7123 connectés
 Page :   1  2
Page Suivante
Les catalyst 3.2 bride les 9700 (Pro) !!!
n°2296345
problemati​kman
Posté le 15-03-2003 à 20:04:58  profilanswer
et la modif marche avec les drivers 3.3 ??????
ps: desolé si g rien compri et que je pose un question à la con
 :na:  :na:  :na:  :na:  :na:  :na:
n°2296352
barbarella
Posté le 15-03-2003 à 20:09:42  profilanswer
avant de porter des jugements définitifs, il faut s'interroger et voir s'il n'y a pas d'autres voix sur les forums parlant d'ATI a moins de rechercher absolument un axe du mal chez ATI et faire du bushisme. Donc ceux qui veulent aller se battre contre le mal devront attendre la résolution 3.3 des catalyst :D.
provenance Rage3D.com
http://www.rage3d.com/#1047579924
Quote:
Our close buddy Terry Makedon, or better known amongst our forums as "Catalyst Maker", has shed some light on what to expect with the soon to be released driver set, Catalyst 3.2!
Here's a small breakdown of what's going on.
1) People are very anxious for the 7.84 set which is known as CATALYST 3.2 and want to know when it will be posted.
2) People want to know what to expect in this driver set.
3) People are wondering about RADEON9800 performance paths and when the RADEON9700 users will get them.
I have decided to address these for the inquiring minds.
1) Shortly
2) Stuttering observed in the 9700 series is all I want to mention right now. Stay tuned for more!
3) Seems like lately on the forums a developer has spoiled my upcoming surprise about the CATALYST drivers for RADEON. We found some pretty decent performance boosts while we were developing the 9800 drivers. They were scheduled for release with the first set of 9800 drivers (CATALYST 3.2) and we were planning on letting them out for the 9700 cards once we'd tested them thoroughly. Which in this case is CATALYST 3.3
When we launched CATALYST we committed that we would keep adding new features, bug fixes and performance boosts across the range, but we're dead serious about our stability and quality testing and won't compromise that for anything. The CATALYST drivers are the most stable on the market, and that will not change. So for now CATALYST 3.2 will have not have the amazing performance boosts for the 9700, CATALYST 3.3 will! Furthermore since I like you guys so much I will plan on bringing in the CATALYST 3.3 posting day from our typical release cycle, and have it posted as soon possible
However, since the CAT(!) is out of the bag - you now know that 9700 owners will have a great performance boost with the CATALYST 3.3 posting. We're not just number one - we'll now be #1 (RADEON 9800 PRO), #2 (9800) and #3 (9700 PRO).
2003 the year of CATALYST!
Message édité par barbarella le 15-03-2003 à 20:11:31
n°2296382
WORF
"Engage !" J. L. Picard
Posté le 15-03-2003 à 20:25:23  profilanswer
J'ai une petite question :
Je possede une Radeon 9700pro et une carte mère P4g8x.
J'ai donc eu besoin de désactiver l'option "Fastwrite" dans
l'onglet Smartgart des options d'affichage de la carte pour résoudre de gros pb de stabilite.
Après avoir réinstallé le driver Catalyst 3.2 et le panneau de contrôle(après remplacement du fichier ati2mtag) le panneau Smartgart n'est plus accessible. Mes questions sont donc les suivantes :
Fastwrite est il toujours désactivé (je ne pense pas) ?
Et si non, comment accéder à nouveau à ce panneau ?
Catalyst 3.2 résoud t il les pb de Freeze avec cette carte mère ?
PS : la manip fonctionne en tout cas, Smoothvision 2.1 ok !
n°2296610
Nichlas
Posté le 15-03-2003 à 22:35:26  profilanswer
J'ai un pb . En fait tout à l'air de vouloir fonctionner sauf que l'ordi me dit qu'il a du démarrer en VGA par défaut car il ne peut charger mon pilote , car soit disant il est pour une version inférieur de Windows !
Message édité par Nichlas le 15-03-2003 à 22:35:47
" je ne sais guère ! "
n°2296631
Nichlas
Posté le 15-03-2003 à 22:45:00  profilanswer
Voilà comment je fais :
- Je copie le fichier dans le répertoire :
X:\3D Prophet RADEON Series Drivers\Driver\XP_INF\BX_05091
- je supprime le fichier indiqué
- je vais dans ajout/suppression de prgramme , et je déinstalle " Control Panel " et " ATI Display Driver " .
