2041 connectés
  Photo numérique
  Appareil
  [Topic unique] ★ Fujifilm XT1/2-XT10/20 ★ News : Firmware 3.00
 Page :   1  2  3  4  5  ..  248  249  250  251  252  253
Page Précédente
n°5222434
Phenom
Posté le 28-01-2014 à 08:29:49  profilanswer
http://reho.st/self/a0d307f8d6309c93aa4add583534341cc4473635.png
http://reho.st/self/7f76dbda0760a28470b2df1fc1ce55dcbd669707.png
http://reho.st/self/2ec9da37d492a121dfda548c7314f5d1a4725527.png
Capteur 24.3 MP CMOS
Image processing engine X Processor Pro
Video 4K 30fps. Full HD 60fps
Max shutter speed 1/8000 seconds
Max shutter speed 1/32000 sec electronic shutter
Flash synchro speed 1/250 sec
Autofocus 325 collimateurs
Alliage de magnesium
Tropicalisation : dust and water
EVF de 2.36 million dots. Rafraichissement 100 fps
Ecran orientable de 3 pouces 1.62 MP
Double slot SD Card. UHS-II support
AF-C custom settings
Plage ISO de 200 à 12800 (RAW)
Wi-Fi intégré pilotage à distance
16 film simulation modes, including the ACROS
Menu personnalisable : “My Menu”
Raw 14 bit compression sans perte.
Développement dans l’appareil
Correction d’exposition sur +/- 5 EV
Mesure sur 256 zones (multi-spot average, spot, center-weighted)
13 sortes de filtres creatifs
Battery NP-W126S. Autonomie 350 vues
Prise Microphone Jack 3.5 mm. 2.5mm remote terminal.
Prise USB 3.0 terminal et Micro HDMI
http://reho.st/self/27c4972dc11b731fc0892a2c543ba9e987c23c9b.png
http://reho.st/self/5be7fa2b998b8e86e9eb5a0280be13a115f5faa5.png
Firmware : V3.00 Lien pour télécharger le dernier firmware XT2
Changements apportés par le firmware 3.00 :  PDF des changements / améliorations apportées par le dernier firmware XT2
1.
New AF tracking algorithm for moving subject
Thanks to the newly developed image recognition algorithm, the update enhances AF-C to track moving subjects twice as fast as previous firmware. In addition, the update also enhances tracking to be able to capture up to 50% smaller moving subjects than before.
2.
Support "FUJIFILM X RAW STUDIO" for Macintosh
Once connecting a camera to a computer via USB cable, the "FUJIFILM X RAW STUDIO" enables users to convert RAW files with X Processor Pro. The fast batch processing will also be available. The "FUJIFILM X RAW STUDIO" can be downloaded from the FUJIFILM website for free.
*"FUJIFILM X RAW STUDIO Ver.1.0 Installer for Macintosh" can be downloaded from the URL below.
3.
Improve radio flash controller usability
 The upgrade allows users to shoot with compatible third party studio flash in high speed sync. or TTL mode via their radio controllers.
4.
Support for backup/restore of camera settings via "FUJIFILM X Acquire"
Once connecting a camera to a computer via USB cable, the "FUJIFILM X Acquire" allows users to backup/restore camera settings to/from a file. Copying all camera settings from one camera to another is available.
*"FUJIFILM X Acquire Ver.1.7 Installer for Windows/Macintosh" can be downloaded from the URL below.
5.
Support for "Instax SHARE SP-3"
 Additionally," Instax SHERE SP-3" has become compatible with this camera.
6.
RGB histogram display and highlight warning
 If you press the function button allocated to the histogram, RGB histogram and highlight warning (High brightness portion will blink.) are displayed.
7.
