3686 connectés
  Boitier
  [Topic Unique] OCZ ModXStream Pro
n°7255449
raptor3388
By my deeds I honor him...V8
Posté le 21-12-2009 à 19:15:49  profilanswer
Vu l'absence totale d'information sur les alimentations OCZ sur le forum, je pense qu'il est temps de créer un topic qui leur est dédié. Je ne dois surement pas être le seul à la posséder ici.
http://www.ocztechnology.com/images/products/accessories/b/MXSP_front_b.jpg
Specifications
500W, 600W, 700W Configurations
 OCZ PowerWhisper Technology
 Internal 135mm fan (500W,600W,700W)
 SLI™ Certified
 3 year warranty backed by OCZ's exclusive PowerSwap™ Warranty replacement program. No more endless return-for-repair loops!
Technical specifications
 150 x 160 x 86mm (W x L x H)
 ATX12V v2.2 and EPS12V
 Typical load 86% Efficiency
 80+ Certified
 Overvoltage/OverPower/Short-Circuit protection
 (.99)Active PFC
 MTBF: 100,000 hours @ 25C
500W - 700W Connectors:
 1 x 20/24-pin ATX
 1 x 8-pin CPU
 1 x 4-pin CPU
Modular Connectors:
 1 x 6-pin PCI-E
 1 x 6+2-pin PCI-E
 4 x Peripheral
 2 x Floppy
 6 x SATA
Resources
 Mechanical Drawing
 Manual
 Specification Charts
Part Numbers
 500W - OCZ500MXSP
 600W - OCZ600MXSP
 700W - OCZ700MXSP
Description
OCZ ModXStream Pro / 500~600W~700W / EZ Mod Cable Management / Active PFC
The ModXStream Pro Series is the superlative solution for driving today's gaming systems, and is NVIDIA® SLI™ certified to power dual graphics. Professional-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 135mm fan, the ModXStream Pro was engineered to be the quietest PSU available and eliminate distracting noises from your PC. 80+ Certified, featuring up to 86% efficiency at typical load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
As a gamer or case modder, modular cabling is a necessity when building a cool and orderly system. To optimize airflow and eliminate cable mazes, the ModXStream Pro is equipped with "EZMod" Technology to allow complete customization of your power system by utilizing only the cables you require.
The OCZ ModXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power. Available in configurations ranging from 400W to 700W and backed with OCZ’s 3-year “power swap” warranty, the OCZ ModXStream Pro gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
Les tests :
pour la OCZ ModXStream Pro 500W :
. Bit-tech : 8/10 http://www.bit-tech.net/hardware/p [...] u-review/7
. Overclock3d : 8.5/10 http://www.overclock3d.net/reviews [...] pro_500w/5
. Cpu3d : 8/10 http://www.cpu3d.com/review/7106-9 [...] usion.html
. Fudzilla : recommeded http://www.fudzilla.com/content/view/9562/40/1/1/
pour la OCZ ModXStream Pro 600W
. PC perspective : Silver award http://www.pcper.com/article.php?a [...] pert&pid=8
. Verdis review : 90% http://verdisreviews.com/reviews/o [...] -review/6/
. Phoronix : approved 8 / 10 http://www.phoronix.com/scan.php?p [...] _pro&num=3
. Overclockersclub : OCC bronze http://www.overclockersclub.com/re [...] 600w/7.htm
. Ocia : approved http://www.ocia.net/reviews/oczmod [...] age4.shtml
. Bjorn3d : approval http://www.bjorn3d.com/read.php?cI [...] ageID=5908
. Xtremecomputing : platinium award http://www.xtremecomputing.co.uk/r [...] 451&page=6
. Virtual-hideout : approved & recommeded http://www.virtual-hideout.net/rev [...] dex3.shtml
pour la OCZ ModXStream Pro 780W :
. Benchmarkreviews 8.75/10 http://benchmarkreviews.com/index. [...] mitstart=5
. BFR : good product http://www.bonafidereviews.com/art [...] 231&page=4
. Driverheaven : good power supply unit http://www.driverheaven.net/review [...] lusion.php
Nokytech
""La ModXStreamPro affiche un bilan intéressant pour une alimentation modulaire de 500w disponible sur le marché pour moins de 70€.Elle s’est montrée à la fois discrète et efficace tout en alliant des qualités de tension honorables."" http://www.nokytech.net/fatal1ty_& [...] html"
il ne faut pas confondre pas la ModXStreamPro avec l'ancienne ModStream qui elle n'était pas terrible http://www.pcworld.fr/article/ocz- [...] on/106181/
(merci mycks!)
