540 connectés
  OS Alternatifs
  Installation
  PB phpMyAdmin Linux
PB phpMyAdmin Linux
n°968718
Sm@No
Posté le 24-10-2007 à 11:38:09  profilanswer
J'ai un pb suite à l'installation de apache2 mysql php et phpMyAdmin.
Donc les versions:
Linux Linux-Smano 2.6.22.9-0.4-default #1 SMP 2007/10/05 21:32:04 UTC i686
apache2: Apache/2.2.6 (Linux/SUSE)
PHP Version 5.2.4
mysql   5.0.45
phpMyAdmin 2.11.0
Voila donc aprés installation et configuration du tout j'ai un pb apparent des error log de apache.
Code :
  1. [Wed Oct 24 11:27:57 2007] [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
  2. [Wed Oct 24 11:27:57 2007] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec2)
  3. [Wed Oct 24 11:27:57 2007] [notice] Apache/2.2.6 (Linux/SUSE) mod_ssl/2.2.6 OpenSSL/0.9.8e PHP/5.2.4 with Suhosin-Patch configured -- resuming normal operations
  4. [Wed Oct 24 11:35:55 2007] [error] [client 192.101.101.33] PHP Warning:  session_start(): open(/var/lib/php5/sess_s0,LqMgR3GcEMAIzfujdQ21FSs8, O_RDWR) failed: Permission denied (13) in /srv/www/htdocs/phpMyAdmin/libraries/session.inc.php on line 89
  5. [Wed Oct 24 11:35:55 2007] [error] [client 192.101.101.33] PHP Warning:  Unknown: open(/var/lib/php5/sess_s0,LqMgR3GcEMAIzfujdQ21FSs8, O_RDWR) failed: Permission denied (13) in Unknown on line 0
  6. [Wed Oct 24 11:35:55 2007] [error] [client 192.101.101.33] PHP Warning:  Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0
  7. [Wed Oct 24 11:35:55 2007] [error] [client 192.101.101.33] File does not exist: /srv/www/htdocs/phpMyAdmin/favicon.ico
  8. [Wed Oct 24 11:35:55 2007] [error] [client 192.101.101.33] File does not exist: /srv/www/htdocs/phpMyAdmin/favicon.ico
Je n'est pas encore configuré ma base sql mais j'ai donné un accés comme ceci avec le compte root:
J'ai qd mm demander un mdp pour root dans mysql:
Code :
  1. /* Authentication type */
  2. $cfg['Servers'][$i]['auth_type'] = 'http';
  3. $cfg['Servers'][$i]['user'] = 'root';
  4. $cfg['Servers'][$i]['password'] = 'mdp';
  5. $cfg['Servers'][$i]['nopassword'] = FALSE;
  6. /* Server parameters */
  7. $cfg['Servers'][$i]['host'] = 'localhost';
  8. $cfg['Servers'][$i]['connect_type'] = 'tcp';
  9. $cfg['Servers'][$i]['compress'] = false;
  10. $cfg['Servers'][$i]['ssl'] = FALSE;
  11. /* Select mysqli if your server has it */
  12. $cfg['Servers'][$i]['extension'] = 'mysqli';
  13. /* User for advanced features */
  14. $cfg['Servers'][$i]['controluser'] = 'pma';
  15. $cfg['Servers'][$i]['controlpass'] = 'pw;
  16. //$cfg['Servers'][$i]['controluser'] = '';
  17. //$cfg['Servers'][$i]['controlpass'] = '';
  18. /* Advanced phpMyAdmin features */
  19. $cfg['PmaAbsoluteUri'] = 'http://localhost/phpmyadmin /';
  20. #$cfg['Servers'][$i]['pmadb'] = ''; // 'phpmyadmin' - see scripts/create_tables.sql
  21. $cfg['Servers'][$i]['pmadb'] = 'phpmyadmin';
  22. $cfg['Servers'][$i]['bookmarktable'] = 'pma_bookmark';
  23. $cfg['Servers'][$i]['relation'] = 'pma_relation';