The phenomenon is fixed that exposure compensation is not correctly reflected to brightness of live view on LCD and EVF when ISO setting is "AUTO", exposure compensation is "C" and it is changed by the command dial.
http://reho.st/self/870a916b6682ca47b558efb9d0d307779dada4e8.png
X-T2 boîtier nu : 1699 € TTC
Disponibilité : 08 septembre 2016
http://reho.st/self/8a15de6e1969129e89aadf6b77e8529459d508f0.png
Revue Fujifilm XT2 (Focus Numerique)
Revue Fujifilm XT2 (TechRadar)
Revue Fujifilm XT2 (Trusted Review)
Revue Fujifilm XT2 (Le monde de la photo)
Revue Fujifilm XT2 (Camera Labs)
Revue Fujifilm XT2 (Jonasraskphotography)
http://reho.st/self/6bd470a9f71930ba3c354457c330497247c215c1.png
http://reho.st/self/e0a9f62a5bcca56aedcb9a18f0b637c7c81f15ea.jpg
http://reho.st/self/fda1c9ed5758103a622207d618d7d529087d16b2.jpg
http://reho.st/self/9868dc1795d21d5a802088631fb0331c5f989940.jpg
http://reho.st/self/5407471b770e406aec0da602eceaf9e0fc79acf8.jpg
Message édité par Phenom le 09-12-2017 à 19:11:28
Ils ont dû merder à ma naissance, je suis sûr qu'en vrai je suis archiduc
n°5222435
Phenom
Posté le 28-01-2014 à 08:29:55  profilanswer
http://reho.st/self/ccd3c3dd3c448d132a1429232983b9bef58fce7b.png
[:gnel42] Firmware V5.01 : Sortie Janvier 2017 [:gnel42]
[:gnel42] Problème de Light Leak sur les Fujifilm XT1 [:gnel42]
https://www.youtube.com/watch?featu [...] qmpLPinIXQ
Description : Fuite de lumière lorsque la trappe d'accès latérale (prise jack et USB) reste ouverte.
Test pour vérification : Allumer l'appareil, laisser le bouchon d'objectif en place, placer une source lumineuse de forte intensité orientée vers les prises jack et USB, trappe ouverte. Si l'image présente des halos lumineux violets, ce boitier est défectueux.
Numéros de série des boitiers concernés : 41002001 à 41006000.
Procédure pour la France :
- Contacter le SAV Club Fujifilm Pro et ouvrir un dossier incident
- Déposer le XT1 dans un magasin agréée Fujifilm + copie facture + copie mail incident si reçu (Ou obtenir un bon de retour prise en charge par Chronopost)
- Attendre la procédure SAV (une dizaine de jours ouvrables à priori)
Le communiqué Fujifilm :
Communiqué Fujifilm du problème de Light Leak du Fujifilm X-T1
Capteur APS-C X-Trans II de 16.3 millions de pixels.
Processeur d’image EXR II.
Vitesse de démarrage : 0,5 seconde.
Verrouillage AF : 0,08 seconde.
Délai de l’obturateur : 0,05 seconde.
Intervalle entre les prises de vue : 0,5 seconde.
Lecteur de cartes SD/SDHC/SDXC (UHS-II).
EVF offrant une définition de 2,3 millions de points. Grossissement 0,77x.
Taux de rafraichissement de l’EVF : 0,005 seconde.
Tropicalisation avec 80 points d’étanchéité.
Résistance à des températures allant jusqu’à -10°C.
Boitier en magnésium, cadran en aluminium.
Sensibilité : entre 200 et 6 400 ISO avec modes étendues à 12 800, 25 600 ou 51 200 ISO.
Ecran LCD de 3 pouces offrant une définition en 1 40k points.
Vitesse d’obturation : entre 30 et 1/4000 secondes.
Vitesse de synchronisation pour le flash : 1/180 seconde.
Formats vidéos : Full HD à 30p ou 60p, MOV et H264.
Autonomie : 350 photos (norme CIPA).
Type de batterie : NP-W126.
Taille : 129 x 89,8 x 46,7 mm.
Poids : 390 grammes, sans batterie et sans carte mémoire.
Couleur : Noir ou Silver.
Version : V5.30
Firmware : V5.30 [http://www.fujifilm.com/support/digital_cameras/software/firmware/x/xt1/] Lien pour télécharger le dernier firmware XT1[/url]
Principales améliorations avec le Firmware 5.30 :
The firmware update Ver.5.30 from Ver.5.20 incorporates the following issue:
1.
The compatibility is added with XF80mmF2.8 R LM OIS WR Macro.
The accuracy of AF function is improved when the lens is attached.