Message édité par raptor3388 le 11-01-2010 à 12:21:16
n°7259473
EpinardsHa​chés
Posté le 25-12-2009 à 12:18:46  profilanswer
Je possède une 600W  OCZ600MXSP, et je la trouve bruyante, du moins au début : j'entendais clairement le ventilo de l'alim qui résonnait dans ma tour, c'était agaçant, d'aiileurs le soir au lieu de laisser tourner mon pc pour finir de télécharger des jeux, je préférais l'éteindre pour regarder tv tranquille, en silence, elle couvrait le bruit du ventirad de mon Phenom.  Et depuis une semaine, je n'entends presque plus ce bruit, oui je dis presque car parfois ce bruit revient un peu. Et depuis cette alim ne m'inspire plus confiance. Alors bien sur, je n'ai fait aucun "test technique dessus", meme pas une passe occt.
Et depuis je me "tate" pour prendre une Corsair
Message édité par EpinardsHachés le 25-12-2009 à 12:19:51
n°7259896
raptor3388
Posté le 25-12-2009 à 19:35:37  profilanswer
Bizarre, je viens de monter la mienne et on ne l'entend pas ! En tout cas elle est bien finie cette alim. Elle est peinte dans un gris anthracite métallisé.
n°7260763
EpinardsHa​chés
Posté le 26-12-2009 à 15:25:36  profilanswer
Je suis surement tombé "sur le mauvais numéro". En fait quand je joue elle ne fait pas trop de bruit, mais dés que j'arrete, les ventirads de ma tour ralentissent, l'alim est de plus en plus bruyante à en devenir agaçant. Et parfois sa ne me le fait pas.
J'ai parcouru pal mal de forums et je n'ai pas vu de mauvais retours pour cette alim, je n'ai pas eu de bol.....
Message édité par EpinardsHachés le 26-12-2009 à 15:25:48
n°7260776
Lestanquet
Posté le 26-12-2009 à 15:32:16  profilanswer
il existe des versions modulaires ?
j'adore ocz en ram, en alim je ne connais pas.
n°7260926
ash56
Posté le 26-12-2009 à 17:44:37  profilanswer
ATTENTION  : alimentation pas compatible avec certaines cartes dont la HD4890 de Sapphire !!
n°7260961
pierrotlem​aboule
Posté le 26-12-2009 à 18:09:07  profilanswer
non compatible avec les series vapor X seulement
mon topic de vente
n°7261008
EpinardsHa​chés
Posté le 26-12-2009 à 18:56:33  profilanswer
Les modxstream pro sont modulaires
n°7261715
Lestanquet
Posté le 27-12-2009 à 12:38:02  profilanswer
:lol:    :lol:  quel con je suis !
n°7272127
thym95
Posté le 04-01-2010 à 18:05:54  profilanswer
Bonjour
D'autres avis d'heureux possesseurs ?
Je suis tenté par une 600W (voir une 500w).
Mais comme j'aime bien la tranquillité, certains commentaires me font hésiter.
