2828 connectés
  Linux et OS Alternatifs
  Installation
  problème d'installation de policykit-qt
n°1155020
Mac Gyver ​974
Posté le 13-08-2009 à 22:21:18  profilanswer
Bonsoir, je ne parviens pas à installer (sous Gentoo) policykit-qt ! =>
>>> Emerging (2 of 2) sys-auth/policykit-qt-0.9.2
 * polkit-qt-0.9.2.tar.bz2 RMD160 SHA1 SHA256 size ;-) ...                                                    [ ok ]
 * checking ebuild checksums ;-) ...        [ ok ]
 * checking auxfile checksums ;-) ...        [ ok ]
 * checking miscfile checksums ;-) ...        [ ok ]
>>> Unpacking source...
>>> Unpacking polkit-qt-0.9.2.tar.bz2 to /var/tmp/portage/sys-auth/policykit-qt-0.9.2/work
>>> Source unpacked in /var/tmp/portage/sys-auth/policykit-qt-0.9.2/work
>>> Preparing source in /var/tmp/portage/sys-auth/policykit-qt-0.9.2/work/polkit-qt-0.9.2 ...
>>> Source prepared.
>>> Configuring source in /var/tmp/portage/sys-auth/policykit-qt-0.9.2/work/polkit-qt-0.9.2 ...
>>> Working in BUILD_DIR: "/var/tmp/portage/sys-auth/policykit-qt-0.9.2/work/polkit-qt-0.9.2_build"
cmake -C /var/tmp/portage/sys-auth/policykit-qt-0.9.2/temp/gentoo_common_config.cmake -DCMAKE_INSTALL_PREFIX=/usr -DBUILD_examples=OFF -DBUILD_EXAMPLES=OFF -DBUILD_Examples=OFF -DCMAKE_BUILD_TYPE=Gentoo -DCMAKE_INSTALL_DO_STRIP=OFF -DCMAKE_USER_MAKE_RULES_OVERRIDE=/var/tmp/portage/sys-auth/policykit-qt-0.9.2/temp/gentoo_rules.cmake /var/tmp/portage/sys-auth/policykit-qt-0.9.2/work/polkit-qt-0.9.2
loading initial cache file /var/tmp/portage/sys-auth/policykit-qt-0.9.2/temp/gentoo_common_config.cmake
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/i686-pc-linux-gnu-gcc
-- Check for working C compiler: /usr/bin/i686-pc-linux-gnu-gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/i686-pc-linux-gnu-g++
-- Check for working CXX compiler: /usr/bin/i686-pc-linux-gnu-g++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - found
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found.
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found.
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found.
-- Found Qt-Version 4.5.1 (using /usr/bin/qmake)
-- Looking for XOpenDisplay in /usr/lib/libX11.so;/usr/lib/libXext.so
-- Looking for XOpenDisplay in /usr/lib/libX11.so;/usr/lib/libXext.so - found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found X11: /usr/lib/libX11.so
-- Looking for include files CMAKE_HAVE_PTHREAD_H
-- Looking for include files CMAKE_HAVE_PTHREAD_H - found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Found Automoc4: /usr/bin/automoc4
-- checking for module 'polkit>=0.8'
--   package 'polkit>=0.8' not found
CMake Error at cmake/modules/FindPkgConfig.cmake:270 (message):
  A required package was not found
Call Stack (most recent call first):
  cmake/modules/FindPkgConfig.cmake:322 (_pkg_check_modules_internal)
  CMakeLists.txt:17 (pkg_check_modules)
-- checking for module 'polkit-dbus>=0.8'
--   package 'polkit-dbus>=0.8' not found
  CMakeLists.txt:18 (pkg_check_modules)
-- checking for module 'polkit-grant>=0.8'
--   package 'polkit-grant>=0.8' not found
  CMakeLists.txt:19 (pkg_check_modules)
-- <<< Gentoo configuration >>>
Build type: Gentoo
Install path: /usr
-- Configuring incomplete, errors occurred!
 * ERROR: sys-auth/policykit-qt-0.9.2 failed.
 * Call stack:
 *               ebuild.sh, line   49:  Called src_configure
 *             environment, line 2831:  Called cmake-utils_src_configure
 *             environment, line  796:  Called die
 * The specific snippet of code:
 *       cmake ${cmakeargs} "${CMAKE_USE_DIR}" || die "cmake failed";
 *  The die message:
 *   cmake failed
 * If you need support, post the topmost build error, and the call stack if relevant.
 * A complete build log is located at '/var/tmp/portage/sys-auth/policykit-qt-0.9.2/temp/build.log'.
 * The ebuild environment file is located at '/var/tmp/portage/sys-auth/policykit-qt-0.9.2/temp/environment'.
>>> Failed to emerge sys-auth/policykit-qt-0.9.2, Log file:
 * Messages for package sys-auth/policykit-qt-0.9.2:
 * Call stack:
 *  The die message:
 *   cmake failed
Y eu une dépendance qui s'est installé mais avec un problème, ils'agit de sys-auth/policykit-0.92 =>
PolicyKit-1.xml:5: warning: failed to load external entity "http://www.oasis-open.org/docbook/xml/4.1.2/docbookx.dtd"
I/O error : Attempt to load network entity http://www.oasis-open.org/docbook/ [...] cbookx.dtd
polkitd-1.xml:5: warning: failed to load external entity "http://www.oasis-open.org/docbook/xml/4.1.2/docbookx.dtd"
pkexec.xml:5: warning: failed to load external entity "http://www.oasis-open.org/docbook/xml/4.1.2/docbookx.dtd"
Note: Writing polkitd-1.8
Note: Writing pkexec.1
Note: Writing PolicyKit-1.8
/usr/bin/xsltproc -nonet --stringparam man.base.url.for.relative.links /usr/share/gtk-doc/html/polkit-1/ --xinclude http://docbook.sourceforge.net/rel [...] ocbook.xsl pkcheck.xml
/usr/bin/xsltproc -nonet --stringparam man.base.url.for.relative.links /usr/share/gtk-doc/html/polkit-1/ --xinclude http://docbook.sourceforge.net/rel [...] ocbook.xsl pkaction.xml
pkcheck.xml:5: warning: failed to load external entity "http://www.oasis-open.org/docbook/xml/4.1.2/docbookx.dtd"
pkaction.xml:5: warning: failed to load external entity "http://www.oasis-open.org/docbook/xml/4.1.2/docbookx.dtd"
Je ne comprends rien, je suis pas assez calé là.... si qqun peut m'aider  :??:
n°1155021
Modération
Posté le 13-08-2009 à 22:24:45  answer
Topic en double, continue sur l'autre.
  Installation
policykit-qt, je n'arrive pas à l'installer [Gentoo]Partage samba, probleme d'acces depuis le nom d'hôte
Ubuntu wifi - problème d'upload sur réseau localprobleme de telechargement ou materiel suis perdu
probleme installation backtrack[ Topic Unique ] Problème de connexion à Internet
Netinstal Debian ProblèmeProblème avec un raid 5 logiciel (mdadm) [résolu]
Problème rlogin
Plus de sujets relatifs à : problème d'installation de policykit-qt