X-T1 boîtier nu : 1199 € TTC (Site Fujifilm)
Disponibilité : mars 2014
http://reho.st/self/a160a7949d2200156f624d6dac0bb7b97f5b9e50.png
Demi-étui tout cuir dédié (BLC-XT1)
Poignée d’alimentation verticale (VG-XT1)
Poignée en métal Large (MHG-XT Large)
Poignée en métal Small (MHG-XT Small)
Quatre modèles de flash dédiés (EF-X8 Nouveau, EF-X20, EF-20, EF-42)
Déclencheur à distance (RR-90)
Microphone stéréo (MIC-ST1)
Coupleur DC (CP-W126)
Adaptateur secteur (AC-9V)
Hand Grip (GB-001)
Œilleton Large (EC-XT L)
Kit de protection pour connecteur de batterie, griffe porte-accessoire, prise synchro flash (CVR-XT)
Revue du Fujifilm XT1 (DPReview)
Premières impressions de prise en main du Fujifilm XT1 (Petapixel)
Premières impressions de prise en main du Fujifilm XT1 (DPReview)
Premières impressions de prise en main du XT1 (Dan Bailey)
Hands on with the Fujifilm X-T1 (FujifilmBlog)
Premières impressions de prise en main du Fujifilm XT1 + Fuji X 10-24mm (Keithlowphoto)
Test terrain du Fujifilm XT1 + Fuji X 56mm / Fuji X 23mm / Fuji X 18-55mm (Dslrmagazine)
Vidéo démonstration du Camera Remote Wifi de Fujifilm (Youtube)
Test du suivi AF du Fujifilm XT1 (Dan Bailey)
Test terrain du Fujifilm XT1 + Fuji X 10-24mm (Seb Imagery)
Premières impressions de prise en main du Fujifilm XT1 (Wilzworkz)
Revue du Fujifilm XT1 (FujiVSFuji)
Test terrain du Fujifilm XT1 (Vidéo) (Nick Delvin)
Revue du Fujifilm XT1 (Laurence Kim)
Test terrain du Fujifilm XT1 (Mariage) (Daniel K Cheung)
Revue du Fujifilm XT1 (Rupert Marlow)
Revue du Fujifilm XT1 (Bert Stephani)
Reportage photo à Kiev avec le Fujifilm XT1 (Eric Bouvet)
Session portraits Fujifilm XT1 + Fuji X 56mm (Namour Filho)
Prise en main du Fujifilm XT1 (DubaïPhotoClub)
Revue du Fujifilm XT1 (Karl Bratby)
Revue du Fujifilm XT1 (F11 magazine par Tony Bridge - Format pdf)
Revue de l'application remote du Fujifilm XT1 (Flixelpix)
Revue du grip VG-XT1 (F-Sunny)
Revue du Fujifilm XT1 et Fuji X 10-24mm (Olafphotoblog)
Revue du Fujifilm XT1 (Light Traveler)
Revue du Fujifilm XT1 (Phoblographer)
Revue du Fujifilm XT1 (Trusted Reviews)
Revue du Fujifilm XT1 (Gizmodo)
Revue du Fujifilm XT1 (Flixelpix)
Revue du Fujifilm XT1 (Fotodesign)
Revue du Fujifilm XT1 (Photomadd)
Revue du Fujifilm XT1 (Vidéo) (Weddingetcetera)
Revue du Fujifilm XT1 (DigitalCameraWorld)
Revue du Fujifilm XT1 (PhotoReview)
Revue du Fujifilm XT1 (En japonais) (Procameraman)
Revue du Fujifilm XT1 (Outdoorimagesfineart)
Pose longue: Fujifilm XT1 vs Fujifilm XE1 (Fuji vs Fuji)
Revue du Fujifilm XT1 (AboutPhotography)
Revue du Fujifilm XT1 et Fuji X 23mm (Ethan)
Régler son Fujifilm XT1 (Anglais) (John Caz Phototography)
Fuji XT1 et 56mm : Face detection (F Sunny)
Revue du Fujifilm XT1 (Neocamera)
Revue du Fujifilm XT1 (Flemmingbojensen)
Revue du Fujifilm XT1 (Boxedlight)
XT1 vs XE2 vs XPro1 (Fuji Vs Fuji)
http://reho.st/self/f20fdb708f7995ea772238988b266b47273393b1.jpg
   1. AF-assist illuminator /
    Self-timer lamp
    2. Front command dial
    3. Strap eyelet
    4. Fn1 button (function button 1)
    5. Lens signal contacts
    6. Lens release button
    7. Battery-chamber cover latch
    8. Battery-chamber cover
    9. Battery-chamber
    10. Battery latch