Eric
Feed : http://forum.hardware.fr/hfr/Achat [...] 4543_1.htm
n°7272241
jujule
Posté le 04-01-2010 à 18:51:37  profilanswer
salut a tous, je possede une 700w et j' en suis tres contant pour l' instant, les tentions sont tres stables et elle est silencieuse contrairement a un post sur la 500w qui est peut etre un peu juste pour la config.
j' espère qu' elle tiendra longtemps, meme pour mes futures configs !!!
ma config a voir dans mon profil.
n°7272512
raptor3388
Posté le 04-01-2010 à 20:55:00  profilanswer
La mienne est inaudible, j'en suis très content pour le moment.
n°7272520
wizard63
Posté le 04-01-2010 à 20:57:24  profilanswer
J'ai une SXS 600 et j'en suis très content
elle n'est pas modulaire mais ne fait pas de bruit et bonne finition (pas de gros point de colle douteux dans le boitier)
Mes ventes   Topic des Auvergnats
n°7282428
mycks
Posté le 11-01-2010 à 10:29:46  profilanswer
Hello, j'avais recherché bcp de tests sur cette alim
peux tu les intégrer au premier post stp
Nokytech
Message édité par mycks le 12-03-2010 à 09:35:25
Bonnes affaires neuves du moment (GPU,CPU,HDD,ALIM) / [Guide d'achat] Choisir sa config selon son budget / [Guide d'achat] Boitiers
n°7282616
formule3
Posté le 11-01-2010 à 13:01:34  profilanswer
Bonjour voilà j'ai eu cette alimentation de 700W pour noël , je l'ai installé , elle est bien , mais par contre pourquoi elle n'est pas compatible avec la Sapphire HD4890 Vapox-X ? Car j'envisageais a faire un CF avec ma HD4870 ....
Merci ! @@+++
n°7364530
Arslan310
Posté le 13-03-2010 à 22:10:47  profilanswer
Salut à tous, j' hésite entre la ocz modulaire 500w et la silverpower(seasonic) 500w, laquelle prendre et pourquoi ?merci
Feedback1:http://forum.hardware.fr/hfr/AchatsVentes/Feedback/feed-back-arslan310-sujet_486576_1.htm
n°7364557
tangozoulo​u0
Posté le 13-03-2010 à 22:33:04  profilanswer
la silverpower est une seasonic  avec 2-3 trucs en moin pour le prix alors que l'ocz contient des composant équivalent à ceux d'une noname , malgré de bonne perf
regarde là :
http://forum.canardpc.com/showthread.php?p=2741699
http://www.hardocp.com/article/2008/...power_supply/9
n°7368759
Arslan310
Posté le 17-03-2010 à 16:48:37  profilanswer
ok merci bien donc go silverpower :jap:
n°7437512
pieuvre
Moi... j'en ai huit !
Posté le 11-05-2010 à 13:58:11  profilanswer
salut des avis d 'utilisateur sur la ModXStreamPro 600W ?
n°7551439
-flanker--
Posté le 28-08-2010 à 16:02:40  profilanswer
je suis en train de monter ma première config avec le modèle 500W.
Pour le moment elle est inaudible, même boitier ouvert. Cependant, je dirais que certains cables sont un peu courts (pour ma part, impossible de passer le ATX_12V par derrière la carte mère µATX dans mon boitier antec mini)
Message édité par -flanker-- le 07-09-2010 à 22:27:29
n°7551626
-flanker--
Posté le 28-08-2010 à 18:04:44  profilanswer
UP?
n°7552148
shenzo95
Youtube : shenzo le kaiser
Posté le 29-08-2010 à 10:28:59  profilanswer
j'ai le modèle 700 W et j'en suis satisfait
Dieu n'existe pas désolé .......! alors arrêtez de lui demander pardon . ma chaine youtube http://www.youtube.com/user/shenzo952?feature=mhee
n°7554218
bluedragon​38
Posté le 30-08-2010 à 17:00:30  profilanswer
Pourquoi ce topic ce trouve dans la categorie = boitier ?
n°7566035
raptor3388
Posté le 07-09-2010 à 22:08:34  profilanswer
Bonne question, j'ai peut-être mal cliqué dans le menu de catégories lorsque je l'ai créé.
n°7990906
Kazuya M
Posté le 28-07-2011 à 18:23:48  profilanswer
Salut ! Manque de pot je viens de recevoir une ModXstreamPro 600W et j'ai une... 4890 VAPOR-X !!!  :sweat:
Et ça marche pas, la carte graphique ventile à fond dès le départ sans s'arrêter et l'écran ne s'allume pas...
