BONJOUR,
je voudrais installer un rehobus sur mon boitier antec p150
j'hesite entre 2 modeles:
le coolmaster aerogate II
le silverstone fp52
petit comparatif
Manufacturer/ Model Cooler Master Aerogate II Silverstone SST-FP52
Fan Control
No. of Fans (max) 4x 3x
Regulator 1x Knobs automatic
Status in display in display
Fan Voltage 7 - 12 Volt automatic
Fan Startup Preset automatic
Monitoring Functions
Temperature Sensors 4x 3x
Cable Labeling CPU/CASE/HDD/VGA CPU/SYS/HDD
Monitoring range 0 - 90° C ( 32 - 194° F) 0 - 100° C ( 32 - 212° F)
Fans 4x 3x
Minimum RPM 500 n.a.
Alarm Signal yes yes
Temperature Settings no Unlimited
Other no Alarm clock, time, date
Display
Temperature Status yes yes
Celsius / Fahrenheit yes / yes yes / yes
RPM Status in display yes yes
Number of Colors 7 1, blue
Display Size 41 x 20 mm 45 x 18 mm
Accessories Included
Sensor cable 4x 3x
Additional Front Panels no no
Molex Cable 4x 3x
Motherboard Signal Cable no no
Screws yes yes
Cable Ties no no
5.25" mounting accessory not necessary no
voila...