- Je redémarre
- lorsque j'arrive sous le bureau , je fais gestionnaire de périphérique puis mettre à jour les pilotes .
- je sélectionne " installer à partir d'une liste ou d'un emplacement selectionné " .
- je coche " Ne pas chercher , je vais choisir le pilote à installer "
- je clique sur " disque fourni... "
- je selectionne mon fichier CX_05162.inf
- je lance puis redémarre
        C'est bien comme ça ?
Message édité par Nichlas le 15-03-2003 à 22:46:17
n°2296657
Escher
Posté le 15-03-2003 à 22:57:43  profilanswer
J'ai le même problème que toi : disparition de l'onglet SmartGart qui gère le FastWrite et l'AGP x8...
n°2296842
WORF
Posté le 16-03-2003 à 00:36:56  profilanswer
A propos de l'option Fastwrite d'ailleurs, est ce que  quelqu'un sait exactement à quoi ça sert ? :)
(à part créer des emmerdes avec certaines cartes mères) :pt1cable:
n°2296863
akhnotpier​rot
Internaute
Posté le 16-03-2003 à 00:56:40  profilanswer
et ben chez oim c pareil
disparu...
je c pas si le fast c réactivé mais battlefield tourne au poil !!!!
[HFR] AKHnoT [:akhnotpierrot] Membre de la team [HFR] BattleTeam
n°2297443
WORF
Posté le 16-03-2003 à 13:02:17  profilanswer
disparu...
Je confirme.
Dès lors que les nouveaux drivers sont réinstallés avec ou sans modification du fichier ati2mtag, le fastwrite est activé par défaut.
n°2297484
Nichlas
Posté le 16-03-2003 à 13:25:58  profilanswer
C'est dangereux ou pas ?
 Sinon je gagne 170 points  ;)
n°2297488
Lao
Posté le 16-03-2003 à 13:30:07  profilanswer
mais est ce qui ya vraiment une diffference avec l'utilisitaion du FSAA ety de l'aniso (style sous unreal ou splinter etc).
car c bien beau qui est ecrit smoothvision 2.1 dans le control panel mais ca veus rien dire
n°2297551
cybermatos
Posté le 16-03-2003 à 14:03:45  profilanswer
 :jap:  +1
n°2297595
fenhrir
Posté le 16-03-2003 à 14:29:05  profilanswer
Le fastwrite est une option apparu avec l'AGP 4X, ca permet a ton CPU d'envoyé directement les infos à ta carte graphic sans passer par la mémoire. C'est donc plus rapide. Logiquement tu as de meilleur perf avec le faswrite mais est ce que c'est vrai ?? je ne peux pas te le dire etant donné que ma machine est en cours de montage.
n°2297687
ratur
Posté le 16-03-2003 à 15:06:22  profilanswer
Est-ce que cette manip marche aussi avec les radeon 9500 (pro) ?
n°2297740
John_AmD
Hippi-Kai-He
Posté le 16-03-2003 à 15:27:25  profilanswer
Bon les mecs j'ai essayé la méthode avec rivathunder, et bien ca ne marche pas du tout bien au contriare: j'ai perdu 1000 pts a 3dmark2001se et 400 pts a 3dmark03. Merci à la restauration systéme.
Au niveau du fichier à télécharger et à installer, donnez le lien afin de le telecharger car je l'ai pas trouvé sur google le ati2mtag
n°2297896
WORF
Posté le 16-03-2003 à 16:23:00  profilanswer
Voici le raccourci young padawan !   ;)
Le fichier est sur cette page...
http://www.pc-tests.com/news/index.php3#id_news_635
n°2297977
Clarkent
Musclor le shérif de l'espace
Posté le 16-03-2003 à 17:04:24  profilanswer
Un des membres de notre Forum nous a fait par de son experience sur les carte graphique ATI et voila ce qu'il nous apprend :
Les pilotes Catalyst 3.2 brident les Radeon 9700 (pro ou pas) pour eviter qu'elle soient aussi performante que les 9800 (pro ou pas)
ils sont supers sur d eux :D, ca pourrait absolument pas venir de bug ou autre, non non ati a fait ca pour que sa 9800 soit plus performante que ca 9700 :D.
d 'ailleurs ati a bridé ses 9700 a des frequences inferieures a une 9700pro tout ca pour que la 9700 pro soit plus performante :D.
il me semble aussi avoir lu que c etait des optimisations qui n etaient pas encore validé pour la 9700 mais bon :D.