    11. Sync terminal (sync terminal cover)
    12. Connector cover
    13. Microphone / remote release connector
    14. HDMI mini connector
    15. Micro USB connector
    16. Focus mode selector
    17. Tripod mount
http://reho.st/self/93a8935fb6c724b2cbaa51bb49e7718080370195.jpg
   1. Microphone
    2. DRIVE dial
    3. Dial lock release
    4. Sensitivity dial
    5. Diopter adjustment control
    6. Hot shoe (hot shoe cover)
    7. Metering dial
    8. ON/OFF switch
    9. Shutter button
    10. Movie-record button
    11. Exposure compensation dial
    12. Fn2 button (function button 2)
    Wi-Fi button (playback mode)
    13. Shutter speed dial
    14. VIEW MODE button
http://reho.st/self/65faa66e1479d0e3d154199c687cb5edd3773eb9.jpg
   1. Electronic viewfinder (EVF)
    2. Playback button
    3. Delete button
    4. Eye sensor
    5. LCD monitor
    6. Vertical battery grip connector cover
    7. AE-L (exposure lock) button
    8. Rear command dial
    9. AF-L (focus lock) button
    10. Indicator lamp
    11. FOCUS ASSIST button
    12. Q (quick menu) button
    Custom settings button
    (press and hold)
    RAW conversion button
    (playback mode)
    13. MENU / OK button
    14. Memory card slot cover
    15. Memory card slot
    16. Selector / Function buttons
    17. DISP (display) / BACK button
    18. Speaker
http://reho.st/self/306b566e35d4b92f2ff97fe73c9b016ab5ac9892.png
Le fujifilm XT1 est proche de la taille des Fujifilm XE1/2 avec le viseur qui dépasse. Le Fujifilm XT1 est plus petit que le XPRO1.
Côte à côte :
http://www.photographique.ch/xt1xe2.jpg
Derrière le XE2:
http://www.photographique.ch/xe2devant.jpg
Côte à côte avec le XPRO1 :
http://www.photographique.ch/xt1xpro1.jpg
Devant le XPRO1:
http://www.photographique.ch/xt1devant.jpg
Message édité par Phenom le 09-12-2017 à 19:54:20
n°5222437
Phenom
Posté le 28-01-2014 à 08:30:22  profilanswer
http://reho.st/self/28579f72983de63004f28fa56717e4610cc581ef.png
Dimensions 118,4mm (L) x 82,8mm (H) x 40,8mm (P) / Profondeur minimale : 31,9mm
Poids 331g (sans accessoire, batterie, ni carte mémoire)
Capteur (APS-C) X-Trans CMOS II 16 millions de pixels
Cartes mémoire SD / SDHC / SDXC (UHS-I)
Format de fichier vidéo : MOV
Compression Vidéo Film : H.264
Audio : Stéréo PCM linéaire
Résolution  L : (3:2) 4896 x 3264 / (16:9) 4896 x 2760 / (1:1) 3264 x 3264
M : (3:2) 3456 x 2304 / (16:9) 3456 x 1944 / (1:1) 2304 x 2304
S : (3:2) 2496 x 1664 / (16:9) 2496 x 1408 / (1:1) 1664 x 1664
L : Vertical : 2160 x 9600 / Horizontal : 9600 x 1440
M : Vertical : 2160 x 6400 / Horizontal : 6400 x 1440
Sensibilité  AUTO (contrôle disponible jusqu’à 6400 ISO)
Sensibilité de sortie étendue : Equivalent à 100, 12800, 25600 et 51200 ISO
Contrôle de l'exposition  Mesure TTL sur 256 zones, Multi / Spot / Moyenne
Mode rafale image/sec  Env. 8.0 images/s (JPEG : max. env. 8 images)
Env. 3.0 images/s (JPEG : jusqu'à la capacité de la mémoire)
Emetteur sans fil  IEEE 802.11b / g / n
Version : V1.21
Firmware : V1.21 Lien pour télécharger le dernier firmware XT10
Principales améliorations avec le Firmware 1.21 :
The accuracy of Manual focus adjustment will be enhanced when using lenses below.
