2837 connectés
  Problème gravure DVD HP Pavillon
n°6601966
madfab
Posté le 18-09-2008 à 23:27:34  profilanswer
voilà mon problème, ça fait quelque temps et quelques dvd que je jette car je n'arrive plus à graver avec nero. La gravure se bloque et le message suivant apparait/
FABRICE
5C80001080000000005666878691
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 06/05/2002 12:01:14
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 14:54:32
NT-SPTI used
Nero Version: 7.0.0.0
Recorder:             <MATSHITA DVD-RAM UJ-850S>Version: 1.05 - HA 1 TA 0 - 7.0.0.0
 Adapter driver:      <IDE>                     HA 1
 Drive buffer  :      2048kB
 Bus Type      :      via Inquiry data (1) -> ATAPI, detected: ?
 Connected to MMC as unknown drive with class-nr : 1
 Drive is autodetected - recorder class:
CD-ROM:               <MATSHITA DVD-RAM UJ-850S >Version: 1.05 - HA 1 TA 0 - 7.0.0.0
=== Scsi-Device-Map ===
CdRomPeripheral      : MATSHITA DVD-RAM UJ-850S         atapi Port 0 ID 0  DMA: On
DiskPeripheral       : FUJITSU MHV2120BH PL            iaStor Port 1 ID 0  DMA: On
=== CDRom-Device-Map ===
MATSHITA DVD-RAM UJ-850S   E:   CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 1021MB (1046508kB)
Free physical memory: 256MB (263136kB)
Memory in use       : 74 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
18.9.2008
Compilation ISO
22:30:29 #1 Text 0 File Isodoc.cpp, Line 6410
 Iso document burn settings
 Determine maximum speed : FALSE
 Simulate                : FALSE
 Write                   : TRUE
 Finalize CD             : TRUE
 Multisession            : FALSE
 Burning mode            : DAO
 Mode                    : 1
 ISO Level               : 1 (Max. of 11 = 8 + 3 char)
 Character set           : ISO 9660
 Joliet                  : TRUE
 Allow pathdepth more than 8 directories : TRUE
 Allow more than 255 characters in path  : TRUE
 Write ISO9660 ;1 file extensions        : FALSE
22:30:29 #2 Text 0 File ThreadedTransfer.cpp, Line 525
 ReadBuffer-Pipe got 81920KB of Memory
22:30:29 #3 Text 0 File Reader.cpp, Line 124
 Reader running
22:30:29 #4 Text 0 File Writer.cpp, Line 113
 Writer E: MATSHITA DVD-RAM UJ-850S running
22:30:29 #5 ISO9660GEN -11 File Geniso.cpp, Line 3304
 First writeable address = 0 (0x00000000)
22:30:29 #6 Text 0 File Burncd.cpp, Line 3301
 Turn on Disc-At-Once, using DVD media
22:30:29 #7 Text 0 File DlgWaitCD.cpp, Line 277
 Last possible write address on media:  2298495 (510:46.45, 4489MB)
 Last address to be written:            2205231 (490:03.06, 4307MB)
22:30:29 #8 Text 0 File DlgWaitCD.cpp, Line 289
 Write in overburning mode: NO (enabled: CD)
22:30:29 #9 Text 0 File DlgWaitCD.cpp, Line 2568
 Recorder: MATSHITA DVD-RAM UJ-850S, Media type: DVD-R
  Disc Manufacturer: SONY16 - D1
  Disc Application Code: 64, Disc Physical Code: 193
22:30:29 #10 Text 0 File DlgWaitCD.cpp, Line 456
 >>> Protocol of DlgWaitCD activities: <<<
22:30:29 #11 Text 0 File ThreadedTransferInterface.cpp, Line 846
 Setup items (after recorder preparation)
  0: TRM_DATA_MODE1 ()
     2 indices, index0 (150) not provided
     original disc pos #0 + 2205232 (2205232) = #2205232/490:3.7
     relocatable, disc pos for caching/writing not required/ required, no patch infos
     -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2205232 blocks [E: MATSHITA DVD-RAM UJ-850S]
22:30:29 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1058
 Prepare recorder [E: MATSHITA DVD-RAM UJ-850S] for write in CUE-sheet-DAO
 DAO infos:
  MCN: ""
  TOCType: 0x00; Session Closed, disc fixated
  Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    4516315136, ISRC ""
 DAO layout:
  __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
        0 |  lead-in |   0 |    0x41 | 0x00
        0 |        1 |   0 |    0x41 | 0x00
        0 |        1 |   1 |    0x41 | 0x00
  2205232 | lead-out |   1 |    0x41 | 0x00
22:30:29 #13 Text 0 File SCSIPassThrough.cpp, Line 34
 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
22:30:29 #14 Phase 24 File dlgbrnst.cpp, Line 1724
 Caching of files started
22:30:29 #15 Text 0 File Burncd.cpp, Line 4129
 Cache writing successful.
