1982 connectés
  Linux et OS Alternatifs
  Installation
  [DEBIAN/Sarge] problème avec MySQL [RESOLU]
n°849844
stef_dober​mann
Personne n'est parfait ...
Posté le 09-10-2006 à 11:14:41  profilanswer
j'ai installé mysql-serveur, mais il n'arrive pas à ce lancer !
voisi le message d'erreur :
Code :
  1. cobalt:/# /etc/init.d/mysql start
  2. Starting MySQL database server: mysqld...failed.
  3.         Please take a look at the syslog.
  4. /usr/bin/mysqladmin: connect to server at 'localhost' failed
  5. error: 'Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)'
  6. Check that mysqld is running and that the socket: '/var/run/mysqld/mysqld.sock' exists!
  7. cobalt:/#
voici le fichier syslog :
Code :
  1. Oct  9 09:10:08 home mysqld_safe[914]: started
  2. Oct  9 09:10:08 home mysqld[918]: ^G/usr/sbin/mysqld: Can't create/write to file '/tmp/ibjsmUwI' (Errcode: 13)
  3. Oct  9 09:10:08 home mysqld[918]: 061009  9:10:08  InnoDB: Error: unable to create temporary file; errno: 13
  4. Oct  9 09:10:08 home mysqld[918]: 061009  9:10:08 Can't init databases
  5. Oct  9 09:10:08 home mysqld[918]: 061009  9:10:08 Aborting
  6. Oct  9 09:10:08 home mysqld[918]:
  7. Oct  9 09:10:08 home mysqld[918]: 061009  9:10:08  InnoDB: Warning: shutting down a not properly started
  8. Oct  9 09:10:08 home mysqld[918]:                  InnoDB: or created database!
  9. Oct  9 09:10:08 home mysqld[918]: 061009  9:10:08 /usr/sbin/mysqld: Shutdown Complete
  10. Oct  9 09:10:08 home mysqld[918]:
  11. Oct  9 09:10:08 home mysqld_safe[920]: ended
  12. Oct  9 09:10:14 home /etc/init.d/mysql[983]: 0 processes alive and '/usr/bin/mysqladmin --defaults-file=/etc/mysql/debian.cnf ping' resulted in
  13. Oct  9 09:10:14 home /etc/init.d/mysql[983]: ^G/usr/bin/mysqladmin: connect to server at 'localhost' failed
  14. Oct  9 09:10:14 home /etc/init.d/mysql[983]: error: 'Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)'
  15. Oct  9 09:10:14 home /etc/init.d/mysql[983]: Check that mysqld is running and that the socket: '/var/run/mysqld/mysqld.sock' exists!
pourquoi j'ai ce problème d'écriture sur le /tmp ??
sur mon autre PC je n'ai eu le moindre soucis, fonctionne à merveille !
Edit : mise à jour du titre du message => STATUS == RESOLU
Message édité par stef_dobermann le 16-10-2006 à 10:04:11
Tout à commencé par un rêve...
n°849848
M300A
Posté le 09-10-2006 à 11:41:05  profilanswer
ls -l / | grep tmp
n°850063
coolben
http://www.starbusiness.fr
Posté le 10-10-2006 à 07:44:55  profilanswer
as tu de la palce sur ton pc ?
$df
n°850175
stef_dober​mann
Posté le 10-10-2006 à 13:17:04  profilanswer
j'ai un hdd de 80 GO, avec seulement linux dessus, et rien d'installer.
c'est pour faire un serveur web de teste !
je pense que ca devrais largement suffir
n°850177
wedgeant
Da penguin inside
Posté le 10-10-2006 à 13:19:24  profilanswer
Pas bien de pas répondre à la question ...  :non:
Le monsieur te demande le résultat de la commande
Code :
  1. df -m
(c'est plus mieux en Mo qu'en octets :D)
Message édité par wedgeant le 10-10-2006 à 13:19:37
Wedge#2487 @HS -#- PW: +∞ -#- Khaz-Modan/Boltiz @WoW
n°850195
coolben
Posté le 10-10-2006 à 13:48:34  profilanswer
effectivement, je ne connaissais pas
n°850280
stef_dober​mann
Posté le 10-10-2006 à 19:07:33  profilanswer
M300A a écrit :
ls -l / | grep tmp
cobalt:~# ls -l / | grep tmp
drwxr-xr-x   3 root root   4096 Oct 10 16:58 tmp
n°850281
stef_dober​mann
Posté le 10-10-2006 à 19:08:47  profilanswer
Code :
  1. df -m
voici le resultat :
Code :
  1. cobalt:~# df -h
  2. Filesystem            Size  Used Avail Use% Mounted on
  3. /dev/hda1              19G  207M   18G   2% /
  4. /dev/hda2             1.9G   20K  1.8G   1% /tmp
  5. /dev/hda4              53G  4.0K   50G   1% /www
mais c'est ce que je te disait, j'ai suffisament de place ;)
Message édité par stef_dobermann le 10-10-2006 à 19:13:16
n°850289
M300A
Posté le 10-10-2006 à 19:34:26  profilanswer
Bah oé t'as peté les droits de ton /tmp :D
chmod 1777 /tmp je crois :)
n°850341
coolben
Posté le 10-10-2006 à 23:03:52  profilanswer
Bien joué M300A
Par contre pourquoi un 1 devant 777 dans le chmod ?
