1544 connectés
  [Topic Unique ] L'Asrock Penryn1600SLI
 Page :   1  2  3
Page Précédente
n°6161535
Olio
Posté le 17-01-2008 à 22:17:51  profilanswer
Bonsoir a tous , j'ai jeté un oeil sur cette carte qui a l'air pas mal du tout surtout niveau caractéristiques...
Moi qui cherchais une carte mere ressente avec 2 ports IDE , si celle ci était sortie un peu plus tot, je l'aurai pris avec un CPU intel...
http://img221.imageshack.us/img221/5251/asrockpenryn1600sli110dia9.jpg
LGA 775 for Intel® Core™ 2 Extreme / Core™ 2 Quad / Core™ 2 Duo / Pentium® Dual Core / Celeron®, supporting Penryn Quad Core Yorkfield and Dual Core Wolfdale processors
- Compatible with all FSB1600/1333/1066/800MHz CPUs
- Supports Hyper-Threading Technology
- Supports Untied Overclocking Technology
- Supports EM64T CPU
Chipset  - Northbridge: NVIDIA® 650iSLI (C55)
- Southbridge: NVIDIA® nForce 430
Memory  - Dual Channel DDR2 memory technology
- 4 x DDR2 DIMM slots
- Supports DDR2 800/667/533 non-ECC, un-buffered memory
- Max. capacity of system memory: 8GB*
BIOS  - 8Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- CPU, DRAM, NB, SB, VTT Voltage Multi-adjustment
 Audio, Video and Networking
Graphics  - n/a
Audio  - 7.1 CH Windows® Vista™ Premium Level HD Audio with Content Protection
- DAC with 110dB dynamic range (ALC890 Audio Codec)
LAN  - Gigabit LAN 10/100/1000 Mb/s
- Giga PHY Realtek RTL8211B
- Supports Wake-On-LAN
 Expansion / Connectivity
Slots  - 3 x PCI Express x16 slots (white @ x16 mode, yellow @ x8 mode)
- 1 x PCI Express x1 slot
- 3 x PCI slots
- Supports NVIDIA® SLI™
4 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 0+1, JBOD and RAID 5) and NCQ functions
- 2 x ATA133 IDE connectors (support 4 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x HDMI_SPDIF header
- 1 x IEEE 1394 header
- CPU/Chassis FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- SLI/XFire power connector
- CD in header
- Front panel audio connector
- 1 x USB 2.0 header (supports 2 USB 2.0 ports)
- 1 x WiFi/E header
Rear Panel I/O  ASRock WiFi_SPDIF I/O Plus
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Serial Port: COM1
- 1 x Parallel Port (ECP/EPP Support)
- 1 x Coaxial SPDIF Out Port
- 1 x Optical SPDIF Out Port
- 4 x Ready-to-Use USB 2.0 Ports
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- 1 x IEEE 1394 Port
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Prix : environ 75 euros
Je possede une Asrock sur ma 2e config , ca a l'air quand meme assez stable , alors apres il y a ceux qui disent que Asrock est une bonne marque et ceux qui disent que c'est du bas de gamme merdique...
Qu'en pensez vous , moi perso , cette carte me plait...
Message édité par Olio le 31-03-2008 à 22:35:09
n°6161556
killapig
Si t'en Reveux, Y'en Re N'a !!
Posté le 17-01-2008 à 22:28:00  profilanswer
75€ c'est quasi le prix de la Asus...qui a plus d'equipements !
Retraité du Hardware
n°6161567
Olio
Posté le 17-01-2008 à 22:31:19  profilanswer
Laquelle ???
Moi ce qui m'interresse ce sont les 2 ports IDE
n°6161571
rxtech
Je suis un mage (JCVD,WOW)
Posté le 17-01-2008 à 22:32:56  profilanswer
laquelle d'asus ??
mais je croyais que le penryn quad etait pas compatible avec le chipset nforce 650sli ???
On nous aurait menti ?
Message édité par rxtech le 17-01-2008 à 22:33:13
http://valid.x86-secret.com/show_oc.php?id=356342 - http://www.youtube.com/watch?v=HNg [...] re=related
n°6161576
Olio
Posté le 17-01-2008 à 22:35:11  profilanswer
Et pourtant cette Asrock supporte le quad et le core2duo
n°6162188
killapig
Posté le 18-01-2008 à 11:24:36  profilanswer
la p5n e sli
n°6162245
rxtech
Posté le 18-01-2008 à 11:51:28  profilanswer
ouai mais quand tu vois tout les problemes rencontré sur p5n e sli, ca fait pas envie ... Et je sais de quoi je parle, j'en ai une ...
n°6162332
Olio
Posté le 18-01-2008 à 12:32:27  profilanswer
Déja dis moi si tu trouve une P5N E sli a 75 euros...
