1459 connectés
Probléme avec munin.
n°997099
hppp
Serveur@home
Posté le 02-01-2008 à 19:18:07  profilanswer
Salut a tous
Je viens d'installer munin sur un autre serveur encore car je l'ai installé sur plusieurs serveurs sans probléme mais la munin ne me crée pas les graphiques. Merci si vous avez déjà eu se probléme
 Voila les logs:
Code :
  1. Jan 02 19:15:04 [5421] - INFO: Changing max of localdomain -> localhost.localdomain -> swap -> swap_out to 100000.
  2. Jan 02 19:15:04 [5421] - INFO: Changing min of localdomain -> localhost.localdomain -> swap -> swap_out to 0.
  3. Jan 02 19:15:04 [5421] - INFO: Changing type of localdomain -> localhost.localdomain -> swap -> swap_out to DERIVE.
  4. Jan 02 19:15:04 [5421] - ERROR: Could not rename file: No such file or directory
  5. Jan 02 19:15:04 [5421] - INFO: Changing max of localdomain -> localhost.localdomain -> swap -> swap_in to 100000.
  6. Jan 02 19:15:04 [5421] - INFO: Changing min of localdomain -> localhost.localdomain -> swap -> swap_in to 0.
  7. Jan 02 19:15:04 [5421] - INFO: Changing type of localdomain -> localhost.localdomain -> swap -> swap_in to DERIVE.
  8. Jan 02 19:15:04 [5421] - ERROR: Could not rename file: No such file or directory
  9. Jan 02 19:15:04 [5421] - INFO: Changing max of localdomain -> localhost.localdomain -> load -> load to undef.
  10. Jan 02 19:15:04 [5421] - INFO: Changing min of localdomain -> localhost.localdomain -> load -> load to undef.
  11. Jan 02 19:15:04 [5421] - INFO: Changing type of localdomain -> localhost.localdomain -> load -> load to GAUGE.
  12. Jan 02 19:15:04 [5421] - ERROR: Could not rename file: No such file or directory
  13. Jan 02 19:15:04 [5421] - INFO: Changing max of localdomain -> localhost.localdomain -> df_inode -> _dev_sda1 to undef.
  14. Jan 02 19:15:04 [5421] - INFO: Changing min of localdomain -> localhost.localdomain -> df_inode -> _dev_sda1 to undef.
  15. Jan 02 19:15:04 [5421] - INFO: Changing type of localdomain -> localhost.localdomain -> df_inode -> _dev_sda1 to GAUGE.
  16. Jan 02 19:15:04 [5421] - ERROR: Could not rename file: No such file or directory
  17. Jan 02 19:15:04 [5421] - INFO: Changing max of localdomain -> localhost.localdomain -> df_inode -> _dev_root to undef.
  18. Jan 02 19:15:04 [5421] - INFO: Changing min of localdomain -> localhost.localdomain -> df_inode -> _dev_root to undef.
  19. Jan 02 19:15:04 [5421] - INFO: Changing type of localdomain -> localhost.localdomain -> df_inode -> _dev_root to GAUGE.
  20. Jan 02 19:15:04 [5421] - ERROR: Could not rename file: No such file or directory
  21. Jan 02 19:15:04 [5421] - INFO: Changing max of localdomain -> localhost.localdomain -> df_inode -> _dev_sda2 to undef.
n°997105
zecrazytux
Posté le 02-01-2008 à 19:28:21  profilanswer
Blog photo/récits activités en montagne http://planetcaravan.net
n°997124
hppp
Serveur@home
Posté le 02-01-2008 à 20:27:18  profilanswer
oui mais le quel?
n°997127
zecrazytux
Posté le 02-01-2008 à 20:32:30  profilanswer
c'est log ne suffisent pas.
pas d'autres infos ?
tu as une option debug ?
utilise strace ?
n°997130
hppp
Serveur@home
Posté le 02-01-2008 à 20:38:26  profilanswer
j'ai que sa come log.je crois pas qu'il est une option debug, jamais fait de strace.
n°997134
zecrazytux
Posté le 02-01-2008 à 20:41:28  profilanswer
ben c'est le moment de t'y mettre ! :)
je connais pas munin, c'est un daemon ? si oui tu dosi avoir uen option pour le lancer en mode non daemon.
strace monprogquisucks 2> /tmp/strace-monprogqusucks.log
Probleme swap lors de l'installation ubuntuprobleme windows XP sur raid > drivers sata nvraid
[VPN] Netgear problème de connexion et d'accès partageDebian - net install problème reconnaissance disque dur
problème pour graver des dvd sous k3bprobleme de LBA et nombre de secteurs sur un disque
Problème server x lors de l'installationProbléme depuis l'ajout d'un HDD.
j'ais un problèmeProbleme connexion Vmware
Plus de sujets relatifs à : Probléme avec munin.