XF35mmF2 R WR / XF90mmF2 R LM WR / XF10-24mmF4 R OIS / XF16-55mmF2.8 R LM WR /
XF18-55mmF2.8-4 R LM OIS / XF18-135mmF3.5-5.6 R LM OIS WR / XF50-140mmF2.8 R LM OIS WR /
XF55-200mmF3.5-4.8 R LM OIS / XF100-400mmF4.5-5.6 R LM OIS WR / XC16-50mmF3.5-5.6 OIS II /
XC50-230mmF4.5-6.7 OIS II
http://reho.st/preview/self/d02f92f5f3eb536e62f3c35c0c89ba743947bcfe.jpg
Message édité par Phenom le 20-09-2016 à 09:11:27
n°5222439
swing
Posté le 28-01-2014 à 08:33:05  profilanswer
[:drap]
photoblog
n°5222440
mkclain
Posté le 28-01-2014 à 08:33:24  profilanswer
drap coupaing :)
n°5222441
Phenom
Posté le 28-01-2014 à 08:34:19  profilanswer
Maj à suivre dans la journée et dans la semaine hein, tout doux :o
n°5222443
Amonchakai
Posté le 28-01-2014 à 08:36:12  profilanswer
n°5222462
Zepi one
Posté le 28-01-2014 à 09:03:47  profilanswer
n°5222470
mkclain
Posté le 28-01-2014 à 09:17:56  profilanswer
Tarifs annoncés de
$1,299 X-T1 body only
$1,699 X-T1 + 18-55
On peut espérer un taro $=€ ce qui semble assez raisonnable, du moins plus raisonnable que le tarif annoncé du X-Pro1.
Premieres images :
http://www.flickr.com/photos/25805 [...] 153273116/
http://farm8.staticflickr.com/7313/12176714365_cacec772d8.jpg
DSCF1511 – SOOC JPEG (full-size) par ricopress, sur Flickr
http://farm3.staticflickr.com/2843/12154703586_d17a8b0105.jpg
DSCF1158 – SOOC JPEG (crop) par ricopress, sur Flickr
http://farm8.staticflickr.com/7328/12174821476_505d4f9b64.jpg
DSCF1446 par ricopress, sur Flickr
Message édité par mkclain le 28-01-2014 à 09:21:22
n°5222472
Phenom
Posté le 28-01-2014 à 09:19:54  profilanswer
1050 livres, donc ça revient kif kif oui.
Par contre ça aurait été mieux avec le kit 16-55 tropicalisé.
Reste à savoir quand le XT1 sera dispo, je sens qu'on va encore attendre un bout de temps.
n°5222483
Zepi one
Posté le 28-01-2014 à 09:32:42  profilanswer
Dispo en mars ...
n°5222490
taxidermis​te
L'ami des bêtes
Posté le 28-01-2014 à 09:38:36  profilanswer
Mon X-Pro 1 + 35mm vs X-T1 + 56mm f1.2:
http://farm6.staticflickr.com/5492/12185931433_c02726b318_b.jpg
http://farm8.staticflickr.com/7348/12185931593_b01cf3fac6_c.jpg
Il est quand même sacrément tentant, même si objectivement mon X-Pro 1 peut encore faire l'affaire pendant un moment!
Ce que j'ai noté:
- le viseur est énorme, grossissement x0.77. Pour donner un ordre d'idée, c'est plus grand que le viseur d'un 5D Mk III, et plus que le précédent champion en viseur électronique, à savoir l'Olympus E-M1 (qui m'avait déjà bluffé). Chapeau Fuji. Rafraichissement à 54fps même dans l'obscurité (là où le X-E2 et l'Olympus ralentissent à 20-30fps)
- l'ergonomie est vraiment bien pensée, réglages principaux par les molettes, le reste avec pas mal de touches personnalisables (6 de mémoire)
- écran orientable protégé par du verre trempé -> yes, enfin!
- intervallomètre intégré + appli avec live view = cool pour les time lapse
- même batterie qu'avant = bof, faudra en avoir plusieurs
- apparemment certains clients de photographes rechignent quand ils voient un petit hybride. Avec la poignée, ça fait "un gros appareil". La classe quoi. Et vive les préjugés idiots...
- tropicalisé = très cool mais pas d'optique pour le moment -> si pas pressé, j'attendrais le kit avec le 16-135 vers juin.
