3716 connectés
  Boitier
  [Topic Unique] Fractal Define XL & MINI orienté Silence
 Page :   1  2  3  4  5  6  7  8  9  10  11  12  13
Page Précédente
n°7679179
william95
Avançons à reculons
Posté le 30-11-2010 à 09:25:04  profilanswer
http://www.fractal-design.com/img/fractallogo.gif
Fractal nous sort enfin sa solution boitier grande tour compatible avec toutes les CG niveau longueur
Disponibilité prévue janvier 2011 en 2 versions
Define XL Black Pearl
http://www.fractal-design.com/img_prod/FD-CA-DEF-XL-BL_1_1.jpg
Define XL Titanium Grey
http://www.fractal-design.com/img_prod/FD-CA-DEF-XL-TI_1_1.jpg
Extérieur :
http://www.fractal-design.com/img_prod/FD-CA-DEF-XL-TI_1_2.jpg
http://www.fractal-design.com/img_prod/FD-CA-DEF-XL-TI_1_3.jpg
http://www.fractal-design.com/img_prod/FD-CA-DEF-XL-TI_1_4.jpg
Intérieur :
http://www.fractal-design.com/img_prod/FD-CA-DEF-XL-TI_2_1.jpg
http://www.fractal-design.com/img_prod/FD-CA-DEF-XL-TI_2_1_1.jpg
http://www.fractal-design.com/img_prod/FD-CA-DEF-XL-TI_2_2.jpg
http://www.fractal-design.com/img_prod/FD-CA-DEF-XL-TI_2_3.jpg
http://www.fractal-design.com/img_prod/FD-CA-DEF-XL-TI_3_3.jpg
http://www.fractal-design.com/img_prod/FD-CA-DEF-XL-TI_4_1.jpg
Information produit :
http://www.fractal-design.com/?vie [...] =2&prod=55
Cooling system
    * 2x 140mm fans (one 140mm included, one optional) with removable and washable filters, in the front. Recommended for intake of air.
    * 1x 120mm fan optional with removable and washable filter, in the front. Recommended for intake of air.
    * 1x 180mm fan included in the top of the case. Recommended for exhaust of air.
    * 1x 140mm fan included in the rear of the case. Recommended for exhaust of air.
    * 1x 120/140mm fan optional in the side of the case. Recommended for intake of air.
Specifications
    * 4x 5,25” bays, 1x 5,25” to 3,5” converter included
    * mini-itx, micro ATX, ATX and E-ATX motherboards
    * 10x HDD trays. 4x HDD trays in the HDD cage in the main chamber. This HDD cage is removable and rotatable. (Space ~330mm with HDD Cage and without ~480mm) 6x HDD trays in the lower HDD chamber. These HDD cages are fixed.
    * A total of two 140mm fans and one 180mm fan included. Front 140mm fans are mounted with removable, washable filter. A fan controller is included, for mounting in one of the rear expansion slots.
    * Pre-fitted with dense noise absorbing material in both side panels.
    * ModuVent™ feature, allowing the user to choose between an optimal low noise level, having the cover mounted or optimal airflow by removing the cover and mounting a fan for intake.
    * Case size (WxHxD): 232x560x561.3mm
    * Net weight: 17.95kg
Test :
Cowcotland : http://www.cowcotland.com/articles [...] place.html
Présentation Vidéo Define XL Titanium Grey : http://www.youtube.com/watch?v=nUZbDiwXYJo
Prix : 132€
http://www.magicpc.fr/composants/b [...] =BZ7572379
http://www.ldlc.com/fiche/PB00107968.html
http://www.ldlc.com/fiche/PB00107967.html
http://www.opium-pc.com/catalog/pr [...] 810f249d88
Define Mini
http://www.cowcotland.com/images/news/2010/12/Define_Mini_1.jpg
http://www.cowcotland.com/images/news/2010/12/Define_Mini_2.jpg
Specifications
    * 6x 3,5 inch HDD trays, compatible with SSD!
    * 2x 5,25 inch bays, with 1x 5,25>3,5 inch converter included
    * On top of front panel: 2x USB2, 1x USB3 and Audio I/O
    * No PSU included (removable filter below PSU)M/B compatibility: Mini ITX and Micro ATX
    * M/B compatibility: Mini ITX and Micro ATX
    * 4+1 expansion slots with sleek white painted brackets
    * Supports graphic cards with lengths up to ca 260mm when removable HDD-bay is in place
    * Supports graphic cards with lengths up to ca 400mm when HDD-bay is removed
    * Supports CPU coolers with height of ca 165mm
    * Supports PSU's with a depth of maximum circa 170mm, when using bottom 120/140mm fan location. When not using the bottom 120mm fan location, the case supports also longer PSU's, typically 200-220mm.
