2702 connectés
  Looking for a graphics card suggestion to fit my current build
n°10518914
daryldixon
Posté le 02-02-2019 à 06:50:36  profilanswer
Hi folks, Looking to get a graphics card suggestion to fit my current build (detailed below). The graphics card listed in the build has been largely unavailable/overpriced for awhile and I'm upcoming movies netflix free trial free netflix hoping to find a comparable alternative.
This build would be used for gaming. Ideally >80fps-1440p-highest-graphics-settings-possible gaming. I'm hoping for a build that can deliver amazing quality NOW, and solid quality over the next 4-6 years.
Budget for the graphics card is probably capped at around 900 but I'd entertain suggestions above that. Also I'd be ordering from within the USA.
Message édité par daryldixon le 06-02-2019 à 05:59:09
n°10518992
MeanBalls
Posté le 02-02-2019 à 11:16:59  profilanswer
So what is your current build?
For 900 usd/euros and your requirements I would suggest an RTX2080, but it also depends on your current CPU.
Message édité par MeanBalls le 02-02-2019 à 11:21:37
n°10519009
zonka
x58 forever!
Posté le 02-02-2019 à 11:34:58  profilanswer
Funny you found your way around here (there are zillions of US forums :p)
Whats your build indeed?
n°10519010
MeanBalls
Posté le 02-02-2019 à 11:36:47  profilanswer
+1   ;)
SMART : Current pending sector countBesoin d'avis pour mon premier build (principalement pour jouer)
1er build, plz helpGeforce 940M + intel HD graphics 520 sur TravelMate P278-MG
conseil Build Cougar QBX mini itxJe viens de build mon PC mais plusieurs problèmes
Les vidéos ne fonctionnent pas avec intel uhd graphics 630Vérification cohérence build PC
Premier build, problèmes en cascade [SOLVED]Avis nouveau build
Plus de sujets relatifs à : Looking for a graphics card suggestion to fit my current build