22:30:29 #16 Phase 25 File dlgbrnst.cpp, Line 1724
 Caching of files completed
22:30:29 #17 Phase 36 File dlgbrnst.cpp, Line 1724
 Burn process started at 4x (5 540 Ko/s)
22:30:29 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2669
 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
22:30:29 #19 Text 0 File DVDR.cpp, Line 2469
 Recording mode: Sequential Recording Mode
22:30:29 #20 Text 0 File MMC.cpp, Line 21541
 Set BUFE: Buffer underrun protection -> ON
22:30:29 #21 Text 0 File DVDR.cpp, Line 2624
 Start write address at LBA 0
 DVD high compatibility mode: Yes
22:30:29 #22 Text 0 File Cdrdrv.cpp, Line 8385
 ---- DVD Structure: Physical Format Information (00h) ----
 Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
  Book Type: DVD-R   (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
  Disc Size: 120 mm,      Maximum Rate: <not specified> (F h)
  Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
  Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
  Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
  End Physical Sector Number of Data Area:      30000 h
  End Sector Number in Layer 0:                 0 h (LBN: FFFD0000 h, 4193920 MB)
  Data in Burst Cutting Area (BCA) does not exist
   Start sector number of the current Border-Out: 0 h
   Start sector number of the next Border-In:     0 h
  Media Specific [16..63]:
       00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00    .`...0@P...!....
       00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
22:32:27 #23 SPTI -1061 File SCSIPassThrough.cpp, Line 306
 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1061)
 Sense Key:  0x04 (KEY_HARDWARE_ERROR)
 Sense Code: 0x44
 Sense Qual: 0x00
 CDB Data:   0x2A 00 00 02 12 A0 00 00 20 00 00 00
 Sense Area: 0xF1 00 04 00 02 0F 90 0A 00 00 07 0A 44
 Buffer x09fb0000: Len x10000
 0x1D 5D C3 E0 63 11 AE 1D BA 82 BE EB 70 C7 38 35
 0x1F 06 42 20 67 FF 5C BE 0A ED 18 D5 F5 89 A8 9E
 0x3E 0C 40 E0 12 2F FC EB 5A A7 70 83 E1 03 BF F4
22:32:27 #24 CDR -1061 File Writer.cpp, Line 302
 Internal target failure
22:32:27 #25 Text 0 File ThreadedTransfer.cpp, Line 228
 all writers idle, stopping conversion
22:32:27 #26 Text 0 File ThreadedTransfer.cpp, Line 222
 conversion idle, stopping reader
22:32:27 #27 Text 0 File DVDR.cpp, Line 2866
 EndDAO: Last written address was 135839
22:32:28 #28 Phase 38 File dlgbrnst.cpp, Line 1724
 Burn process failed at 4x (5 540 Ko/s)
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 18/08/2001 06:07:32
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 30/01/2007 07:03:34
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 06/05/2002 12:01:08
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 16/08/2007 00:33:10 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Oui je sais c'est un peu long. :)
J'ai essayé de graver avec d'autres logiciel comme deepburner, la la gravure se terminait mais elle ne devait pas être de bonne qualité parce que mon lecteur divix n'arrivait pas à lire les films. J'ai aussi essayé avec easy cd creator et la ça ne marchait pas non plus
Par contre pour graver des cd, il n'y a pas de problème.
En bref j'ai besoin de votre aide. :sol:
merci d'avance.
n°6603743
Step73
Posté le 20-09-2008 à 09:53:05  profilanswer
Greveur DVD à remplacer. Il est probablement HS
n°6603767
tprince61
alea jacta est
Posté le 20-09-2008 à 10:17:13  profilanswer
Idem
n°6605454
madfab
Posté le 21-09-2008 à 11:53:47  profilanswer
Même si j'arrive à graver en moins bonne qualité avec d'autres logiciel?
ce n'est pas une question de réglages?
n°6605459
Step73
Posté le 21-09-2008 à 11:57:12  profilanswer
Moins bonne qualité... tu n'arrives pas à les lire !!!
Va sur LDLC ou RDC, ça s'achète.
n°6605505
madfab
Posté le 21-09-2008 à 12:20:14  profilanswer
Oui, je sais. mais moi g un portable.
Donc j'aurais préféré ne pas avoir à brancher un appareil supplémentaire dessus.
merci de ton aide en tout cas
n°6605599
ilien83
C'est écrit dessus ...
Posté le 21-09-2008 à 13:18:43  profilanswer
Tu n'es pas obligé de brancher un periph supplémentaire, juste remplacer celui qui est en panne.
Ceux là devraient convenir, à verifier après démontage de l'actuel.
http://www.rueducommerce.fr/compos [...] 40&prix=50
Quand tout le reste a échoué lisez le mode d'emploi
probleme surchauffe et arret pcProbleme DD externe eSata sur branchement SATA
Problème d'écran noir au lancement d'un jeux.Probleme de mémoire et d'OC
[Asus Striker II Extreme] Encore un probleme !!!probleme pour insaler xp sur un asus m70sa
Problème Nvidia 9800 GTX ?ATI Radeon HD 4870 - Probleme ecran noir et freeze pc
Probleme boitier mad-x dracula BKproblème physx
Plus de sujets relatifs à : Problème gravure DVD HP Pavillon