    * Case size (WxHxD): 210x395x490mm
    * Net weight: 9,50 kg
Message édité par william95 le 22-01-2011 à 16:13:18
MY FEEDBACK HERE
n°7679183
christophe​212
Posté le 30-11-2010 à 09:29:14  profilanswer
Ah bon le R3 ne permet pas toutes les longueurs de cartes graphiques ??
n°7679204
william95
Avançons à reculons
Posté le 30-11-2010 à 09:55:43  profilanswer
Et non puisque la cage des HD n'est pas extractable comme sur le Define XL, de mémoire c'est 29cm le max sur R3
(a moins de vouloir jouer du dremel bien sur mais bon...)
L'avantage du Define XL permettra de ne pas se soucier de la longueur des CG (33 cm avec cage et 44cm sans)
Message édité par william95 le 30-11-2010 à 10:58:01
MY FEEDBACK HERE
n°7679316
Theutheu
Posté le 30-11-2010 à 11:38:34  profilanswer
Test du R3 XL
http://www.cowcotland.com/news/232 [...] place.html
Je sais, on ne me remerciera jamais assez ... | | | http://www.fun-fairplay.org
n°7705047
luxy
Posté le 16-12-2010 à 23:14:00  profilanswer
grande hésitation entre le R3 et le XL
ces boîtiers sont vraiment superbes, pas seulement dans la beauté, mais surtout dans la conception !!  [:clooney15]
O/C carte graphique Ati avec Ati Tray Tools
n°7705445
pegaz86
Le gras c'est la vie
Posté le 17-12-2010 à 10:49:11  profilanswer
faudrait voir les Perf et le bruit avec un ventilateur sur le coté.
Profil D3
n°7705461
zorro51
Posté le 17-12-2010 à 11:02:10  profilanswer
Fractal s'est quand même pas mal aidé des Antec P180 (on va dire qu'il reprend 70% de la conception des P180) ! Faut voir la qualité des plastiques en plus ! Certains ont été décus par la qualité... du Fractal.
n°7705954
fkasztel
Posté le 17-12-2010 à 16:54:05  profilanswer
Le P180 a de belles finitions mais l aménagement intérieur est naze (je trouve) vu sa taille ses 6 emplacements HDD sont une grosse blague
n°7706017
zorro51
Posté le 17-12-2010 à 17:40:27  profilanswer
Je parlais surtout de l'extérieur du boitier.
n°7706070
3rik
Casse-toi pauv' con
Posté le 17-12-2010 à 18:16:26  profilanswer
AMHA, une fois la porte ouverte la façade est très laide :/
VDS Signature 850W, Koss SB49, Ventilos ||| Feed-Back ||| Sauve toi, sauve moi, et tu sauras où l'acheter le courage
n°7706837
william95
Avançons à reculons
Posté le 18-12-2010 à 10:37:10  profilanswer
En même temps, la porte n'est pas faite pour rester ouverte lol ^^
MY FEEDBACK HERE
n°7713172
mansonic
luv' maille paycay
Posté le 22-12-2010 à 18:07:08  profilanswer
up pour des gens qui postent leur photals!
si tu lis ça alors c'est que tu surveilles pas ta petite soeur...
n°7722959
william95
Avançons à reculons
Posté le 30-12-2010 à 11:15:57  profilanswer
n°7725251
theBride_
Strobist
Posté le 31-12-2010 à 14:57:54  profilanswer
Le Define Mini :love:
Pourquoi Lian-Li ne nous a pas pondu un truc similaire avec son A04 :o
Une date pour la disponibilité ?
128DB - Instagram - Ventes
n°7725714
Big Blue
Live/Psn/Nid legeantbleu
Posté le 31-12-2010 à 17:38:23  profilanswer
dispo, chez fractal ? [:rofl]
[VDS] Steam Controller comme neuf, 35€ fdpin.
n°7725778
fkasztel
Posté le 31-12-2010 à 18:10:59  profilanswer
suis sûr chez Fractal il y a des anciens de 3D Realms
ils te montrent de belles photos, font des annonces, mais on ne voit jamais rien en magasin ^^
n°7728018
lepiaf37
Posté le 02-01-2011 à 15:47:17  profilanswer
+1 pour le define mini
http://reparationsonosplay5.free.fr/
n°7728327
tifaya972
Heuuu... proute !?
