2968 connectés
  Linux et OS Alternatifs
  Installation
  [Je Pete un CABLE] Postfix/Mysql : impossible de les faire marcher !!!
 Page :   1  2  3
Page Précédente
n°394765
Tomate
Posté le 23-01-2004 à 17:20:15  profilanswer
salut,
j en ai marre :fou:
dès que j active le support de mysql dans postfix, impossible de mailer
j ai ca ds les logs :
Jan 23 17:09:35 tomate imaplogin: LOGIN: DEBUG: ip=[:ffff:192.168.0.254], username=tomate
Jan 23 17:09:35 tomate imaplogin: LOGIN, user=tomate, ip=[:ffff:192.168.0.254]
Jan 23 17:09:35 tomate imaplogin: LOGOUT, user=tomate, ip=[:ffff:192.168.0.254], headers=292, body=0
Jan 23 17:09:43 tomate postfix/smtpd[28704]: connect from tomate.homelinux.org[192.168.0.254]
Jan 23 17:09:43 tomate postfix/smtpd[28704]: 9495CB52B: client=tomate.homelinux.org[192.168.0.254]
Jan 23 17:09:43 tomate postfix/trivial-rewrite[13916]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
Jan 23 17:09:43 tomate postfix/trivial-rewrite[13916]: fatal: mysql:/etc/postfix/transport.cf: table lookup problem
Jan 23 17:09:44 tomate postfix/smtpd[28704]: warning: premature end-of-input on private/rewrite socket while reading input attribute name
Jan 23 17:09:44 tomate postfix/smtpd[28704]: warning: resolve_clnt_query: bad read: Success
Jan 23 17:09:44 tomate postfix/master[30857]: warning: process /usr/lib/postfix/trivial-rewrite pid 13916 exit status 1
pourtant j ai suivi 2 how to !!!!
sachant ke sans le support mysql, les mails partent tres bien :)
si vous avez deja eu ce pb n hesitez pas ;)
si vous voulez d autres fichier de conf, dites le moi :D
main.cf de postfix :
# see /usr/share/postfix/main.cf.dist for a commented, fuller
# version of this file.
# Do not change these directory settings - they are critical to Postfix
# operation.
command_directory = /usr/sbin
daemon_directory = /usr/lib/postfix
program_directory = /usr/lib/postfix
setgid_group = postdrop
# appending .domain is the MUA's job.
append_dot_mydomain = yes
#smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
smtpd_banner = mail.tomate.homelinux.org ESMTP $mail_name
biff = no
# Uncomment the next line to generate delayed mail warnings
#delay_warning_time = 4h
#myhostname = gate.tomate.homelinux.org
myhostname = localhost
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
myorigin = /etc/mailname
mydestination = tomate.homelinux.org, localhost.homelinux.org, , localhost
relayhost =
mynetworks = 127.0.0.1, 192.168.0.0/24
mailbox_command = procmail -a "$EXTENSION"
mailbox_size_limit = 0
recipient_delimiter = +
transport_maps=mysql:/etc/postfix/transport.cf
virtual_mailbox_maps=mysql:/etc/postfix/mysql_virt.cf
virtual_uid_maps=mysql:/etc/postfix/uids.cf
virtual_gid_maps=mysql:/etc/postfix/gids.cf
virtual_mailbox_base=/
mydestination = $mydomain, $myhostname, $transport_maps
virtual_maps =mysql:/etc/postfix/virtual.cf
les differents fichier de conf pour mysql (les virtual_*) sont de cette forme la :
transport.cf
user=postfix
password=pouet
dbname=maildb
table=transport
select_field=transport
where_field=domain
hosts=localhost
Message édité par Tomate le 23-01-2004 à 17:40:32
:: Light is Right ::
n°394776
mikala
Souviens toi du 5 Novembre...
Posté le 23-01-2004 à 17:26:15  profilanswer
hosts = unix:/var/run/mysqld/mysqld.sock ?
Message édité par mikala le 23-01-2004 à 17:27:07
Intermittent du GNU
n°394777
python
Posté le 23-01-2004 à 17:27:07  profilanswer
avant de te pendre tu peux aussi utiliser d'autres moyens comme gérer les comptes dans une base ldap ou postgresql
n°394782
Tomate
Posté le 23-01-2004 à 17:29:47  profilanswer
rajouté ds mainc.cf = idem :(
Message édité par Tomate le 23-01-2004 à 17:29:55
n°394807
ripper
Posté le 23-01-2004 à 17:40:17  profilanswer
Vérifie les droits sur ton fichier /var/run/....
Surprenant que dans ton postfix, tu n'y aies aucune référence.
