1495 connectés
  Linux et OS Alternatifs
  Installation
  Erreur de compilation...
n°478668
jjgan
Posté le 13-05-2004 à 23:20:44  profilanswer
[jerome@localhost gtetrinet-0.7.5]$ ./configure
checking for a BSD-compatible install... /usr//bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking for dcgettext... yes
checking for gmsgfmt... /usr//bin/msgfmt
checking for xgettext... /usr//bin/xgettext
checking for catalogs to be installed...  am az ca cs cy de es eu fr ja mk ml ms nl no pl pt pt_BR ru sr sr@Latn sv uk zh_TW
checking for gconftool-2... /usr//bin/gconftool-2
Using config source xml::/etc/gconf/gconf.xml.defaults for schema installation
Using $(sysconfdir)/gconf/schemas/ as install directory for schema files
checking for pkg-config... /usr//bin/pkg-config
checking for libgnome-2.0 >= 2.0.0 libgnomeui-2.0 >= 2.0.0... Package libgnome-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `libgnome-2.0.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libgnome-2.0' found
configure: error: Library requirements (libgnome-2.0 >= 2.0.0 libgnomeui-2.0 >= 2.0.0) not met; consider adjusting the PKG_CONFIG_PATH environment variable if your libraries are in a nonstandard prefix so pkg-config can find them.
alors que
[jerome@localhost gtetrinet-0.7.5]$ locate libgnome-2
/usr/share/locale/fr/LC_MESSAGES/libgnome-2.0.mo
/usr/lib/libgnome-2.so.0.400.0
[jerome@localhost gtetrinet-0.7.5]$ locate libgnomeui-2
/usr/share/locale/fr/LC_MESSAGES/libgnomeui-2.0.mo
/usr/lib/libgnomeui-2.so.0.400.0
:??: (je compile pas souvent)
Qui suis-je ? Que fais-je ? | phpLister | Perdu ? Vous êtes ici --> *
n°478670
black_lord
Modérateur
Truth speaks from peacefulness
Posté le 13-05-2004 à 23:26:50  profilanswer
c'est libgnome-2-dev ou un truc du genre pour avoir les entêtes de fonctions
Message édité par black_lord le 13-05-2004 à 23:27:19
n°478713
jjgan
Posté le 14-05-2004 à 00:11:26  profilanswer
mandrake ça pu niveau gestion des dépendances :(
il me dit on va desinstaller "ça" pour pouvoir mettre à jour "ci", [ok] désolé j'ai besoin de "ça" pour installer "ci" :'(
Véridique :(
n°478761
black_lord
Modérateur
Posté le 14-05-2004 à 08:05:59  profilanswer
urpmq --fuzzy libgnome-2-devel
ça donne quoi ?
n°478762
Taz
bisounours-codeur
Posté le 14-05-2004 à 08:09:11  profilanswer
tu pas plutot trouver un rpm :o
n°479443
jjgan
Posté le 14-05-2004 à 20:25:21  profilanswer
ça donne quoi ?
en fait ça déconnais avec le gestionnaire de paquets graphique (MCC)
mais en ligne de commande ça roule... (j'avais jamais essayé) :)
n°479446
j_c_p
Linux user
Posté le 14-05-2004 à 20:31:41  profilanswer
Véridique :(
MDK ça fctionne très bien, faut juste savoir l'utiliser :o (c'est comme tt).
Un seul conseil : [:kahyman]
Message édité par j_c_p le 14-05-2004 à 20:32:45
n°479473
jjgan
Posté le 14-05-2004 à 21:16:22  profilanswer
désolé mais je pensais que passer par le GUI ou par la ligne de commande revenait au même...
n°479489
j_c_p
Linux user
Posté le 14-05-2004 à 21:33:36  profilanswer
non, rien ne vaut la ligne de commande  :o
Message édité par j_c_p le 14-05-2004 à 21:37:28
  Installation
Installation NAGIOS: erreur de compilationDrivers Promise: erreur à la compilation
erreur compilation mplayer[Kopete] Erreur à la compilation
[Gentoo] Erreur de compilation de KDEwarning et erreur en couleur dans la console a la compilation
message d'erreur de compilation de sourceserreur à la compilation du noyau
erreur lors de la compilation d'un kernel 2.4.20[MDK9.1] erreur de compilation GTK
Plus de sujets relatifs à : Erreur de compilation...