- ce n'est pas dans une salle de conf qu'on teste l'AF donc à voir. Mais Fuji semble avoir fait de nets progrès. Le passage infini / proxi avec le 56mm était quasi instantané (subjectivement un poil plus lent que le E-M1 qui est un champion, mais je pense qu'avec les bons zooms ça devrait être très bien)
J'ai oublié le reste, faut que je retrouve mes notes. Mais au taquet pour le tester en mars ;)
Message édité par taxidermiste le 28-01-2014 à 09:41:09
:: J'ai les goûts les plus simples du monde: je me contente du meilleur ::
n°5222495
Zepi one
Posté le 28-01-2014 à 09:43:23  profilanswer
http://farm6.staticflickr.com/5492 [...] b318_b.jpg
http://farm8.staticflickr.com/7348 [...] fac6_c.jpg
Ce que j'ai noté:
Il effectivement plus petit que le xpro !!! Ca va faire une configuration de voyage avec 2 boitiers quasi-imbattable niveau encombrement/ qualité !
Je me vois déjà avec en juillet prochain pour mon prochain grand voyage
Instagram
n°5222497
barna
Posté le 28-01-2014 à 09:47:37  profilanswer
drapo
n°5222499
Kalymereau
This is not a method
Posté le 28-01-2014 à 09:49:35  profilanswer
Phenom a écrit :
                                     ★★ Fulfijil XT1 ★★
[:ddr555]
Taille XT1: 129 x 89,8 x 46,7 mm, poids 390 g
Taille XE2: 126,5 x 74,4 x 53,9 mm, poids 445 g
si y a pas d'erreur (je suis surpris par le poids) c'est vraiment bien [:implosion du tibia]
Message édité par Kalymereau le 28-01-2014 à 09:50:05
rm -rf internet/
n°5222501
mkclain
Posté le 28-01-2014 à 09:49:40  profilanswer
Ils chient avec la batterie... y'a vraiment encore un effort de ce coté là, quand on voit un reflex qui tape dans les 1000 prises.
n°5222503
Zepi one
Posté le 28-01-2014 à 09:51:21  profilanswer
Des samples :
http://www.fujifilm.com/products/d [...] le_images/
Une petite vidée de présentation :
http://www.youtube.com/watch?featu [...] twe5Hci3kk
Message édité par Zepi one le 28-01-2014 à 09:53:38
Instagram
n°5222505
mkclain
Posté le 28-01-2014 à 09:52:43  profilanswer
Phenom a écrit :
                                              ★★ Fulfijil XT1 ★★
 :lol:  :lol: on dirait le nom d'un mec : FULFI GILLES
n°5222526
moshnride
ABSE Photography
Posté le 28-01-2014 à 10:09:33  profilanswer
ça à l'air vraiment pas mal.
ABSEPhotography.com/Gal HFR/Instagram/Facebook
n°5222530
sinclaire
clear boobs
Posté le 28-01-2014 à 10:11:54  profilanswer
Drap
Je me le prends dès sa dispo  :miam:
n°5222531
le vrai rd​u
je suis oignon
Posté le 28-01-2014 à 10:12:16  profilanswer
Présent [:volta]
très impatient de tester le viseur, sinon c'est vraiment mon rêve qui devient réalité :) je suis fan des commandes à molettes :)
CX|flickr|gal|site
n°5222535
moshnride
ABSE Photography
Posté le 28-01-2014 à 10:15:38  profilanswer
par contre aucune fixe prévu en weatherproof, c'est juste naze.
n°5222581
Phenom
Posté le 28-01-2014 à 10:45:45  profilanswer
Sois patient un peu :o
n°5222582
kikou2419
Posté le 28-01-2014 à 10:46:50  profilanswer
drap
TU Nvidia Shield Android TV
n°5222586
mkclain
Posté le 28-01-2014 à 10:54:05  profilanswer
Tu peux y arriver :
★★ Fulfijilm XT1 ★★  [:lapin_vert:5]
Le 16-55 sera Waterproof lui ?
n°5222589
Aiji
Born Survivor
Posté le 28-01-2014 à 10:57:18  profilanswer
oui c'est annoncé comme waterproof pour les 3 nouveaux objos :o
n°5222590
Phenom
Posté le 28-01-2014 à 10:57:50  profilanswer
n°5222597
panda_man
This time is different
Posté le 28-01-2014 à 11:07:48  profilanswer
Drapo, ça m'intéresse  :D
Mon FlickR
n°5222601
Poogz
Modérateur
Posté le 28-01-2014 à 11:13:52  profilanswer
Tu comptes faire un vrai TU ou tu as juste fait le topic pour faire le topic ?