Pfff, jamais j'aurais imaginé qu'une série de cartes graphique soient incompatible avec une alim...  :heink:
Mais comment c'est possible ?
J'ai plus qu'à remettre ma Seasonic 430W S12 II qui marche très bien avec mais commence à faire du bruit en jeu depuis que je suis passé sur un core i5 2400...
www.kazcorporation.com : homecinema, Hi-Fi, multimedia et DIY.
n°8050503
kevin9610
Posté le 20-09-2011 à 09:05:56  profilanswer
Bonjour.
Alors, petit feed-back. J'ai reçu ma 600w il y a 2 semaines, et déjà HS  :fou:
A vide, elle démarre sans problème, mais une fois reliée à la carte mère, plus rien.
Je précise avant tout, le proc a 1 mois, ainsi que la RAM, la CG a 1 semaine (GTX 560 ti), et la CM 1 mois également.
De plus, pour être certain, j'ai rebranché une Heden 560w [:jiejie999], et ça tourne.
Voilà, j'avais hésité entre plusieurs marques à l'achat, les autres étant principalement Corsair et Seasonic, le choix sera moins dur la prochaine fois!
n°8265071
raptor3388
Posté le 02-04-2012 à 00:21:53  profilanswer
Après plus de deux ans d'utilisation, mon alim vient de lacher sans aucune raison, l'ordi étant en veille...
J'ai entendu un grand "clac", avec une odeur de cramé venant de l'alim...j'éspère une chose c'est qu'elle n'a pas embarqué d'autres composants, surtout les DD. Elles sont garanties 3 ans, donc SAV...si je retrouve les factures.
Pfff, je suis un peu deg' là. Avant çà j'utilisais une Advance depuis six ans :/ Et là je passe à une alim de marque et elle me lache en à peine deux ans et trois mois.
Portfolio - 1984 Trans Am - 1974 Formula 400 - 1979 Mustang  - 1987 Corvette
n°8265081
NaTaS46
Posté le 02-04-2012 à 00:57:42  profilanswer
Je profite de ce topic pour faire un petit feedback :
J'ai une OCZ Mod X Stream Pro 500 Watts depuis deux ans maintenant.
Je l'avais achetée car grosse promo dessus à ce moment là et je n'en suis pas déçu!
Ma config est plutôt silencieuse (3 BeQuiet SilentWings USC en 140mm et un push/pull de Alpenföhn en 120mm sur mon Antec Kuhler 620) et je n'entends pas l'alim, même sur des sessions de jeu!
Je n'ai évidemment pas de tests ou mesures poussés à vous soumettre, mais je me contente de penser à toutes ces Corsair CX430 qui sifflaient sur le forum ;)
Pour info ma config actuelle:
CM : Asus M5A97
Ram : Corsair Vengeance CAS9 2x4 Go
Proco : Amd Phenom IIx4 965 BE
CG : Asus HD6950 2048Mo DCUII
SSD : Crucial M4 128 Go (tout neuf de ce week-end)
DD : Seagate Barracuda 1To 7200tpm (idem)
+ les ventilos et ventirad mentionnés ci-dessus, le tout monté dans un Cooler Master CM690II
Résultat : PC à 3 mètres de mon lit inaudible la nuit et ne dépassant pas 56° CPU et 60° GPU en burn, je suis heureux :)
n°8266992
raptor3388
Posté le 03-04-2012 à 21:01:10  profilanswer
En effet, elle est (était...) inaudible, pas de sifflement, ventilo très silencieux..
Quelqu'un peut m'expliquer la démarche du SAV chez OCZ ? C'est la première fois qu'un composant me lache...
Si jamais elle a embarqué d'autres élements du PC, vous pensez que OCZ pourrait faire un geste commercial ? C'est difficile à prouver, mais il y a de quoi être en colère, surtout si c'est le disque dur de stockage qui a pris.