Ca tourne plutot a 90/100 euros
Ensuite , l'Asrock a plus d'équipement comme tu dis...
Elle intégre meme le wifi et le hdmi
Avant de dire des anneries , vérifie
n°6162496
killapig
Posté le 18-01-2008 à 13:42:57  profilanswer
Oulala excuse moi grand gourou apôtre asrock tout puissant  :love:
en effet j'ai lu un peu vite
n°6162505
Posté le 18-01-2008 à 13:45:24  answer
pas mal, faut voir pour l oc et les perfs...
pas cher 75e pour une carte si complete...
Posté le 18-01-2008 à 13:45:24  profilanswer
n°6163131
Olio
Posté le 18-01-2008 à 18:46:19  profilanswer
Oula ne le prends pas mal hein :)
J'ai rien contre Asus et je suis pas un disciple Asrock , seulement tu as direct affirmer des choses fausses :)
n°6163157
jesaipacki
Posté le 18-01-2008 à 18:57:02  profilanswer
Il me semble aussi avoir lu que les Yorkfield ne seraient pas compatibles avec les chipsets 650i et 680i.
n°6163162
Olio
Posté le 18-01-2008 à 18:59:19  profilanswer
Ben j'ai pris les caractéristiques sur le site Asrock...
Et apparement elle supporte les yorkfield
n°6163183
jesaipacki
Posté le 18-01-2008 à 19:08:43  profilanswer
Sinon ASRock va proposer de plus en plus des cartes mères à base des chipsets milieu de gamme, un P35 est prévu aussi si elle n'est pas sorti.
De toute façon, niveau prix les ASRock couteront toujours moins chères que les cartes mères Asus pour ne pas concurrencer la maison mère.
Message édité par jesaipacki le 18-01-2008 à 19:09:08
n°6163193
rxtech
Posté le 18-01-2008 à 19:11:03  profilanswer
c'est juste qu il manquait un composant sur les cm a base ne nf6xxsli pour recevoir les quads ...
Je suppose que vu que cette cm vient juste de sortir, ils ont rajoute ce fameux composant ...
Et puis vu que nvidia viens de sortir les 780i et 790i, il faut bien qu ils eclusent leurs stocks de chipsets nf6 ...
n°6164143
killapig
Posté le 19-01-2008 à 10:21:34  profilanswer
Ma P5n e sli sortie debut 2007 accepte les quad depuis le debut :
http://www.asus.com/products.aspx? [...] odelmenu=1
Asrock c'est super qualité prix et fiable (une mobo morte sur une trentaine montée), le probleme c'est les bios. Apres si on n'Oc pas ça reste un tres bon choix
n°6164191
groscouic
Posté le 19-01-2008 à 11:00:23  profilanswer
[:haltias]
une petite carte qui risque de remplacer ma 939SLI32...
Pour la fiabilité, j'en ai monté 6, et pas de soucis sur 3 ans.
C'est sur apres, ce ne sera peut etre pas LA carte de l'oveclocker fou :pt1cable: , mais du moment que c'est stable.
Au niveau perf, un petit aperçu ici : http://my.ocworkbench.com/bbs/show [...] post425861
TOPIC @verclock des series 939 Asrock :)
n°6164304
rxtech
Posté le 19-01-2008 à 12:00:52  profilanswer
n°6164516
Olio
Posté le 19-01-2008 à 13:37:07  profilanswer
Ah ben tiens alors :)
Ma prochaine avec un quad ( dans 1 an )
n°6164734
philips105​s
Seal of Quality
Posté le 19-01-2008 à 15:15:23  profilanswer
Ben je me laisserai bien tenter par cette petite carte mère d'ici quelques temps. J'achète du Asrock depuis 3 générations de CPU (K7, A64, Core2) et en dehors du faux port PCIEx16 de la dernière aucun soucis de stabilité.
Merci pour l'info Olio  :hello:
n°6169948
Olio
Posté le 21-01-2008 à 19:40:02  profilanswer
De rien :)
n°6170161
Rayaki
Posté le 21-01-2008 à 21:00:49  profilanswer
des infos sur les disponibilités prochaines ? :)
n°6170483
Olio
Posté le 21-01-2008 à 23:20:30  profilanswer
J'attends aussi :)
Pour l'instant rien
n°6170746
killapig
Posté le 22-01-2008 à 08:57:18  profilanswer
Je cite
This model may not be sold worldwide. Please contact your local dealer for the availability of this model in your region.
