Mac Gyver 974 | Bonjour, problème résolu ! en fait, le fichier à télécharger ici est bien le fichier vgabios.bin du tuto (après extraction du gz bien sur), il faut juste le renommer le fichier issue de l'extraction en vgabios.bin.
J'ai maintenant un "BIOS" libre sur mon serveur sous un O.S. libre branché sur un routeur libre (DIR-825 sous DD-WRT)...
E-350D utilisateur # dmidecode # dmidecode 2.12
SMBIOS 2.7 present.
7 structures occupying 302 bytes.
Table at 0xC7FA7020.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: coreboot
Version: 4.1-170-gc6a4aae
Release Date: 07/31/2015
ROM Size: 4096 kB
Characteristics:
PCI is supported
PC Card (PCMCIA) is supported
BIOS is upgradeable
Selectable boot is supported
ACPI is supported
Targeted content distribution is supported
BIOS Revision: 4.0
Firmware Revision: 0.0
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: ASROCK
Product Name: E350M1
Version: 1.0
Serial Number: 123456789
UUID: Not Settable
Wake-up Type: Reserved SKU Number: Not Specified
Family: Not Specified
Handle 0x0002, DMI type 2, 8 bytes Base Board Information Manufacturer: ASROCK Product Name: E350M1 Version: 1.0 Serial Number: 123456789
Handle 0x0003, DMI type 3, 21 bytes
Chassis Information
Manufacturer: ASROCK Type: Desktop
Lock: Not Present
Version: Not Specified Serial Number: Not Specified Asset Tag: Not Specified Boot-up State: Safe
Power Supply State: Safe Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Height: Unspecified
Number Of Power Cords: Unspecified Contained Elements: 0
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
Socket Designation: Not Specified
Type: Central Processor
Family: Pentium Pro
Manufacturer: AuthenticAMD
ID: 20 0F 50 00 FF FB 8B 17
Signature: Type 0, Family 20, Model 2, Stepping 0
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
HTT (Multi-threading)
Version: AMD E-350D APU with Radeon(tm) HD Graphics
Voltage: Unknown
External Clock: Unknown
Max Speed: Unknown
Current Speed: Unknown
Status: Unpopulated
Upgrade: Other
L1 Cache Handle: Not Provided
L2 Cache Handle: Not Provided
L3 Cache Handle: Not Provided
Part Number: Not Specified
Core Count: 2
Characteristics: None
Handle 0x0005, DMI type 32, 11 bytes
System Boot Information
Status: No errors detected
Handle 0x0006, DMI type 127, 4 bytes
End Of Table
Edit: par contre je n'ai pas trouvé la touche pour "rentrer dans le BIOS"
Re edit: il semble qu'il n'y en ait pas coreboot avec SeaBios forment vraiment un "bios" libre très rapide, concentré uniquement sur le chargement d'O.S. (de façon rapide !)
Ce qui me convient parfaitement en fin de compte, étant donné qu'il s'agit d'un serveur en prod...
D'ailleurs je vais reflasher en modifiant une options afin qu'il n'y ait même plus les 2,5 secondes d'attentes pour faire un éventuel changement de périph. de boot (inutile vu l'utilisation serveur !)
Et sinon voici un lshw:
e-350d
description: Desktop Computer
product: E350M1 ()
vendor: ASROCK
version: 1.0
serial: 123456789
width: 64 bits
capabilities: smbios-2.7 dmi-2.7 vsyscall32
configuration: boot=normal chassis=desktop
*-core
description: Motherboard
product: E350M1
vendor: ASROCK
physical id: 0
version: 1.0
serial: 123456789
*-firmware
description: BIOS
vendor: coreboot
physical id: 0
version: 4.1-170-gc6a4aae
date: 07/31/2015
capacity: 4032KiB
capabilities: pci pcmcia upgrade bootselect acpi
*-cpu:0 DISABLED
description: CPU [empty]
product: Pentium Pro
vendor: AuthenticAMD
physical id: 4
version: AMD E-350D APU with Radeon(tm) HD Graphics
configuration: cores=2
*-memory
description: System memory
physical id: 1
*-cpu:1
product: AMD E-350D APU with Radeon(tm) HD Graphics
vendor: Advanced Micro Devices [AMD]
physical id: 2
bus info: cpu@0
capacity: 1600MHz
width: 64 bits
capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp x86-64 constant_tsc rep_good nopl nonstop_tsc extd_apicid aperfmperf pni monitor ssse3 cx16 popcnt lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch ibs skinit wdt arat hw_pstate npt lbrv svm_lock nrip_save pausefilter vmmcall cpufreq
*-pci:0
description: Host bridge
product: Family 14h Processor Root Complex
vendor: Advanced Micro Devices, Inc. [AMD]
physical id: 100
bus info: pci@0000:00:00.0
version: 00
width: 32 bits
clock: 66MHz
*-display
description: VGA compatible controller
product: Wrestler [Radeon HD 6310]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 1
bus info: pci@0000:00:01.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:28 memory:e0000000-efffffff ioport:2000(size=256) memory:f0100000-f013ffff
*-multimedia:0
description: Audio device
product: Wrestler HDMI Audio
physical id: 1.1
bus info: pci@0000:00:01.1
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm pciexpress msi bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:27 memory:f0140000-f0143fff
*-storage
description: SATA controller
product: SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode]
physical id: 11
bus info: pci@0000:00:11.0
version: 40
width: 32 bits
clock: 66MHz
capabilities: storage ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=64
resources: irq:19 ioport:2410(size=8) ioport:2420(size=4) ioport:2418(size=8) ioport:2424(size=4) ioport:2400(size=16) memory:f014b000-f014b3ff
*-usb:0