  24. $cfg['Servers'][$i]['table_info'] = 'pma_table_info';
  25. $cfg['Servers'][$i]['table_coords'] = 'pma_table_coords';
  26. $cfg['Servers'][$i]['pdf_pages'] = 'pma_pdf_pages';
  27. $cfg['Servers'][$i]['column_info'] = 'pma_column_info';
  28. $cfg['Servers'][$i]['history'] = 'pma_history';
  29. //$cfg['Servers'][$i]['designer_coords'] = 'pma_designer_coords';
  30. $cfg['Servers'][$i]['verbose_check'] = TRUE;
  31. $cfg['Servers'][$i]['AllowRoot'] = TRUE;
  32. //$cfg['Servers'][$i]['AllowDeny']['rules'] = array();// of strings
  33. $cfg['Servers'][$i]['AllowDeny']['order'] = ''
  34. //$cfg['Servers'][$i]['hide_db']       = '';
  35. /*
  36. * End of servers configuration
  37. */
  38. /*
  39. * Directories for saving/loading files from server
  40. */
  41. $cfg['UploadDir'] = '';
  42. $cfg['SaveDir'] = '';
J'ai toujours une erreur:
phpMyAdmin - Erreur
Erreur lors du démarrage de la session, veuillez vérifier les erreurs indiquées par PHP ou dans le fichier témoin du serveur web, et configurer PHP correctement.
c'est bien celui ci le php.ini a modifier?
/etc/php5/apache2/php.ini:
Si vous avez des idées merci!!!
Message édité par Sm@No le 24-10-2007 à 11:44:27
n°968798
Sm@No
Posté le 24-10-2007 à 13:26:38  profilanswer
Pour le favicon.ico c'est réglé mais il me reste les autre erreurs qui bloque l'accées a phpMyAdmin.
Code :
  1. [Wed Oct 24 13:23:53 2007] [error] [client 192.101.101.33] PHP Warning:  session_start(): open(/var/lib/php5/sess_BGiHPACot-zkS67KHRodAPsfJma, O_RDWR) failed: Permission denied (13) in /srv/www/htdocs/phpMyAdmin/libraries/session.inc.php on line 89
  2. [Wed Oct 24 13:23:54 2007] [error] [client 192.101.101.33] PHP Warning:  Unknown: open(/var/lib/php5/sess_BGiHPACot-zkS67KHRodAPsfJma, O_RDWR) failed: Permission denied (13) in Unknown on line 0
  3. [Wed Oct 24 13:23:54 2007] [error] [client 192.101.101.33] PHP Warning:  Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0
Apparement le USer de php n'a pas les droit d'écriture sur le fichier /var/lib/php5 est ce ca?
A l'aide.
/var/lib/php5:
dr-xr-xr-x 2 wwwrun     root        336 Oct 24 14:36 php5
Mon UID de apache est wwwrun groupe www.
Comment je sais pour l'utilisateur php?
Message édité par Sm@No le 24-10-2007 à 14:46:31
n°968903
Sm@No
Posté le 24-10-2007 à 14:54:22  profilanswer
Du nouveau:
Code :
  1. PHP Warning:  Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0
Mon fichier php.ini:
session.save_path = "/var/lib/php5"
Quelque chose de choquant?
  OS Alternatifs
  Installation
  PB phpMyAdmin Linux
firmware (linux) pour set up boxAccès à un dossier et imprimante partagés sur Linux à partir d'un Mac
Mon 1er LinuxAnkh 2 : Un port Linux si 250 pré-commandes
Capture video linux [resolu]Installation d'un disque dur sata sous linux
[Debat] Ubuntu 7.10 - Linux est-il pret pour le Dektop grand public ?Problème de session avec linux
Linux ou Windows ?telecommande radio pour linux
Plus de sujets relatifs à : PB phpMyAdmin Linux
Hit-Parade