n°5222604
Grouchotth
Posté le 28-01-2014 à 11:19:40  profilanswer
n°5222626
Phenom
Posté le 28-01-2014 à 11:41:24  profilanswer
Désolé j'ai un boulot en journée :( , du coup si ça peut attendre ce soir et cette semaine, ou je dois poser une demi RTT ? :o  :D
Après si tu considères que le TU objos Nikon avait été mal repris et tait une sombre bouse, dans ce cas :o :D
Message édité par Phenom le 28-01-2014 à 11:42:32
n°5222630
Phenom
Posté le 28-01-2014 à 11:43:19  profilanswer
Bref, pour rencentrer, j'ai un gros doute sur le flash fourni, m'a l'air bien faible.
A la rigueur, baisser le prix et prendre un vrai flash à côté me semble plus approprié.
n°5222643
taxidermis​te
L'ami des bêtes
Posté le 28-01-2014 à 12:01:55  profilanswer
Pas faux, c'est plus un goodie pour les acheteurs (comme les premiers NEX et Oly je crois)
Mais je n'ai pas de flash sur mes 3 derniers appareils et je m'en porte bien. Et si on veut faire du boulot sérieux, on a besoin d'autre chose.
n°5222651
Phenom
Posté le 28-01-2014 à 12:15:27  profilanswer
Annoncé à 1199 euros par Fujifilm France pour le boitier seul.
Annoncé à 1599 euros par Fujifilm France pour le boitier + 18-55 en kit.
Disponibilité en Mars 2014.
Message édité par Phenom le 28-01-2014 à 12:15:39
n°5222656
Zepi one
Posté le 28-01-2014 à 12:20:32  profilanswer
Sur le papier c'est presque le boîtier parfait selon mes besoins... L'AF sera le juge de paix , si il est bon je craquerai.
Pour faire court :
+ boîtier qui reste compact et léger
+ capteur qui a fait ces preuves
+ gamme optique
+ design (j'adore)
- l' AF qui a encore tout a prouver
- batterie (en même temps si c'est la même que le xpro c'est pas si mal que ça on voyagera avec 1 chargeur et 3 batteries)
- le prix qui n'est pas si contenu que ça
- 4 Mpx de plus je n'aurais pas été contre
Message édité par Zepi one le 28-01-2014 à 12:22:23
n°5222671
Zepi one
Posté le 28-01-2014 à 12:40:31  profilanswer
Je partage ton avis, il n'est pas forcément innovant mais c'est le boitier Fuji qui manquait dans la gamme...
Après l'aps-c c'est un choix comme un autre.Le boîtier compact FF existe deja chez Sony, mais les optiques lumineuses FF (AF) c'est probablement  pas réalisable pour le moment.
Donc je préfère un combo aps-c équilibré avec un x-machintruc et le 23 f1.4 qu'un FF tout petit avec assez gros 35 f2.8.
n°5222679
Phenom
Posté le 28-01-2014 à 12:44:06  profilanswer
n°5222680
jeanns
Posté le 28-01-2014 à 12:44:29  profilanswer
merci pour ton retour d'infos et photos, bel appareil, me tente bien mais d'un moint de vue marketing il sort un peu tard ama , juste apres la sortie du sony A7 qui est lui Full frame, presque au même prix
Page Précédente
  Photo numérique
  Appareil
[Topic unique] Futur boitier Pentax plein format numérique[Topic Unique] La vidéo avec un reflex Canon
discutons du best of 2013 [topic unique]best of 2013 [topic unique]
[Pure topic unique] Nikon Df[Topic Unique] Sony Cybershot RX10
[Topic unique] Les objectifs Sony FE *24X36*[Topic Unique] Sony A7 et tous ses modèles
[Topic unique] Smartlenses Sony QX10 | QX30 | QX100 | QX1TopikUnik ● Pentax K-3 : I, II, III, soleil ! ●
Plus de sujets relatifs à : [Topic unique] ★ Fujifilm XT1/2-XT10/20 ★ News : Firmware 3.00
