickr.com/lionoche
n°1993662
JMD31
Posté le 07-10-2007 à 20:03:26  profilanswer
Impressionnant ! (et déterrage par la même occasion...) ;-)
Le Sigma SD-14 est à 1000 Euros aujourd'hui.
n°1993673
tharkie
Effaré par l'idiotie humaine
Posté le 07-10-2007 à 20:08:44  profilanswer
n°1993861
ricoco
Posté le 07-10-2007 à 21:36:33  profilanswer
au salon de la photo j'ai vu des tirage Epson
du SD14 et 1 DS Mark III
vu que c'était la meme taille la même imprimante c'était archi bluffant pour le SD14 et les couleurs, les détails, ca petait bien !
n°1994050
lionoche
Posté le 07-10-2007 à 22:50:29  profilanswer
Tu revendrais pas ton matos Nikon, par hasard ?
n°1995369
tharkie
Posté le 08-10-2007 à 15:01:24  profilanswer
Je t'échange deux barils de sigma SD14 contre un baril de 1dsmarkIII ?
Sujet sur les cartes son audiophiles pour mélomanes et musiciens & DAC+ADC
n°2387878
snikt59
Posté le 15-03-2008 à 13:10:32  profilanswer
Est-ce que cet appareil vaut le coup à 500€ et ses maj du firmware ?
n°2478804
troicent
Posté le 22-04-2008 à 23:38:50  profilanswer
Il est à 650 euros avec le 18/200 stabilisé!
n°2738372
ted13
Fuji: Es ce sans effesse ??
Posté le 19-08-2008 à 18:50:52  profilanswer
ok super je le prends... le 18-200 avec une monture Nikon et je revends immediatement le boitier  :D
http://www.flickr.com/photos/teddy13/
n°2746336
canikolumi​tax
Posté le 23-08-2008 à 09:35:54  profilanswer
Bonjour a tous.
Convaincu du potentiel du capteur Foveon grâce à mon Dp-1 qui fait des images d'une qualité assez incroyable pour un compact
, j'ai commandé un SD14 et un zoom 18-50 F2.8 macro...
Malheureusement je n'ai pas réussi à faire une photo correcte avec. :(
les images étaient pas vraiment nettes.
1ere photo prise après avoir déballé l'appareil  http://images2.photomania.com/569755/1/rad39D8B.jpg
les suivantes sont pareilles
j'ai retourné l'appareil.
est-ce que quelqu'un a déjà eu ce problème à la réception d'un sd14 neuf ?
merci pour vos réponse. ;)
Message édité par canikolumitax le 23-08-2008 à 09:40:38
n°2748552
ted13
Posté le 24-08-2008 à 22:33:35  profilanswer
canikolumitax a écrit :
Bonjour a tous.
Je ne suis pas sur qu'il s'agisse la d'un défaut de l'appareil car on s'en apercoit surtout si on fait un crop à 100%. Etrange car il ne s'agit pas d'une erreur de mise au point ni d'un flou de bougé. On a plutot l'impression d'une sorte de lissage pour atenuer le bruit provocant une destruction des fin détails...alors que tu n'es qu'a iso 100. (surtout au niveau du feuillage). A moins que ce ne soit provoqué par une interpolation... car tu me sembles à une résolution bien élevée pour du 4,7MP et tu etais peut etre réglé en 14MP interpolés (la compression jpeg peut avoir des conséquences aussi). Il aurait fallu faire un autre essai en 4,7MP effectifs sur un objet de pres ou un visage par exemple. De tte facon, si on doit t'en renvoyer un autre tu seras vite fixé. A moins que tu n'aies une solution de remboursement ce qui serait peut etre moins risqué.
Message édité par ted13 le 25-08-2008 à 12:30:53
n°2820816
ted13
Posté le 24-09-2008 à 21:05:05  profilanswer
Et pouf ! le SIGMA nouveau est arrivé (c'est comme le beaujolais): le SD15
http://www.cicfou.com/files/9b638b [...] df-14.html
Message édité par ted13 le 24-09-2008 à 21:06:09
 Page :   1  2  3
Page Précédente
  Photo numérique
  Appareil
  Sigma SD14
sigma monture minoltaZoom 70-200mm Sigma pour Pentax
Avis sur SIGMA 28-70 mm F2.8 DG EX PentaxSIGMA EF - 500 ST compatible EOS 350 D ???
objo FD 24 ? : canon vs sigmaObjectif Sigma 70-200 f/2,8 pour Nikon
Remplacer Sigma 100 300 4-5,6 APO MACRO par quoi ???Différents Sigma 70-300 Macro, lequel choisir ?
Nikon, Sigma, Metz ?Nouveau SIGMA 17-70mm F2,8-4,5 DC Macro
Plus de sujets relatifs à : Sigma SD14
Hit-Parade