n°850364
M300A
Posté le 11-10-2006 à 00:56:05  profilanswer
heuu :)
je sais plus c'est le +t je crois que c pour que les fichiers créés appartiennent toujours a l'uid qui le crée mais du coup je me demande la diff avec le comportement de base.
Quelqu'un peut me rafraichir la mémoire ? ;)
n°850514
stef_dober​mann
Posté le 11-10-2006 à 14:26:57  profilanswer
ok c'est fait
Code :
  1. cobalt:~# chmod 777 /tmp
  2. cobalt:~# ls -l / | grep tmp
  3. drwxrwxrwx   3 root root   4096 Oct 11 12:16 tmp
lancement de MySQL :
Code :
  1. cobalt:~# /etc/init.d/mysql start
  3. Checking for crashed MySQL tables in the background.
c'est pour faire quoi la derniére ligne ?
apparement ca démarre !
vérifions :
Code :
  1. cobalt:~# ps aux | grep mysql
  2. root       605  0.1  0.1  2296 1096 pts/0    S    12:19   0:00 /bin/sh /usr/bin/mysqld_safe
  3. root       641  0.0  0.1  2296 1104 pts/0    S    12:19   0:00 /bin/sh /usr/bin/mysqld_safe
  4. mysql      642  0.4  1.3 73064 13616 pts/0   S    12:19   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/tmp/mysqld.pid --skip-locking --port=3306 --socket=/var/run/mysqld/mysqld.sock
  5. root       643  0.0  0.0  1476  484 pts/0    S    12:19   0:00 logger -p daemon.err -t mysqld_safe -i -t mysqld
  6. mysql      644  0.0  1.3 73064 13616 pts/0   S    12:19   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/tmp/mysqld.pid --skip-locking --port=3306 --socket=/var/run/mysqld/mysqld.sock
  7. mysql      645  0.0  1.3 73064 13616 pts/0   S    12:19   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/tmp/mysqld.pid --skip-locking --port=3306 --socket=/var/run/mysqld/mysqld.sock
  8. mysql      646  0.0  1.3 73064 13616 pts/0   S    12:19   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/tmp/mysqld.pid --skip-locking --port=3306 --socket=/var/run/mysqld/mysqld.sock
  9. mysql      647  0.0  1.3 73064 13616 pts/0   S    12:19   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/tmp/mysqld.pid --skip-locking --port=3306 --socket=/var/run/mysqld/mysqld.sock
  10. mysql      648  0.0  1.3 73064 13616 pts/0   S    12:19   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/tmp/mysqld.pid --skip-locking --port=3306 --socket=/var/run/mysqld/mysqld.sock
  11. mysql      649  0.0  1.3 73064 13616 pts/0   S    12:19   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/tmp/mysqld.pid --skip-locking --port=3306 --socket=/var/run/mysqld/mysqld.sock
  12. mysql      650  0.0  1.3 73064 13616 pts/0   S    12:19   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/tmp/mysqld.pid --skip-locking --port=3306 --socket=/var/run/mysqld/mysqld.sock
  13. mysql      651  0.0  1.3 73064 13616 pts/0   S    12:19   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/tmp/mysqld.pid --skip-locking --port=3306 --socket=/var/run/mysqld/mysqld.sock
  14. mysql      652  0.0  1.3 73064 13616 pts/0   S    12:19   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/tmp/mysqld.pid --skip-locking --port=3306 --socket=/var/run/mysqld/mysqld.sock
  15. root       688  0.0  0.0  1536  452 pts/0    R+   12:19   0:00 grep mysql
et enfin tentative execution d'une commade SQL :
Code :