"PAR LE POUVOIR DU CRÂNE ANCESTRAL, JE DETIENS LA FORCE TOUTE PUISSANTE".
n°2297995
ratur
Posté le 16-03-2003 à 17:13:53  profilanswer
J'ai fait la manip sur mon hercules 9500 pro
j'ai eu aucun probleme pour l'install mais il me met toujours smoothvision II
quelqu'un a une idée ?
n°2298581
ggeforce
Avec des si je coupe du bois !
Posté le 16-03-2003 à 21:38:20  profilanswer
http://perso.wanadoo.fr/ggeforce/sv2.JPG
donc si j'ai sa je pence que sa marche
en + j'ai gagner 100pts a 3dmark2003 [:xp1700]
http://perso.wanadoo.fr/ggeforce/r9700pro.JPG
et comme on peut le voire avec les new drivers 3.2 il diferanci les puces  :jap: ,
il met r9700pro  :D
pas comme avent 9500/9700 series !!!!  :sarcastic:  :whistle:
Message édité par ggeforce le 16-03-2003 à 21:40:09
Feedback
n°2298594
mobyfab
The power of dreams.
Posté le 16-03-2003 à 21:43:54  profilanswer
ah smieu ça !
n°2298717
barbarella
Posté le 16-03-2003 à 22:47:20  profilanswer
il met r9700pro  :D
heu,
tu joues avec les param texture et mip map au mini ? tu sais au -dessus de 200 fps y a pas trop de diff :D. Plus sérieusement pour quelle raison ?
n°2299056
ggeforce
Posté le 17-03-2003 à 08:19:28  profilanswer
Barbarella a écrit :
heu,
non c'etais au mini car je venais de faire 3dmark2003  [:xp1700]
si non je joue tout a font  :na:
Feedback
n°2299172
kokofiolo
Posté le 17-03-2003 à 10:26:55  profilanswer
Et pour les 9500 Pro, ça marche aussi???
n°2299186
John_AmD
Hippi-Kai-He
Posté le 17-03-2003 à 10:33:47  profilanswer
Lut tous, alors j'ai réussi la manip et j'ai bien smothvision 2.1 et j'ai une augmentation de performances à 3dmark03  de +100 pts mais pas a 3dmark2001se bizarrement.
Maintenant je vais vous exprimer mon sentiment sur cette affaire et je vais critiquer le titre provocateur de ce topic:
1°)Je me rappelle d'io y a qq jours que clubic.com avait interviewé le PDG d'ATI. Il en ai sortie que les catalystes 3.2 allaient bientôt sortir sans augmentation de perf mais plutôt en corrigeant des bugs, et que les catalystes 3.3 allaint eux portaient réellement des performances.
2°)Dire qu'ATI bride artificiellement les catalystes 3.2 au niveau des drivers afin que la radeon 9800pro soit plus puissante que la 9700 pro s'est complétement stupide car la pluspart des tests de la 9800 pro ont été basé sur les catalystes 3.1. Je penses plutôt que le fichier que nous avons téléchargé provient vraisemblament des prochains catalystes 3.3
3°)Au niveau du smothvision 2.1, je vais vous donner un exemple. Ce n'est pas parce que sur le compteur de votre voiture est marqué à 200Km/h que le moteur monte jusqu'à 200km/h. En d'autres termes pour ce qui n'aurait pas compris, ce n'est pas parce que c'est marqué smothvision 2.1 avec la radeon 9700 pro (ou meme les autres R300) que cette carte le gére.
Moralité, il faut être critique sur les informations que  nous lisons. NE SOYONS PAS COMME CES AMERICAINS GOBEURS D'INFORMATIONS PROPAGANDES PROVENANS DE LOBBIES INTELLO-MEDIATIQUE.
