1207 connectés
 Page :   1  2  3  4  5  6  7
Page Suivante
[ Annuaire ] - Tests & comparatifs d'alimentations [ Abandonné ]
n°7609100
ditche_GN
Posté le 14-10-2010 à 10:13:45  profilanswer
Cougar GX G600
n°7610970
PitOnForum
thèse, antithèse et synthèse
Posté le 15-10-2010 à 18:06:24  profilanswer
certains PSU Cougar ont des capacités de rebondissement surprenants...
Message édité par PitOnForum le 15-10-2010 à 18:06:36
DOSSIER PC & COMPOSANTS SILENCIEUX: PC + composants, bruit et silence - solutions
n°7623120
ditche_GN
Posté le 23-10-2010 à 20:11:51  profilanswer
n°7627770
chriskenob​y
Que la force soit avec vous
Posté le 26-10-2010 à 18:08:59  profilanswer
Yop, une mise a jour du test de 59Hardware sur les alims 500W......
http://www.59hardware.net/dossier/ [...] 922/0.html
l origine de la Musique Electro (Pop,Techno,....) c est eux..  http://www.kraftwerk.com/
n°7639312
ditche_GN
Posté le 02-11-2010 à 23:33:48  profilanswer
n°7639558
PitOnForum
Posté le 03-11-2010 à 08:51:12  profilanswer
The new Seasonic X-Series 560 W is an impressive power supply. During our tests it achieved efficiency always above 87%, peaking 90.3%, voltages very close to their nominal values (3% regulation instead of the traditional 5% regulation), and extremely low noise and ripple levels. On top of that, due to its highly overspec’ed components, we could easily pull 730 W from it with efficiency still above 87%. This is remarkable.
The only “problem” with this power supply is its price, too close to the X-Series 650 W’s price. With only USD 10 difference between them, you may want to buy the 650 W model instead to get a higher labeled wattage (even though the 560 W model is capable of easily delivering 650 W) and, mainly, two extra video card cables. Or, if you decide to see this in a different angle, you may want to buy the 560 W model and save USD 10, with the only drawback of having only two video card cables. It’s your call.
impressionnant
Message édité par PitOnForum le 03-11-2010 à 08:51:58
n°7642572
ditche_GN
Posté le 04-11-2010 à 20:00:50  profilanswer
n°7643314
ditche_GN
Posté le 05-11-2010 à 11:50:35  profilanswer
n°7646335
ditche_GN
Posté le 07-11-2010 à 13:11:50  profilanswer
n°7683236
Tous
http://www.annuaire-guitare.fr
Posté le 03-12-2010 à 08:21:17  profilanswer
Tiens, je rajoute la liste des principaux constructeurs d'alims, si j'en ai oubliées, merci de signaler ;)
http://www.corsair.com/products/power_supplies.aspx
http://www.ocztechnology.com/produ [...] anagement/
http://www.seasonicusa.com/NEW_X-s [...] 60-850.htm
http://www.nzxt.com/new/product.ph [...] s&series=3
http://www.silverstonetek.com/prod [...] p?area=usa
http://www.enermax.com/home.php?fn [...] ct_a&lv0=1
http://xfxforce.com/en-gb/products [...] ition.aspx
http://zalman.co.kr/ENG/product/Ca [...] orySecond=
http://www.antec.com/Believe_it/pr [...] eries=NDk=
http://www.akasa.com.tw/update.php [...] erformance
http://www.amacrox.com.tw/english/ [...] aspx?pid=1
http://www.be-quiet.net/be-quiet.n [...] iteLang=fr
http://www.coolermaster.fr/category.php?category_id=22
http://www.coolmaxusa.com/productCenter.asp
http://www.cougar-world.de/en/prod [...] upply.html
http://www.delta.com.tw/product/ps/sps/sps_main.asp
http://www.epowertec.com/powersupplies.html
http://www.fsp-group.com.tw/englis [...] &proid=541
http://www.mushkin.com/Power-Supplies/Volta.aspx
http://www.mushkin.com/Power-Supplies/Joule.aspx
http://www.pcpower.com/products/power_supplies/
http://www.sin-tek.com/
http://www.tagan.com.tw/
http://fr.thermaltake.eu/product_p [...] C_00000020 (et sa 1500W)
http://www.topower.com.tw/product/product.htm
http://www.ultraproducts.com/appli [...] ?CatId=106
http://www.zumaxpower.com/products/product.htm
http://www.cwt.com.tw/english/2_pr [...] p?MainID=1
http://www.enhance.com.tw/e_products.htm
http://www.hipro.com.tw/product.php
http://www.seventeam.com.tw/product_index.php
http://www.gigabyte.fr/products/li [...] s=51&ck=41
http://www.lian-li.com/v2/en/produ [...] l_index=10
http://www.vantecusa.com/en/product/index/18
http://www.xigmatek.com/product_list.php?categoryid=4
http://www.nesteq.net/gb/products/powersupplies.html
Pas trouvé de site pour celles-ci :
SilverPower de maxpoint des seasonic à bas prix...
Hiper... qui aurait fermé ses portes ?
Sparkle ???
Les Cartes Son Haute Fidélité pour mélomanes, musiciens, audiophiles, la MAO, le cinéma,...
n°7684195
Tous
Posté le 03-12-2010 à 20:03:44  profilanswer
chriskenoby a écrit :
Petite News...........
http://img243.imageshack.us/img243/1274/alim.png
Bien joué ! Bravo Marc !!!
Reste plus qu'à se porter partie civile et attaquer ceux qui vendent Heden en France pour dédommager tous les pauvres gens arnaqués !!! Et saisir la DGCCRF... Ils font quoi eux au fait ?
Message édité par Tous le 03-12-2010 à 20:06:58
Page Suivante
pb win32k.sys ... ram hs ? voici mes tests..ALIMENTATIONS DELL!!! Que de bonnes nouvelles
Comparatifs des cg des 3 ou 4 dernières annéesComment faire démarré 2 alimentations en même temps
[ Topic Unique ] Alimentations HIPER , les ptit' nouvelles qui roxChoix des processeurs dans les tests de cartes grapiques.
Le PC se fige. Mes tests, mes conclusions ... vos avisDisque dur externe Seagate bruyant ! Objectivité des tests Tom's HW ?
Comparatifs[Alimentations] Alim >500W et silencieuse: impossible?
Plus de sujets relatifs à : [ Annuaire ] - Tests & comparatifs d'alimentations [ Abandonné ]
Hit-Parade