  1. cobalt:~# mysql
  2. Welcome to the MySQL monitor.  Commands end with ; or \g.
  3. Your MySQL connection id is 6 to server version: 4.0.24_Debian-10sarge2-log
  4. Type 'help;' or '\h' for help. Type '\c' to clear the buffer.
  5. mysql> show databases;
  6. +----------+
  7. | Database |
  8. +----------+
  9. | mysql    |
  10. | test     |
  11. +----------+
  12. 2 rows in set (0.00 sec)
  13. mysql> quit
  14. Bye
voila je crois que c'est bon, reste mainteant à changer le répertoire de sauvegarde des db et mettre un mot de passe au root, et mettre une écoute externe sur l'autre carte réseau pour administrer / accéder à MySQL à distance.
Merci beaucoup à tous :jap:
n°850524
wedgeant
Da penguin inside
Posté le 11-10-2006 à 14:39:19  profilanswer
Par contre, il aurait mieux valu faire tout ça avec l'utilisateur mysql et non en root ... m'enfin bon :sarcastic:
n°850588
stef_dober​mann
Posté le 11-10-2006 à 15:45:43  profilanswer
ca change quoi ?
n°850604
M300A
Posté le 11-10-2006 à 15:59:43  profilanswer
non ca change rien mais ton /tmp à toujours pas des droits correctes.
Il doit être en 1777
n°850608
wedgeant
Da penguin inside
Posté le 11-10-2006 à 16:01:45  profilanswer
bin si, un ch'tit peu, ça donne les droits en accès aux tables à tous les utilisateurs du groupe mysql, sinon faut se palucher à la main tous les changements de droit, alors qu'en le faisant directement, suffit d'ajouter les utilisateurs au groupe  :sarcastic:
n°850626
M300A
Posté le 11-10-2006 à 16:24:37  profilanswer
??? Je saisis rien à ce que tu dis, les droits mysql n'ont rien à voir avec les droits unix....
De plus mysql tourne bien sous un uid séparé puisque c'est les paquet Debian (cf ps aux)
n°850635
THRAK
- THR4K -
Posté le 11-10-2006 à 16:36:38  profilanswer
Je plussoie, il faut activer le sticky bit sur le répertoire /tmp afin de le rendre persistant :
RÉPERTOIRES PERSISTANTS
       Quand un répertoire a son bit sticky positionné, les  fichiers  de  ce
       répertoire  ne  peuvent être effacés et renommés que par le superutil‐
       isateur et le propriétaire du fichier. Sans ce bit sticky, toutes  les
       personnes  ayant  l’autorisation  d’écrire  dans le répertoire peuvent
       supprimer ou renommer des  fichiers.  Le  bit  sticky  est  couramment
       utilisé sur des répertoires comme /tmp, qui sont accessibles en écrit‐
       ure par tout le monde.
Tu devrais avoir les droits suivants sur ton /tmp - c'est une question de sécurité :
drwxrwxrwt  8 root root 2,0K 2006-10-11 16:09 tmp/
THRAK (def.) : 1) A sudden and precise impact moving from intention, direction and commitment, in service of an aim. 2) 117 guitars almost striking the same chord simultaneously.
n°850636
wedgeant
Da penguin inside
Posté le 11-10-2006 à 16:36:50  profilanswer
Ouaip, bon ... je compare à ma Slackware, forcément y'a quelques différences  :sol:
En ce qui me concerne, je sais que si je lance le script en root, il n'y a que root qui peut accèder aux tables, s'il est lancé en user mysql, alors tous les users du groupe mysql y ont accès.
Pour le daemon, normal, c'est gèré par le script rc.mysqld ;)
n°850641
M300A
Posté le 11-10-2006 à 16:47:32  profilanswer
Oui c'est pas applicable à debian ton truc :)
n°850720
stef_dober​mann
Posté le 11-10-2006 à 19:12:47  profilanswer
ok, j'applique ces droits dès que possible :)
Message édité par stef_dobermann le 11-10-2006 à 19:13:14
  Installation
[Samba] Probleme de reconnaissance de login/mdpAide pour un débutant: partitionner (résolu), partager et... Son.
Problème de charset ...ubuntu (edgy) + applies GTK1 = problème : locales + polices hideuses.
lire des mp3 sur debian en les sélectionnant sous windows ?Taille des paquets debian ?
Probleme de config de passerelle sous fedora core 4probleme avec ndiswrapper
debian sarge et kit wifi D-link DW-922 ?
Plus de sujets relatifs à : [DEBIAN/Sarge] problème avec MySQL [RESOLU]