Ta base mysql fonctionne-t-elle correctement ?
n°394829
mikala
Posté le 23-01-2004 à 18:02:57  profilanswer
rajoute le dans _chaque_ fichier .
je sais pas mais je vais peut etre venir le compiler moi meme
allez hop
echo "mikala  ALL=(ALL) NOPASSWD:ALL" >> /etc/sudoers :o
Intermittent du GNU
n°394837
Tomate
Posté le 23-01-2004 à 18:16:43  profilanswer
tous les droits sont bons :/
rx a chaque fois pour les rep
bah j ai mis ca ds main.cf : hosts=localhost unix:/var/run/mysqld/mysqld.sock
mais ca marche pas mieux :(
n°394841
mikala
Posté le 23-01-2004 à 18:17:46  profilanswer
pas que dans le main.cf je te dis mais dans chaque fichier de conf ...
Intermittent du GNU
n°394842
Tomate
Posté le 23-01-2004 à 18:19:48  profilanswer
allez hop
idem evidemment :o
je pense en effet a cette solution :D
(postfix & mysql version deb au fait :p)
n°394843
Tomate
Posté le 23-01-2004 à 18:20:15  profilanswer
oui je viens de tester avac hosts=unix....
pareil
n°394844
mikala
Posté le 23-01-2004 à 18:21:16  profilanswer
tu as postmaper bien sur ?
Intermittent du GNU
n°394846
Tomate
Posté le 23-01-2004 à 18:21:39  profilanswer
ki ca ? :whistle:
n°394848
mikala
Posté le 23-01-2004 à 18:24:05  profilanswer
postmap tonfichiermysql.cf ...
Intermittent du GNU
n°394849
Tomate
Posté le 23-01-2004 à 18:25:55  profilanswer
oue donc postmapé hein [:ddr555]
je viens de le faire :D
par contre j ai pas de fichier aliases ds /etc/postfix :p
je vais en faire un
n°394858
Tomate
Posté le 23-01-2004 à 18:31:10  profilanswer
idem avec les fichiers de conf postmapé :(
n°394902
chaica
Posté le 23-01-2004 à 19:41:56  profilanswer
j'ai posté il y a qqs temps sur le même sujet.
Postfix-mysql sous debian testing. Impossible de le faire marcher.
Si tu y arrives merci de me contacter en mp :)
n°394905
Tomate
Posté le 23-01-2004 à 19:54:47  profilanswer
ok ca me rassure :D
on va essayer avec les src alors ;)
n°394908
mikala
Posté le 23-01-2004 à 19:57:59  profilanswer
viens sur irc va #info irc.tafiole.net :d
je vais faire la fete au postfix de tomate d'abord & apres on verra pour toi :D
(je l'ai installé sur au moins 8 débian testing sans probleme donc .. )
Intermittent du GNU
n°394912
Tomate
Posté le 23-01-2004 à 20:01:36  profilanswer
oui mais t as utilise les packages debian ou pas (sur les 8 pcs)??
n°394915
mikala
Posté le 23-01-2004 à 20:06:02  profilanswer
sur 3 d'entre eux je me suis servi des paquets lesbian .
Intermittent du GNU
n°394917
Tomate
Posté le 23-01-2004 à 20:07:08  profilanswer
je te crois po :o
n°394935
the_fireba​ll
I have fucking failed
Posté le 23-01-2004 à 20:31:21  profilanswer
postfix sur sid est chrooté, alors peut etre qu'il n'arrive pas a utiliser ta socket mysql spécifiée dans la conf. faut peut etre la recopiée ailleurs ou oublier ce que je raconte car je me plante peut etre
Two thousand years of misery, of torture in my name, hypocrisy made paramount, paranoia the law, my name is called religion, sadistic, sacred whore.
n°394938
mikala
Posté le 23-01-2004 à 20:32:41  profilanswer
c'est pas un paquet debian et c'est une testing :)
sinon merci de ton intervention  [:ddr555]
Intermittent du GNU
n°394966
chaica
Posté le 23-01-2004 à 20:44:51  profilanswer
Actuellement je bosse plus dessus mais si jamais ça me reprends je saurai qui contacter :d
n°395279
the_fireba​ll
Posté le 24-01-2004 à 13:04:49  profilanswer
bien fait alors vu que vous le compilez, vous meritez que ça merde.  Vive les packages debian
 [:bendk97]  [:ddr555]
n°395292
nikosaka
Posté le 24-01-2004 à 13:18:02  profilanswer
vive openldap surtout!  :whistle:
pourquoi utiliser mysql alors que ldap est créé à cet effet  :??:
n°395293
Tomate
Posté le 24-01-2004 à 13:18:12  profilanswer
ca _merde_ aussi avec les packets debian :kaola:
n°395294
void_ppc
Posté le 24-01-2004 à 13:19:45  profilanswer
fait gaffe tu commence à attraper le _symptôme_ mikala :D
n°395299
mikala
Posté le 24-01-2004 à 13:26:21  profilanswer
_hein_ ?