Message édité par raptor3388 le 03-04-2012 à 21:02:45
n°8271620
raptor3388
Posté le 08-04-2012 à 23:25:26  profilanswer
J'ai testé mon ordi avec une autre alim (la ModXStream Pro 500W de mon frère), et elle a bien fait son travail, tous les composants marchent. Les disques durs sont tous deux à 100% dans CrystalDiskInfo. Ca m'embête quand même car j'ai beau avoir une vingtaine d'alims en stock, aucune n'a de connecteur 8 broches pour carte mère, et les plus récentes sont des...Heden :/ Je vais éviter ^^
Go SAV...
Message édité par raptor3388 le 08-04-2012 à 23:27:00
n°8280638
arkhos01
Posté le 17-04-2012 à 22:06:51  profilanswer
Bizarrement j'ai moi meme une ModXStream Pro 600W et une HD4890 Vapor-x de chez Sapphire et ca marche niquel alors que d'apres vous c'est incompatible.
Aucun problème avec l'alim et elle est très silencieuse.
Message édité par arkhos01 le 17-04-2012 à 22:08:26
n°8283415
apsilon
Posté le 20-04-2012 à 12:38:59  profilanswer
pareil que arkhos01 j'avais avant une hd4890 vapor-x avec la mxs pro 600w et aucun soucis je l'ai changé maintenant contre une 560ti tf2 msi et c'est toujours nickel , et cette alimentation est silencieuse
n°8537669
raptor3388
Posté le 05-12-2012 à 15:41:44  profilanswer
Ils ont été sympa au SAV de OCZ, normalement on est sensé expédier le produit dans les 30 jours après avoir reçu le RMA, sauf que je n'ai vraiment pas eu le temps depuis Avril, et j'ai quand même pu l'envoyer beaucoup plus tard. Heureusement car la garantie finit dans dix jours !
Est-ce que les derniers modèles ont des condensateur de meilleur qualité ? Ceux que je pouvais voir à l'intérieur étaient des Teapo...il y a pire mais ça reste pas terrible.
Message édité par raptor3388 le 05-12-2012 à 15:41:53
n°8562752
raptor3388
Posté le 27-12-2012 à 20:40:12  profilanswer
J'ai reçu l'alim de remplacement, c'est tout simplement une nouvelle ModXStream Pro en boite scellée.
n°8686396
Zouhir93
Posté le 11-04-2013 à 19:36:43  profilanswer
sorry pour le déterrage :o mais j'aurais besoin des certains cables de l'alim, incomplet chez moi, j'ai du en perdre pendant le temps :o
si quelqu'un en aurait à donner :jap:
n°9744553
linnoa
Posté le 23-02-2016 à 16:16:45  profilanswer
Je déterre un peu le topic car je recherche une deuxième paire de connecteur pci-e 6/8 broches pour passer à un SLI de 970.
Cependant, je ne retrouve plus les câbles supplémentaire de l'alimentation et je souhaitais savoir où je pourrai trouver ceux-ci. Je ne sais pas si ce type de cable sera compatible  car je ne sais pas si ce type de produit est compatible: http://www.amazon.fr/SilverStone-S [...] 4CWEAYM7TH
L'alim est: http://www.materiel.net/alimentati [...] 41866.html
Au pire, je passerai par des adaptateurs SATA ==> PCI-E mais je me suis dit que le mieux serait d'utiliser les rails de l'alimentation prévus à cet effet non ?
Merci d'avance
Message édité par linnoa le 23-02-2016 à 16:40:14
  Boitier
Question CRUCIAL : OCZ SLI-READY ou BALLISTIX TRACER ?[Topic Unique] [Alim] Thermaltake Toughpower XT
[Topic Unique] Intel i3/i5/i7 clarkdale 32nm igp inside dispo nowP5Q PRO impossible installer systeme
éternelle question cartes Pro Vs GamerClavier non reconnu lors du boot sur disque XP Pro SP2
[Topic unique] APACER SSD A7 TURBO 64 GO (premiers benchs à chaud)
Plus de sujets relatifs à : [Topic Unique] OCZ ModXStream Pro