description: USB controller
product: SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
physical id: 12
bus info: pci@0000:00:12.0
version: 00
width: 32 bits
clock: 66MHz
capabilities: ohci bus_master
configuration: driver=ohci-pci latency=64
resources: irq:18 memory:f0148000-f0148fff
*-usb:1
product: SB7x0/SB8x0/SB9x0 USB EHCI Controller
physical id: 12.2
bus info: pci@0000:00:12.2
version: 00
width: 32 bits
clock: 66MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci-pci latency=64
resources: irq:17 memory:f014b400-f014b4ff
*-usb:2
physical id: 13
bus info: pci@0000:00:13.0
version: 00
width: 32 bits
clock: 66MHz
resources: irq:18 memory:f0149000-f0149fff
*-usb:3
physical id: 13.2
bus info: pci@0000:00:13.2
version: 00
width: 32 bits
clock: 66MHz
resources: irq:17 memory:f014b500-f014b5ff
*-serial UNCLAIMED
description: SMBus
product: SBx00 SMBus Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 42
width: 32 bits
clock: 66MHz
configuration: latency=0
*-multimedia:1
product: SBx00 Azalia (Intel HDA)
physical id: 14.2
bus info: pci@0000:00:14.2
version: 40
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=snd_hda_intel latency=64
resources: irq:16 memory:f0144000-f0147fff
*-isa
description: ISA bridge
product: SB7x0/SB8x0/SB9x0 LPC host controller
physical id: 14.3
bus info: pci@0000:00:14.3
version: 40
width: 32 bits
clock: 66MHz
capabilities: isa bus_master
*-pci:0
description: PCI bridge
product: SBx00 PCI to PCI Bridge
physical id: 14.4
bus info: pci@0000:00:14.4
version: 40
width: 32 bits
clock: 66MHz
capabilities: pci subtractive_decode vga_palette
*-usb:4
product: SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
physical id: 14.5
bus info: pci@0000:00:14.5
version: 00
width: 32 bits
clock: 66MHz
resources: irq:18 memory:f014a000-f014afff
*-pci:1
product: SB700/SB800/SB900 PCI to PCI bridge (PCIE port 0)
physical id: 15
bus info: pci@0000:00:15.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pci pm pciexpress msi ht normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:24
*-pci:2
product: SB700/SB800/SB900 PCI to PCI bridge (PCIE port 1)
physical id: 15.1
bus info: pci@0000:00:15.1
version: 00
width: 32 bits
clock: 33MHz
resources: irq:25 ioport:1000(size=4096) ioport:f0000000(size=1048576)
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
logical name: eth0
version: 06
serial: bc:5f:f4:af:89:54
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8168e-2.fw ip=192.168.0.100 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
resources: irq:26 ioport:1000(size=256) memory:f0004000-f0004fff memory:f0000000-f0003fff
*-pci:1
product: Family 12h/14h Processor Function 0
physical id: 101
bus info: pci@0000:00:18.0
version: 43
width: 32 bits
clock: 33MHz
*-pci:2
product: Family 12h/14h Processor Function 1
physical id: 102
bus info: pci@0000:00:18.1
version: 00
width: 32 bits
clock: 33MHz
*-pci:3
product: Family 12h/14h Processor Function 2
physical id: 103
bus info: pci@0000:00:18.2
version: 00
width: 32 bits
clock: 33MHz
*-pci:4
product: Family 12h/14h Processor Function 3
physical id: 104
bus info: pci@0000:00:18.3
version: 00
width: 32 bits
clock: 33MHz
*-pci:5
product: Family 12h/14h Processor Function 4
physical id: 105
bus info: pci@0000:00:18.4
version: 00
width: 32 bits
clock: 33MHz
*-pci:6
product: Family 12h/14h Processor Function 6
physical id: 106
bus info: pci@0000:00:18.5
version: 00
width: 32 bits
clock: 33MHz
*-pci:7
product: Family 12h/14h Processor Function 5
physical id: 107
bus info: pci@0000:00:18.6
version: 00
width: 32 bits
clock: 33MHz
*-pci:8
product: Family 12h/14h Processor Function 7
physical id: 108
bus info: pci@0000:00:18.7
version: 00
width: 32 bits
clock: 33MHz
*-scsi
physical id: 3
logical name: scsi0
capabilities: emulated
*-disk
description: ATA Disk
product: Hitachi HDP72501
vendor: Hitachi
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: A52A
serial: GEK860RB2WSYNA
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 sectorsize=512 signature=23211c6e
*-volume:0
description: Linux filesystem partition
vendor: Linux
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
version: 1.0
serial: 220746c0-3537-436c-be48-3feb1a2ed773
capacity: 32MiB
capabilities: primary bootable extended_attributes ext2 initialized
configuration: filesystem=ext2 label=kernel lastmountpoint=/boot modified=2015-07-26 15:40:03 mounted=2015-07-26 15:39:45 state=clean
*-volume:1
description: Linux swap volume
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
version: 1
serial: 11d6a0d1-cf60-4c1b-aa41-519d5685c513
capacity: 8GiB
capabilities: primary nofs swap initialized
configuration: filesystem=swap label=swap pagesize=4096
*-volume:2
description: EXT4 volume
vendor: Linux
physical id: 3
bus info: scsi@0:0.0.0,3
logical name: /dev/sda3
logical name: /
version: 1.0
serial: f59fb4e9-47e9-4cd8-91dc-a925052020a3
capacity: 141GiB
capabilities: primary journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
configuration: created=2014-07-28 16:27:19 filesystem=ext4 label=root lastmountpoint=/ modified=2015-08-03 14:44:58 mount.fstype=ext4 mount.options=rw,noatime,data=ordered mounted=2015-08-03 14:44:58 state=mounted
Message édité par Mac Gyver 974 le 03-08-2015 à 23:23:35
