739 connectés
  Linux et OS Alternatifs
  Installation
  apt-listbugs et probleme d instalations
n°341228
The Dml
pouet.. pouet ...
Posté le 18-10-2003 à 16:41:54  profilanswer
:hello: !
j ai un petit soucis qui j espere est pas trop méchant. :)
Quand je tente d installer ou de virer un programmee apt-lisbug me revoy toujour ce message :
After unpacking 483kB disk space will be freed.
Do you want to continue? [Y/n] y
/usr/sbin/apt-listbugs:153:in `require': No such file to load -- debian (LoadError)
        from /usr/sbin/apt-listbugs:153
E: Sub-process if dpkg -s apt-listbugs | grep -q 'Status: install ok installed'; then /usr/sbin/apt-listbugs -I -l -g -H misato.debian.or.jp --indexdir=/~taru/apt-listbugs/ --pin-priority=1000 apt; fi returned an error code (1)
E: Failure running script if dpkg -s apt-listbugs | grep -q 'Status: install ok installed'; then /usr/sbin/apt-listbugs -I -l -g -H misato.debian.or.jp --indexdir=/~taru/apt-listbugs/ --pin-priority=1000 apt; fi
Dmlpc2:/usr/sbin#
une idée comment résoudre ca ? car je peut plus rien installer là ... merci !  :)
n°341229
Taz
bisounours-codeur
Posté le 18-10-2003 à 16:47:49  profilanswer
faut lire avant d'installer
et utiliser reportbug
Followup 1 - #216094: /usr/sbin/apt-listbugs:153:in `require': No such file to load -- debian (LoadError)
Date: Thu, 16 Oct 2003 15:20:48 -0300
Package: apt-listbugs
Version: 0.0.33
Severity: normal
Followup-For: Bug #216094
The version 0.3.0 of dpkg-ruby does not contain the ruby1.6 version of
dpkg-ruby. Instead, it depends on libdpkg-ruby1.8, whereas apt-listbugs
requires libdpkg-ruby1.6 because of the dependency on ruby1.6.
apt-listbugs dependencies should be fixed to include libdpkg-ruby1.6 and
dpkg-ruby 0.3.0 should conflict with apt-listbugs <= 0.0.33
Cheers, Leo
-- System Information:
Debian Release: testing/unstable
Architecture: i386
Kernel: Linux spitfire 2.4.22-1-686 #1 Fri Sep 5 23:04:29 EST 2003 i686
Locale: LANG=pt_BR, LC_CTYPE=pt_BR (ignored: LC_ALL set to C)
Versions of packages apt-listbugs depends on:
ii  apt                           0.5.14     Advanced front-end for dpkg
ii  dpkg-ruby                     0.3.0      ruby interface for dpkg
ii  libintl-gettext-ruby1.6       0.11-4     Gettext wrapper for Ruby 1.6
ii  libzlib-ruby1.6               0.6.0-4    An extension library to use zlib f
ii  ruby1.6                       1.6.8-7    An interpreter of object-oriented
-- no debconf information
lines 1-31/31 (END)
n°341230
The Dml
pouet.. pouet ...
Posté le 18-10-2003 à 16:49:45  profilanswer
erf ... j ai suivit la procédure de la formation linux d alexi delatre donc j ai pas lut avant :/
merci je vais tenter de voir comment corriger ca.
Message édité par The Dml le 18-10-2003 à 16:50:36
n°341236
The Dml
pouet.. pouet ...
Posté le 18-10-2003 à 17:15:05  profilanswer
franchement je trouve pas grand chose pour savoir comment virer apt-lisbbugs.Quelqun sait comment le désactiver ?
une idée comment résoudre mon pb ?
n°341248
The Dml
pouet.. pouet ...
Posté le 18-10-2003 à 17:53:49  profilanswer
c bon j ai réussit a le virer !
n°341249
Taz
bisounours-codeur
Posté le 18-10-2003 à 17:54:47  profilanswer
y avait pas un cours d'anglais en plus ?
sinon tu e d/l apt-listbugs/libs plus anciens et voilà.
n°341256
The Dml
pouet.. pouet ...
Posté le 18-10-2003 à 18:20:08  profilanswer
oki ! merci de m avoir éclairer :) !
n°341710
Taz
bisounours-codeur
Posté le 19-10-2003 à 19:40:20  profilanswer
la soluce testée cet aprèm
voilà :oD
  Installation
Probleme d'affichage sur portable GeForce FX 4200 DebianProblème de droits : Apache, public_html et PHP
Intsllation du SDK Java sous RedHat 9: problème de PATH...gtk2, debian sid : probleme de font
probleme d'installation de materielProbléme avec kde-network pour connection internet
Problème de réseau intégré nforce2 sous redhat9[Debian Sid] Problème souris USB [Résolu]
knoppix / clavier problemeprobleme lors de l'install des nforce 2 sur MDK 9.1
Plus de sujets relatifs à : apt-listbugs et probleme d instalations
