1394 connectés
  Linux et OS Alternatifs
  Installation
  [ MySQL Database Server ] Instalation
n°922481
casterman
Posté le 12-06-2007 à 11:58:02  profilanswer
Je cherche a installer un serveur MySQL sur un server lycos (VDS).
J'utilise webmin qui fait a peu pres tout, tout seul... J'ai mis tous les composants a jour...
Et quand je lance l'instalation, voila ce que j'ai comme "retour"...
Installation le(s) composant(s) avec la commande apt-get -y -f install mysql-client mysql-server mysql-admin ...
Reading Package Lists...
Building Dependency Tree...
The following extra packages will be installed:
  defoma e2fslibs e2fsprogs file fontconfig fontconfig-config gcc-4.1-base
  libatk1.0-0 libc6 libcairo2 libdb4.4 libdbd-mysql-perl libdbi-perl
  libfontconfig1 libfreetype6 libgcc1 libglade2-0 libglib2.0-0
  libglibmm-2.4-1c2a libgtk2.0-0 libgtk2.0-common libgtkmm-2.4-1c2a libjpeg62
  libmagic1 libmysqlclient15off libncurses5 libnet-daemon-perl libpango1.0-0
  libpango1.0-common libplrpc-perl libpng12-0 libreadline5 libsigc++-2.0-0c2a
  libstdc++6 libtiff4 libx11-6 libx11-data libxau6 libxcursor1 libxdmcp6
  libxext6 libxfixes3 libxft2 libxi6 libxinerama1 libxml2 libxrandr2
  libxrender1 lsb-base mysql-admin-common mysql-client-5.0 mysql-common
  mysql-server-5.0 perl perl-base perl-modules readline-common ttf-dejavu
  tzdata x11-common
Suggested packages:
  defoma-doc psfontmgr x-ttcidfont-conf dfontmgr gpart parted e2fsck-static
  locales glibc-doc dbishell libfreetype6-dev ttf-kochi-gothic ttf-kochi-mincho
  ttf-thryomanes ttf-baekmuk ttf-arphic-gbsn00lp ttf-arphic-bsmi00lp
  ttf-arphic-gkai00mp ttf-arphic-bkai00mp libcompress-zlib-perl tinyca
  libterm-readline-gnu-perl libterm-readline-perl-perl
Recommended packages:
  libft-perl libatk1.0-data libglib2.0-data hicolor-icon-theme libgtk2.0-bin
  libgpmg1 xml-core mysql-query-browser perl-doc
The following NEW packages will be installed:
  defoma file fontconfig fontconfig-config gcc-4.1-base libatk1.0-0 libcairo2
  libdb4.4 libdbd-mysql-perl libdbi-perl libfontconfig1 libfreetype6
  libglade2-0 libglib2.0-0 libglibmm-2.4-1c2a libgtk2.0-0 libgtk2.0-common
  libgtkmm-2.4-1c2a libjpeg62 libmysqlclient15off libnet-daemon-perl
  libpango1.0-0 libpango1.0-common libplrpc-perl libpng12-0 libreadline5
  libsigc++-2.0-0c2a libstdc++6 libtiff4 libx11-6 libx11-data libxau6
  libxcursor1 libxdmcp6 libxext6 libxfixes3 libxft2 libxi6 libxinerama1 libxml2
  libxrandr2 libxrender1 lsb-base mysql-admin mysql-admin-common mysql-client
  mysql-client-5.0 mysql-common mysql-server mysql-server-5.0 readline-common
  ttf-dejavu tzdata x11-common
The following packages will be upgraded:
  e2fslibs e2fsprogs libc6 libgcc1 libmagic1 libncurses5 perl perl-base
  perl-modules
9 upgraded, 54 newly installed, 0 to remove and 99 not upgraded.
Need to get 0B/66.3MB of archives.
After unpacking 148MB of additional disk space will be used.
... installation échouée
quelqu'un a t'il une idée pourquoi j'obtiens le "installation échouée"?  [:casterman]
PS: si ce n'est pas la bonne catégorie, mea culpa  :jap:
n°922671
fdaniel
Have you got a 27B/6 ?
Posté le 13-06-2007 à 09:55:08  profilanswer
A ta place je lancerai la commande apt-get dans un terminal pour pouvoir afficher le message d'erreur complet.
  Installation
Mysql: injection sql, addslashes?NO-ip ! DNS dynamique avec une debian "server"
[qstat] Server no responseServer home : barrière entre LAN et freebox
instalation linux après un gost Win98 (pour dual boot)Postfix 2.3.8+authentification mysql.
postfix+sasl+mysqlPostfix +MySQL +SASL2 +Postfixadmin
Snort et MySqlOptimisation Apache 2 et MySQL
Plus de sujets relatifs à : [ MySQL Database Server ] Instalation