Donc cette carte ne sera pas forcement vendue en France (comme c'est le cas pour la carte mere Asrock en P31).
A noter que plusieurs cartes mères en P35 sont référencées chez Asrock :
http://www.asrock.com/mb/overview. [...] 35-WiFi%2b
http://www.asrock.com/mb/overview. [...] 00P35-WiFi
http://www.asrock.com/mb/overview. [...] 0Twins-P35
La dernière semble aussi assez interressante
n°6170758
rxtech
Posté le 22-01-2008 à 09:10:55  profilanswer
n°6170786
killapig
Posté le 22-01-2008 à 09:37:27  profilanswer
rxtech a écrit :
La cm asrock en p31 est au catalogue rue du commerce au prix de 66 euros : http://www.rueducommerce.fr/compos [...] ntel%20P31
ah ok, dsl, j'avais regardé il y a quelques temps.
Par contre pour le même prix on a une Gigabyte...
n°6170800
rxtech
Posté le 22-01-2008 à 09:47:44  profilanswer
D'un autre cote, a 65 euros c'est dur de faire moins cher ... :lol:
n°6188426
Olio
Posté le 29-01-2008 à 12:50:08  profilanswer
n°6188545
rxtech
Posté le 29-01-2008 à 13:36:45  profilanswer
On sent vraiment la volonte d asrock de devenir une marque " a part entiere ", et non juste un constructeur de carte mere pas cheres ...
n°6191903
groscouic
Posté le 30-01-2008 à 19:09:00  profilanswer
n°6209929
groscouic
Posté le 08-02-2008 à 17:03:56  profilanswer
Preview de la carte : http://www.ocworkbench.com/2008/as [...] 0dB/g1.htm
elle m'a l'air bien sympatique...
n°6210180
Olio
Posté le 08-02-2008 à 19:29:57  profilanswer
Ma prochaine avec un bon CPU intel :) :)
n°6225371
old100
V8 Power
Posté le 17-02-2008 à 15:21:38  profilanswer
n°6225407
SWFALCON
Posté le 17-02-2008 à 15:59:28  profilanswer
je croyais que les cartes mères 650i et 680i pouvait pas supporter les nouveaux quad core yorkfield ?
https://www.ebay.fr/usr/swfalcon + http://www.priceminister.com/boutique/farainp
n°6225432
old100
V8 Power
Posté le 17-02-2008 à 16:16:14  profilanswer
Oui, d'où le titre de l'article!
n°6232780
Olio
Posté le 21-02-2008 à 11:31:37  profilanswer
n°6233133
rxtech
Posté le 21-02-2008 à 13:54:23  profilanswer
n°6233823
Olio
Posté le 21-02-2008 à 19:13:30  profilanswer
Nan du tout mais je pensais a 60/70 comme les autres cartes de chez Asrock :)
La on atteint presque 100 euros avec les frais de port :)
n°6234426
BloodyCarn​age
Posté le 22-02-2008 à 00:38:42  profilanswer
Sauf que cette carte est sensiblement moins dépassée que ce qu'asrock à l'habitude de sortir. Ici, il ne s'agit pas de recycler un chipset vieux de 4 ans qu'on a vaguement modernisé pour l'occasion. C'est un chipset récent, avec le support complet des techno actuelles, un chip son haut de gamme (pour un bidule intégré), des condo solides et un bios évolué. C'est quand même pas tout à fait la même gamme; ils ne vont pas te la vendre à prix coûtant.
n°6234481
donutshome​r
Ce qui doit être sera.
Posté le 22-02-2008 à 01:52:10  profilanswer
je  me permet de metre un lien pour mon topic sur les
Asrock chipset P15
 Page :   1  2  3
Page Précédente
Asrock 929Dual-SataII et PCI Express ?[ Topic Unique ] Origen S16V
Besoin d'avis sur position jumpers (ASROCK K7S8X)[topic Unique] HD160XT et HD160XTplus Zalman
PCI Express 8X seulement sur Asrock AM2NFG[Topic Unique]Asus Maximus Extreme: Le top du top par Asus !
Cpu athlon xp2600 reconnu à 1.15mhz sur asrock???????????Boot impossible avec ASRock K8UPGRADE NF3
Durée de garantie d'une carte mère ASROCK K8NF4G-SATA2
Plus de sujets relatifs à : [Topic Unique ] L'Asrock Penryn1600SLI
