2949 connectés
  Linux et OS Alternatifs
  Installation
  Erreur au demarrage de phpladpadmin
n°1322737
anzian
Posté le 23-10-2012 à 19:07:54  profilanswer
bonsoir à tous,
Je viens de faire une installation d'un serveur LDAP en suivant ce tuto: http://www.majorxtrem.be/2009/05/05/installation-et-configuration-dun-serveur-openldap-sous-debian/.
Après l'installation de phpldapadmin, à la connexion et en tentant de créer un user, j'ai cette suite de message.
   Automatically removed objectClass from template
 Samba: Machine: sambaSAMAccount removed from template as it is not defined in the schema
 Courier Mail: Alias: courierMailAlias removed from template as it is not defined in the schema
 Samba: Account: sambaSAMAccount removed from template as it is not defined in the schema
 Courier Mail: Account: courierMailAccount removed from template as it is not defined in the schema
  Automatically removed attribute from template
 Courier Mail: Account: uidNumber removed from template as it is not defined by an ObjectClass
 Courier Mail: Account: gidNumber removed from template as it is not defined by an ObjectClass
 Courier Mail: Account: homeDirectory removed from template as it is not defined by an ObjectClass
 Samba: Group Mapping: sambaGroupMapping removed from template as it is not defined in the schema
 Samba: Group Mapping: displayName removed from template as it is not defined by an ObjectClass
 Thunderbird: Address Book Entry: mozillaOrgPerson removed from template as it is not defined in the schema
 Thunderbird: Address Book Entry: c removed from template as it is not defined by an ObjectClass
Quelqu'un pourrait il m'aider à résoudre le problème.
Merci.
n°1322752
anzian
Posté le 23-10-2012 à 21:30:07  profilanswer
Je précise que quand je lance mon fichier ldif (ldapadd -f racine.ldif -D "cn=admin,dc=anzian,dc=local" -w anzian00040ldap1) j'ai le message :adding new entry "dc=anzian,dc=local"
ldap_add: Already exists (68).
Est-ce normal ??
n°1323308
anzian
Posté le 29-10-2012 à 19:13:46  profilanswer
Après une relecture de mes configurations j'arrive à avoir la mire d’authentification pour l'ajout de poste client. Mais j'ai un message d'erreur:
Le domaine spécifié n'existe pas ou n'a pas pu contacté.
Quelles solutions s'offre à moi ???
  Installation
Install module perl erreurApache Erreur 403 - Forbidden
Erreur à l'install de gimp en ligne de commmandeMessage d'erreur au cours de l'indexation d'un document
etrange erreur kernellenteur au démarrage de ma debian lenny
Erreur net getlocalsidLancement script au démarrage + anti crash
Gentoo - Désactiver démarrage automatique de ProftpdOpenMediaVault configuration et erreur de apt
Plus de sujets relatifs à : Erreur au demarrage de phpladpadmin