Posté le 02-01-2011 à 18:29:14  profilanswer
+1 pour le mini aussi!
n°7734169
fabiendc
Posté le 05-01-2011 à 11:51:11  profilanswer
a quel prix est le mini, quand et ou peut on l'acquérir ?
n°7734228
william95
Avançons à reculons
Posté le 05-01-2011 à 12:25:29  profilanswer
aucune info pour l'instant
MY FEEDBACK HERE
n°7735932
morbax
Posté le 05-01-2011 à 22:59:18  profilanswer
personne n'a acheté le xl pour nous faire un pti retour :)
n°7737545
mannequi
Posté le 06-01-2011 à 19:51:34  profilanswer
:bounce:  :bounce:  :bounce:
+ 1 pour  un retour svp, ma carte bleu frétille  :D  :D
ce qui m'intéresse c'est le silence, est il vraiment présent sur ce boitier ???
n°7737901
luxy
Posté le 06-01-2011 à 23:09:50  profilanswer
il semblerai bien que oui, au dire des tests
n°7739224
elchicanos​38
Aie Carramba
Posté le 07-01-2011 à 18:34:34  profilanswer
Salut à tous,
Voilà hier j'ai craqué pour l'achat d'un Fractal XL en couleur Titanium Grey en remplacement de ma "vieille" tour Antec Sonata car les composants de ma config commençait à être à l'étroit.
Le poids de la bête est assez impressionnant.
Pour les montages des composants :
- quelques soucis avec mon Rhéobus Akasa AK-FC-03 impossible de fermer la porte avant du boitier si je l'installais "normalement" (à cause des boutons du rhéobus) mais bon j'ai réussi à enfoncer le rhéobus un peu plus dans la cage 5,25 et là la porte se ferme.
- La peinture des plateaux amovibles pour les disques durs pas terrible : quand on sort un plateau amovible et que l'on le réintroduit, le plateau amovible frotte sur les côtés et la peinture blanche s'enlève et on se retrouve avec plein de particules blanche dans le boitier. Vraiment pas terrible !  :fou:
- Problème avec la conception au niveau des fixations port PCI soit c'est mon boitier qui a un défaut de fabrication ou soit je ne sais pas monté une configuration (j'opterai plutôt pour la première hypothèse).
Je possède 2 cartes PCI : lorsque je les installe correctement dans les ports de la carte mère et qu'ensuite j'essaie de les fixer au boitier gros problème d'alignement. Si j'essaie de les fixer correctement, je constate un problème d'alignement et je dois dois forcer : j'ai mes cartes PCI qui sortent à moitié des ports de la carte mère . Obliger de fixer mes cartes un peu je ne sais comment. Pour info, ma carte mère est bien fixé (entretoises hexagonales sont bien utilisés).
Je suis un peu déçu de la qualité du boitier. Sur mon Antec Sonata tout rentrait nickel, pas de problème avec mes cartes PCI, pas de problème de peinture avec cage de disque dur.
Message édité par elchicanos38 le 07-01-2011 à 19:11:12
n°7739394
william95
Avançons à reculons
Posté le 07-01-2011 à 20:02:01  profilanswer
tu pourrais nous faire des photos éventuellement des problèmes précités ?
MY FEEDBACK HERE
n°7739408
elchicanos​38
Aie Carramba
Posté le 07-01-2011 à 20:07:08  profilanswer
Demain je prendrais quelques photos avec mon APN et je posterai tout ça.
n°7739415
william95
Avançons à reculons
Posté le 07-01-2011 à 20:10:39  profilanswer
ok merci, pense à faire un mail au sav fractal avec les photos, généralement ils ont un bon sav
MY FEEDBACK HERE
n°7739732
mannequi
Posté le 07-01-2011 à 23:27:52  profilanswer
merci pour le retour. :jap:  ;)
qu'as tu comme carte graphique ( la mienne est fixée sur 2 slot) alors vu ton pb sa m'intrigue  :??:
et question bruit ventillo a fond sa donne quoi ??
je ne vois pas de bouton reset sur les photos : il est absent ??
merci encore  :D
Message édité par mannequi le 07-01-2011 à 23:32:14
n°7740501
luxy
Posté le 08-01-2011 à 13:54:30  profilanswer
mannequi, le bouton reset est derrière la porte ... on en a pas besoin tous les jours
n°7740534
mannequi
Posté le 08-01-2011 à 14:07:45  profilanswer
entièrement d'accord avec toi, mais c'est comme tout, le jour ou tu en as besoin c'est mieux de l'avoir. ;)
n°7740567
elchicanos​38
Aie Carramba
Posté le 08-01-2011 à 14:18:20  profilanswer
Le bouton est derrière la porte mais il est vraiment très petit et pas facile d'accès.
Très difficile à trouver avec une faible luminosité.
http://img84.imageshack.us/img84/8913/fractalxl3.jpg
Message édité par elchicanos38 le 08-01-2011 à 15:04:04
n°7740595
elchicanos​38
Aie Carramba
Posté le 08-01-2011 à 14:28:29  profilanswer
merci encore  :D
Comme carte graphique, je possède une HIS Radeon HD 4850 Ice Q4 qui est double slot également mais je n'ai rencontré aucun problème avec celle-ci mais j'ai observé le problème avec mes cartes PCI.
