2705 connectés
  Linux et OS Alternatifs
  Installation
  comment compiler gcc en 64 bits :'( [Gentoo] [Résolu]
n°1039336
trouble_fe​te
Posté le 03-05-2008 à 17:44:56  profilanswer
Bonjour, je ne parviens pas a compiler gcc (quel que soit la version) a partir d'un stage 3 amd 64, aussi bien de la Gentoo 2007.0 que 2008.0 r2, dans tout les cas en amd64 aucune version de gcc n'est compilable  :heink:
A chaque fois le message d'erreur est le même...
voici ce que ça a donné avec gcc-4.2.3 mais c'est le même message avec toute les versions de gcc que j'ai tenté de compiler:
ERROR: compile
ERROR: sys-devel/gcc-4.2.3 failed.
Call stack:
              ebuild.sh, line   49:  Called src_compile
            environment, line 4593:  Called toolchain_src_compile
            environment, line 5062:  Called gcc_src_compile
            environment, line 2919:  Called gcc_do_make
            environment, line 2749:  Called die
The specific snippet of code:
      emake LDFLAGS="${LDFLAGS}" STAGE1_CFLAGS="${STAGE1_CFLAGS}" LIBPATH="${LIBPATH}" BOOT_CFLAGS="${BOOT_CFLAGS}" ${GCC_MAKE_TARGET} || die "emake failed with ${GCC_MAKE_TARGET}";
 The die message:
  emake failed with profiledbootstrap
If you need support, post the topmost build error, and the call stack if relevant.
A complete build log is located at '/var/tmp/portage/sys-devel/gcc-4.2.3/temp/build.log'.
The ebuild environment file is located at '/var/tmp/portage/sys-devel/gcc-4.2.3/temp/environment'.
>>> Messages generated by process 27027 on 2008-05-03 16:17:21 CEST for package sys-devel/gcc-4.1.2:
ERROR: compile
ERROR: sys-devel/gcc-4.1.2 failed.
Call stack:
            environment, line 4594:  Called toolchain_src_compile
            environment, line 5065:  Called gcc_src_compile
            environment, line 2920:  Called gcc_do_make
            environment, line 2750:  Called die
 The die message:
A complete build log is located at '/var/tmp/portage/sys-devel/gcc-4.1.2/temp/build.log'.
The ebuild environment file is located at '/var/tmp/portage/sys-devel/gcc-4.1.2/temp/environment'.
>>> Messages generated by process 13450 on 2008-05-03 16:54:17 CEST for package sys-devel/gcc-4.2.3:
ERROR: compile
Call stack:
 The die message:
Message édité par trouble_fete le 03-05-2008 à 22:52:45
Tyan Tiger 200T, SDR PC 133, 1*256Mo, Bi-Tualatin 1,4Ghz, disque Maxtor 6Y080L0 IDE 80Go, FX 5200 en format PCI, modem/routeur DSL-524T, le tout sous Gentoo
n°1039339
Tom_
Posté le 03-05-2008 à 18:09:40  profilanswer
Donnes voir le résultat d'un "emerge --info". ;)
n°1039356
trouble_fe​te
Posté le 03-05-2008 à 20:20:19  profilanswer
Portage 2.1.4.4 (default-linux/amd64/2007.0/desktop, gcc-4.1.1, glibc-2.5-r0, 2.6.25 x86_64)
System uname: 2.6.25 x86_64 Intel(R) Core(TM)2 Duo CPU     E6550  @ 2.33GHz
Timestamp of tree: Wed, 30 Apr 2008 00:16:01 +0000
app-shells/bash:     3.2_p17-r1
dev-lang/python:     2.4.3-r4
dev-python/pycrypto: 2.0.1-r6
sys-apps/baselayout: 1.12.9
sys-apps/sandbox:    1.2.18.1-r2
sys-devel/autoconf:  2.61
sys-devel/automake:  1.9.6-r2, 1.10
sys-devel/binutils:  2.18-r1
sys-devel/gcc-config: 1.4.0-r4
sys-devel/libtool:   1.5.22
virtual/os-headers:  2.6.17-r2
ACCEPT_KEYWORDS="amd64"
CBUILD="x86_64-pc-linux-gnu"
CFLAGS="-march=nocona -O2 -pipe"
CHOST="x86_64-pc-linux-gnu"
CONFIG_PROTECT="/etc"
CONFIG_PROTECT_MASK="/etc/env.d /etc/gconf /etc/terminfo"
CXXFLAGS="-march=nocona -O2 -pipe"
DISTDIR="/usr/portage/distfiles"
FEATURES="distlocks metadata-transfer sandbox sfperms strict unmerge-orphans userfetch"
GENTOO_MIRRORS="ftp://ftp.free.fr/mirrors/ftp.gentoo.org/"
LANG="fr_FR@euro"
LC_ALL="fr_FR@euro"
LINGUAS="fr"
MAKEOPTS="-j3"
PKGDIR="/usr/portage/packages"
PORTAGE_RSYNC_OPTS="--recursive --links --safe-links --perms --times --compress --force --whole-file --delete --stats --timeout=180 --exclude=/distfiles --exclude=/local --exclude=/packages"
PORTAGE_TMPDIR="/var/tmp"
PORTDIR="/usr/portage"
PORTDIR_OVERLAY="/usr/local/portage"