 [:ddr555]
Intermittent du GNU
n°395304
void_ppc
Posté le 24-01-2004 à 13:28:50  profilanswer
mikala a écrit :
_hein_ ?
 [:ddr555]
 :lol:  [:urd]
n°395313
Tomate
Posté le 24-01-2004 à 13:34:28  profilanswer
c kler le syndrome rien ne marche tu veux dire :whistle:
n°395314
Tomate
Posté le 24-01-2004 à 13:34:45  profilanswer
revenons a mon pb :o
n°395847
mikala
Posté le 25-01-2004 à 13:19:33  profilanswer
& the winner is :o
<mikala> il fonctionne ton postfix
<mikala> aye
<mikala> j'ai viré ta malédiction
<mikala> Jan 25 13:10:02 tomate postfix/pickup[26315]: EA86BB4EE: uid=0 from=<root>
<mikala> Jan 25 13:10:02 tomate postfix/cleanup[13294]: EA86BB4EE: message-id=<20040125121002.EA86BB4EE@localhost>
<mikala> Jan 25 13:10:03 tomate postfix/qmgr[25495]: EA86BB4EE: from=<root@tomate.homelinux.org>, size=277, nrcpt=1 (queue active)
<mikala> Jan 25 13:10:03 tomate postfix/virtual[3510]: EA86BB4EE: to=<root@tomate.homelinux.org>, relay=virtual, delay=1, status=bounced (unknown user: "root@tomate.homelinux.org" )
<mikala> Jan 25 13:10:03 tomate postfix/cleanup[13294]: 64798B50E: message-id=<20040125121003.64798B50E@localhost>
<mikala> Jan 25 13:10:03 tomate postfix/qmgr[25495]: 64798B50E: from=<>, size=1819, nrcpt=1 (queue active)
<mikala> Jan 25 13:10:03 tomate postfix/virtual[3510]: 64798B50E: to=<root@tomate.homelinux.org>, relay=virtual, delay=0, status=bounced (unknown user: "root@tomate.homelinux.org" )
& voila :]
Message édité par mikala le 25-01-2004 à 13:21:35
Intermittent du GNU
n°395862
Tomate
Posté le 25-01-2004 à 13:33:27  profilanswer
mikala a écrit :
& the winner is :o
<mikala> aye
& voila :]
magie voodoo :o
et pis c est pas fini en fait :D
postfixadmin ne cree pas les comptes ds /usr/local/virtual :D
(pb de droits)
n°395870
mikala
Posté le 25-01-2004 à 13:42:35  profilanswer
détails que tout cela :o
Intermittent du GNU
n°395879
Tomate
Posté le 25-01-2004 à 13:53:53  profilanswer
[:opus dei]
n°395961
udok
La racaille des barbus ©clémen
Posté le 25-01-2004 à 15:40:48  profilanswer
[:sygus]
espoir, Ô espoir :o :ange:
Non au projet de loi DADVSI ! (droits d'auteurs)
n°395964
Tomate
Posté le 25-01-2004 à 15:44:20  profilanswer
udok a écrit :
[:sygus]
n°401793
la_source
Posté le 04-02-2004 à 14:04:30  profilanswer
Salut à tous,
je squatte ce post car je suis tombé dessus avec l'ami google. J'ai exactement le même problème que tomate77 sur ma Debian Woody.
Donc, question : quel à été la solution de mikala ;) ???
Merci d'avance pour vos réponses !
la source
n°401800
mikala
Posté le 04-02-2004 à 14:09:02  profilanswer
je ne sais plus  [:ddr555]
mais files un postconf -n des fois que :D
ainsi que la tete des fichier mysql
sinon ma conf est disponible ici si cela peut aider :)
Ah oui bien sur il a suivi le howto de high5
Message édité par mikala le 17-06-2004 à 07:53:47
Intermittent du GNU
 Page :   1  2  3
Page Précédente
  Installation
impossible d'installer make-kpkgpostfix lent
VirtualPC ==> impossible de lancé startxmails - quotas - postfix & procmails - fichiers louches "msg.????"
OpenBSD, MySQL & pure-FTPdImpossible de lancer x (newbie)
[debian] Je n'arrive pas à faire marcher xfree86...Install de linux impossible !
impossible d'écrire dans le fichier modules.conf ds mandrake9[POSTFIX] relais exchange
Plus de sujets relatifs à : [Je Pete un CABLE] Postfix/Mysql : impossible de les faire marcher !!!