Message édité par elchicanos38 le 08-01-2011 à 14:28:58
n°7740618
elchicanos​38
Aie Carramba
Posté le 08-01-2011 à 14:36:23  profilanswer
Comme promis voici quelques photos prises avec mon APN des problèmes rencontrés avec mon boitier Fractal XL.
Alors les premières photos, la carte est bien fixée au panneau arrière du boitier mais la carte est par contre mal enfoncée dans le port PCI impossible de l'enfoncée plus (essais avec 2 cartes PCI différentes et avec n'importe quels port).
http://img824.imageshack.us/img824/7905/fractalcartefixee.jpg
http://img692.imageshack.us/img692/4307/fractalcartefixee2.jpg
Les Photos suivantes montrent la cartes PCI enfoncée le plus possible dans le port PCI mais impossible de la fixée au panneau arrière du boitier
http://img338.imageshack.us/img338/4813/fractalactu.jpg
http://img535.imageshack.us/img535/6407/fractalactu2.jpg
http://img41.imageshack.us/img41/1267/fractalcartefixee2port.jpg
Et dernière photo : les petites particules de peinture qui s'enlève suite à extraction puis réintroduction d'un plateau amovible de disque dur
http://img407.imageshack.us/img407/7005/peinturek.jpg
Message édité par elchicanos38 le 08-01-2011 à 15:00:50
n°7740633
Big Blue
Posté le 08-01-2011 à 14:44:11  profilanswer
Pas de soucis avec mon R3 pour les pci et la peinture qui s'effrite :jap:
Mais j'ai d'autre problème aussi ...
Message édité par Big Blue le 08-01-2011 à 14:44:22
n°7740879
luxy
Posté le 08-01-2011 à 17:09:17  profilanswer
n°7741369
TriniTa_91​1
Posté le 08-01-2011 à 20:49:33  profilanswer
@ elchicanos38
On dirait un pb de hauteur d'entre-toises, sur lesquelles tu vises la CM, celles de gauche plus basse que celle de droites. (cela peut-être une piste).
Le reste parait bien aligné, trou pour fixer la carte fille.
n°7741465
elchicanos​38
Aie Carramba
Posté le 08-01-2011 à 21:39:10  profilanswer
TriniTa_911 a écrit :
@ elchicanos38
Il faudrait que je vérifie mais bon ca me semblerait bizarre car j'ai utilisé les entretoises fournies avec le boitier.
Avant de mettre la carte mère dans le boitier, j'avais bien vérifier que les entretoises étaient bien serrées.
Par contre, j'ai pas vérifié si les entretoises avaient la même taille mais la logique voudrait que oui.
Message édité par elchicanos38 le 08-01-2011 à 21:46:27
n°7741494
Mouais5
Posté le 08-01-2011 à 21:53:17  profilanswer
J'ai monté un R3 la semaine passé, c'était mon premier montage de P.C. et j'étais un peu trop enthousiaste. En plus fractal est vachement chiche en doc, fin bref...
J'ai donc visé la mobo sur le boitier avec les mauvaises vis, j'avais exactement le même soucis que toi avec les cartes PCI. J'ai finalement prit le temps de réfléchir et j'ai trouvé sur la boite des vis les infos pour savoir quelles vis utiliser... j'avais mis les "entretoises" sur les rack de HDD  :D
Bref sinon mon R3 RAS, bruit des DD bien étouffé, cable management ok (toujours le pb des caoutchoucs qui se barrent), pis il est beau  :love:
n°7742587
TriniTa_91​1
Posté le 09-01-2011 à 14:21:17  profilanswer
C'est quoi la taille max des ventirad dans le Define XL ?
Est-ce que le Thermalright HR02 passe ?
http://www.izipik.com/images/201101/09/gjq8vxgnv3mbm0urs4-hr02.jpg
n°7743546
elchicanos​38
Aie Carramba
Posté le 09-01-2011 à 20:43:55  profilanswer
http://www.izipik.com/images/20110 [...] 4-hr02.jpg
L'info était dispo dans le premier message :
"  * Supports CPU coolers with height of ca 165mm "
Page Précédente
  Boitier
VENDS - Boitier LIAN LI PC-6089 Black 70€Quelel baisse de perf lecture avec un boitier externe pr lecteur BR?
boitier disque du externe : Icy Box IB-330StU3- Bquel boitier choisir
conseil pour boitier pc pas cherConseil upgrade d'une tour 2008
Boitier HP => Tt Element TLED d'activité HDD du boitier désespérement éteint + BIOS capricieux !
ASUS M4A88TD-V et ventilateur perpendiculaire au boitier
Plus de sujets relatifs à : [Topic Unique] Fractal Define XL & MINI orienté Silence