SYNC="rsync://rsync.europe.gentoo.org/gentoo-portage"
USE="X a52 aac aalib accessibility acl acpi alsa amd64 arts avi berkdb cairo cdparanoia cdr cli cracklib crypt cups dbus dri dshow dts dvd dvdr dvdread eds emboss encode esd evo fam ffmpeg firefox fortran gdbm gif gnome gpm gstreamer gtk hal iconv ipv6 isdnlog jpeg kde kerberos lame ldap libcaca lm_sensors mad midi mikmod mmx mmxext mp3 mp4 mpeg mudflap ncurses nls nptl nptlonly nsplugin ogg opengl openmp oss pam pcre pdf perl png pppd python qt qt3 qt3support qt4 quicktime readline reflection sdl session smp spell spl sse sse2 sse3 ssl svg tcl tcpd tiff tk truetype unicode usb v4l v4l2 vcd vfwex vorbis x264 xanim xml xorg xv xvid zlib" ALSA_CARDS="hda-intel" ALSA_PCM_PLUGINS="adpcm alaw asym copy dmix dshare dsnoop empty extplug file hooks iec958 ioplug ladspa lfloat linear meter mulaw multi null plug rate route share shm softvol" APACHE2_MODULES="actions alias auth_basic authn_alias authn_anon authn_dbm authn_default authn_file authz_dbm authz_default authz_groupfile authz_host authz_owner authz_user autoindex cache dav dav_fs dav_lock deflate dir disk_cache env expires ext_filter file_cache filter headers include info log_config logio mem_cache mime mime_magic negotiation rewrite setenvif speling status unique_id userdir usertrack vhost_alias" ELIBC="glibc" INPUT_DEVICES="keyboard mouse evdev" KERNEL="linux" LCD_DEVICES="bayrad cfontz cfontz633 glk hd44780 lb216 lcdm001 mtxorb ncurses text" LINGUAS="fr" USERLAND="GNU" VIDEO_CARDS="nvidia"
Unset:  CPPFLAGS, CTARGET, EMERGE_DEFAULT_OPTS, INSTALL_MASK, LDFLAGS, PORTAGE_COMPRESS, PORTAGE_COMPRESS_FLAGS, PORTAGE_RSYNC_EXTRA_OPTS
n°1039362
trouble_fe​te
Posté le 03-05-2008 à 21:52:13  profilanswer
help :??: j'ai oublié de préciser plusieurs choses:
Cette Gentoo est toute fraiche il n'y a que le stage 3 amd64 2007.0 (j'ai testé la 2008.0 rc2 en AMD64, même problème !)
j'ai un PC en 32 bits et là bizarrement gcc s'est compilé sans problème, le problème vient donc du fait que c'est une 64 bits, d'une façon ou d'une autre le fait de vouloir compiler gcc sur une Gentoo 64 bits pose problème
apres est-ce du a mon make.conf, ou bien est-ce que gcc n'est tout simplement pas compilable en 64 bits actuellement avec -nocona je n'en sais rien je (re)débarque dans le monde du 64 bits :??:
Message édité par trouble_fete le 03-05-2008 à 21:53:58
n°1039367
trouble_fe​te
Posté le 03-05-2008 à 22:52:23  profilanswer
Oh la vache ! oh pu|ain !!!!
vous n'allez pas le croire, ça venait de la configuration du noyau ! la vache j'aurais pu chercher longtemps la chance de m'etre rappelé vaguement d'une option du noyau pouvant géner le compilateur ! c'est un truc de fou
voila l'option, regardez bien ça pourrait vous servir:
General setup  ---> [ ] Optimize for size (Look out for broken compilers!)
Ce qu'ils écrivent et que j'ai mis en gras c'est pas pour rien
autant en 32 bits ça ne m'a pas posé de soucis donc j'y ait pas fait attention, autant en 64 bits n'activez pas cette option sous peine d'empecher certaine compilation, notamment la compilation du compilateur qui est alors impossible !
pffff sauvé mais 2 jours de galère, heureusement que dans ma mémoire j'ai eu comme un flash de me souvenir de cette option du noyau !
LA VACHE !
bon et bien je recommence tout car du coup je veux recommencer l'install depuis le stage 3 de la 2008.0 r2 directement...  :sweat:
  Installation
(RÉSOLU) Photoshop sur OSX, ne s'ouvre plus ?Gentoo 2008_beta2 kde 4 only compilé via gcc-4.3 -march=core2[Résolu]
[Résolu] ddclient ubuntu 8.04[Résolu] Mail automatique + tableau html
[RESOLU] Plus d'acces à PhpMyAdmin en installant .htaccessMemory dumper ? [Résolu]
Patch pour pouvoir compiler dev-libs/boost avec gcc-4.3 ![GENTOO] purger la file SMTP et connaitre son état.
[RESOLU]OpenVPN fonctionne bien sauf que...
Plus de sujets relatifs à : comment compiler gcc en 64 bits :'( [Gentoo] [Résolu]
