2134 connectés
  Linux et OS Alternatifs
  Installation
  [MDK] Probleme urpmi
n°624734
Neo_t3
Posté le 23-01-2005 à 10:58:33  profilanswer
Depuis hier soir il m'est impossible de mettre à jour ma Mandrake 10.1 :
[root@planetneo neo_t3]# urpmi --auto-select
Pour satisfaire les dépendances, les 13 paquetages suivants vont être installés (43 Mo):
kdebase-3.2.3-134.4.101mdk.i586
kdebase-common-3.2.3-134.4.101mdk.i586
kdebase-kate-3.2.3-134.4.101mdk.i586
kdebase-kcontrol-nsplugins-3.2.3-134.4.101mdk.i586
kdebase-kdeprintfax-3.2.3-134.4.101mdk.i586
kdebase-kdm-config-file-3.2.3-134.4.101mdk.i586
kdebase-kmenuedit-3.2.3-134.4.101mdk.i586
kdebase-konsole-3.2.3-134.4.101mdk.i586
kdebase-progs-3.2.3-134.4.101mdk.i586
libkdebase4-3.2.3-134.4.101mdk.i586
libkdebase4-kate-3.2.3-134.4.101mdk.i586
libkdebase4-kmenuedit-3.2.3-134.4.101mdk.i586
libkdebase4-konsole-3.2.3-134.4.101mdk.i586
Est-ce correct ? (O/n) o
    ftp://ftp.proxad.net/pub/Distributions_Linux/Mandrakelinux/official/updates/10.1/main_updates/./kdebase-kcontrol-nsplugins-3.2.3-134.4.101mdk.i586.rpm
...échec de la récupération : curl failed: exited with 19 or signal 0
...échec de la récupération : curl: (19) Given file does not exist
installation de /var/cache/urpmi/rpms/kdebase-konsole-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/libkdebase4-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-kate-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-kdm-config-file-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/libkdebase4-kmenuedit-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/libkdebase4-kate-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-kdeprintfax-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-kmenuedit-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/libkdebase4-konsole-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-progs-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-common-3.2.3-134.4.101mdk.i586.rpm
L'installation a échoué:
        kdebase = 1:3.2.3-134.3.101mdk is needed by (installed) kdebase-kcontrol-nsplugins-3.2.3-134.3.101mdk
L'installation a échoué, il manque des fichiers :
Vous devriez mettre à jour votre base de données urpmi
Je precise que j'ai essayer de changer de source mais c'est pareil.
Message édité par Neo_t3 le 25-01-2005 à 11:22:55
Neo_t3 registered Linux user number 354648. | http://www.ondaflow.com
n°624737
shaddy
j'aime la gym
Posté le 23-01-2005 à 11:27:51  profilanswer
J'ai aussi des problèmes avec les mises à jour de KDE. Apparemment il y a des dépendances manquantes : mandrake-mime-4.10 je crois...
Ubuntu c'est nul ! Tu l'installes et puis ça marche ... y a rien à bidouiller. rm -rf /
n°624758
Mjules
Modérateur
Parle dans le vide
Posté le 23-01-2005 à 12:19:12  profilanswer
essaye avec wget (urpmi --wget)
remets à jour ta base urpmi
attends un peu, il est possible que tu sois tombé en plein milieu d'une maj du mirroir
Message édité par Mjules le 23-01-2005 à 12:19:56
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°624784
Neo_t3
Posté le 23-01-2005 à 12:55:10  profilanswer
Fait, sans changement resultat identique
Je vais attendre  :ange:
Sinon c'est la paquetage kdebase-kcontrol-nsplugins-3.2.3-134.4.101mdk.i586 qui n'est present sur aucun serveur, qui plante donc l'installation  :sol:
n°624787
Mjules
Modérateur
Parle dans le vide
Posté le 23-01-2005 à 13:08:01  profilanswer
à mon avis, ils se sont ratés dans la maj des updates et le paquet est manaquant, ya plus qu'à attendre qu'ils le rajoutent
n°624886
Kyle_Katar​n
Posté le 23-01-2005 à 16:56:00  profilanswer
urpmi --clean
urpmi.update -a
urpmi --auto-select
n°625008
Dark_Schne​ider
Close the World, Open the Net
Posté le 23-01-2005 à 20:02:13  profilanswer
--allow-force
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°626009
Neo_t3
Posté le 25-01-2005 à 11:22:41  profilanswer
Ce matin ça remarche ;)
urpmi.update -a
urpmi --auto-select et rulez 8)
n°626682
shaddy
j'aime la gym
Posté le 26-01-2005 à 12:12:40  profilanswer
J'ai toujours un problème avec le --allow --force. Si urpmi détecte des conflits je me dis que c'est pour mon bien et qu'il vaut mieux ne pas forcer l'installation. Mais souvent sur le forum certains conseillent de passer outre. Alors voilà ce que cela donne dans mon cas:
        package prism54-firmware-1.0.4.3-1mdk is already installed
        file /usr/share/mimelnk/image/x-rgb.desktop from install of kdelibs-common-3.3.1-11mdk conflicts with file from package mandrake-mime-0.4-9mdk
        file /usr/share/services/kded/kdetrayproxy.desktop from install of kdelibs-common-3.3.1-11mdk conflicts with file from package kdetrayproxy-0.2-6mdk
        file /usr/lib/kde3/kded_kdetrayproxy.la from install of libkdecore4-3.3.1-11mdk conflicts with file from package kdetrayproxy-0.2-6mdk
        file /usr/lib/kde3/kded_kdetrayproxy.so from install of libkdecore4-3.3.1-11mdk conflicts with file from package kdetrayproxy-0.2-6mdk
Essayer de forcer l'installation (--force) ? (o/N)
A ce stade je n'ai pas encore forcé parce que je ne me rends pas compte de l'importance de ces conflits. Vous en pensez quoi?
n°626696
captcav
Posté le 26-01-2005 à 12:33:41  profilanswer
up car interessant
n°626839
shaddy
j'aime la gym
Posté le 26-01-2005 à 15:39:55  profilanswer
ok j'ai rien dis, apparemment tout est là
http://forum.hardware.fr/hardwaref [...] 3363-3.htm
  Installation
Probleme de débit entre serveur 2003 et XP proProblème d'affichage avec Suse 9.2
problème avec Mandrake linux 10Problème de Quota
Problème mount/umount linuxProbleme avec desinstalation
probleme de driverProbleme installation Suse 9.2
Probleme pour lancer firefoxProbleme Sata Urgent sur RedHat 9
Plus de sujets relatifs à : [MDK] Probleme urpmi
