Extrait (if you don't understand, I'll translate):
Power connectors: standard ATX 2.2 (24 pins, you can plug a regular 20-pin connector, but you had better avoid using such powerful modern components as top PCIE video cards. Otherwise, you should use an additional connector that will be described below), 8-pin EATX12V connector to power a processor (you can plug the standard 4-pin ATX12V connector (providing no less than 13 A for Pentium 4/EE and no less than 16 A for Pentium D/EE). PSU with an 8-pin connector may be required for future processors), 4-pin (peripheral) additional connector in case of a PSU with a 20-pin connector (mandatory for SLI mode)