Bien le bonjour :jap:
n°2299189
lagaffe
pas toujours gaffeur ;-)
Posté le 17-03-2003 à 10:34:14  profilanswer
y a rien pr debrider ma radeon 9000?
parce que je sens que ca rame ds les jeux
je suis deja dehors
n°2299226
Gazette
Posté le 17-03-2003 à 10:46:52  profilanswer
Tu as raison a mon avis on a ete les pigeon dans l affaire car on a tester une parti de leur future driver (gratuitement)
Comme si une bande de programmeurs pouvais augmenté les performance d une cg dont la complexité et l architecture sont connu que de ati que ce soie stable et que ca marche en plus.
J espere que les perf avec les 3.3 serons un pe plus au rendez vous qu avec les 3.2 mod.
Parce que chez moi il y a un gain pixel shader gain pour lobby gain dragotic mais perte sur le 1er 3fps.
Smoothvision n est peut etre qu un log pour un proco de cg et que cela peut evolué.
Sur ceux je vais me programmé les catalyst 4.0 underground warez warez et pi me faire un pti bench.:D
n°2299247
John_AmD
Hippi-Kai-He
Posté le 17-03-2003 à 10:56:37  profilanswer
LOL et ben moi j'ai déjà 2 ans en avance sur toi car je suis en train de rivaler avec ma poubelle le futur R500 :D
Bon ok je sors
n°2299249
WORF
Posté le 17-03-2003 à 10:56:57  profilanswer
Quoi qu'il en soit, Smoothvision 2.1 ou pas, nos chers amis d'ATI ont intérêt à arranger ce probleme de "Fastwrite" qui fait planter allègrement la machine sur les cartes mères p4g8x...(et d'autres apparemment)
Et aux dernières nouvelles j'ai constaté avec amertume que ce bug n'est toujours pas résolu avec Catalyst 3.2.  :fou:
Peut être est ce plutôt un pb de BIOS d'ailleurs, je ne sais pas...Grumph !
n°2299257
John_AmD
Hippi-Kai-He
Posté le 17-03-2003 à 11:03:03  profilanswer
Je pense plustot prob de bios, va sur le site ATI.com et va sur ATI Crew pour ce genre de prob hardware. Tu remplis un formulaire, ta bécame, quels pilotes etc... et il te réponde meme en français.
Sinon ma radeon 9700pro marche avec ma KT3 Ultra avec chipset Via et ma A7N8X deluxe avec chipset Nforce2 avec fastwrtie activé
n°2299262
Erkul
Posté le 17-03-2003 à 11:04:26  profilanswer
Ouaip, moi avant j'avais une NF7-S et gros problèmes avec le fastwrite...maintenant j'ai une a7v8x et pu de blème
->bios CM et po CG
n°2301157
romje
Posté le 17-03-2003 à 21:21:53  profilanswer
il met r9700pro  :D
Message édité par romje le 17-03-2003 à 23:29:15
n°2301226
lolo92
Posté le 17-03-2003 à 21:43:34  profilanswer
ici il y a les drivers omega 2.4.07a fait à partir des catalyste 3.2 avec modification du SMOOTHVISION 2.1 et surtout avec l'onglet SmartGart de rajouter
pour désactiver le fastwrite
http://www.omegacorner.com/
n°2302756
ggeforce
Posté le 18-03-2003 à 16:37:56  profilanswer
moi je l'ai d'origine l'onglet SmartGart  :whistle:
Feedback
n°2308421
mahir
Posté le 20-03-2003 à 22:15:57  profilanswer
+190 points sous 3d mark 2003
terrible
n°2309434
ggeforce
Posté le 21-03-2003 à 13:15:27  profilanswer
moi je l'ai virer
sa me faisait ramer a ut2003  :heink:  :sweat:
Feedback
 Page :   1  2
Page Suivante
Help, recherche Radeon 9500 Pro pas chèrebine installer catalyst ?
Asus a7v8x(kt400) + Club3D radeon 9700 = misson impossible??Pbleme sortie TV avec radeon 9700
drivers catalyst 3.2 et SmartGard ?? help !Qui a essayé de transformer sa 9700 en 9800 avec rivaturner ???
La 9800 PRO, elle sort quand ???Blocage au reboot avec P4G8X Deluxe et Hercules 9700 PRO 128 Mo !
HELP! Saphirre 9500 Pro bugge quand j'installe les drivers
Plus de sujets relatifs à : Les catalyst 3.2 bride les 9700 (Pro) !!!
