1797 connectés
  ATI Tools : L'overclocking intelligent ? UPDATE 12/1/05 => version .23
 Page :   1  2  3  4  5  6  7
Page Précédente
n°2961432
Tangzzz
Posté le 22-01-2004 à 12:34:01  profilanswer
Cet utilitaire présente la possiblité de détecter les fréquences maximum supportées par la carte sans qu'il y ait des artefacts, et ce grâce à la présence d'un mode de recherche des artefacts intégré directement dans le programme.
http://www.techpowerup.com/atitool/screen1.gif
Nouvelle version 0.0.23
Telechargement :
http://www.techpowerup.com/atitool/ATITool_0.0.23.exe
Changelog :
    * Added memory timings editor support for R430 and R480
    * From this version on the installer will be able to detect a running ATITool instance
    * Button "Mem" is now disabled when no ATI card detected
    * "Delta of 0 in 0 (- avg). No errors for mm:ss.xx" message reworded to "No errors for mm:ss.xx"
    * Logo is shown in the main window when temp. monitoring is inactive
    * Fixed broken X800SE temp. monitoring
    * Added save file dialog to dump bios
    * Added support for M28, R430, R480, R423GL
    * Added temp. monitoring option "show default icon in tray"
    * Added hw monitoring support for Abit uGuru (AA8, AG8, AI7, AN7, AS8, AV8, KV8)
    * Added support for Abit RX600
    * Added hw monitoring support for LM87, ADM1022, ADM1024, ADM1025, ADM1028, THMC50, FMS2701, NE1619
    * Added option to use "old scanning method"
    * Fixed issues in "Startup" settings
    * Added Catalyst AI support for 4.9 drivers
    * Added detection/overclocking/mem timings support for X800 SE AGP
    * Fixed crash issue on non-ATI cards
    * Added support for changing Catalyst AI settings
    * Fix for incorrect TAA detection with ATI Catalyst Control Center
    * Installer will now detect running ATIToolHooks.dll and mark it to be replaced at reboot
    * Installer will now detect running ATITool and ask to close it
    * Added M10 support to memory timings editor
    * Minor improvements to artifact scanning and detection
    * Added removal of Macrovision detection from analog input recording driver
    * Fixed crash when year>2038 (#81)
    * Added GPU temp. graph to main window
    * Reorganized user interface and 2D/3D profiles, feedback please
    * Added Catalyst version display
    * Fixed artifacts sometimes not cleared between scans
    * Added minimize on close option
    * Minor changes to the Hardware Monitoring page
    * Added experimental Hardware Monitoring settings page
    * Added HDD temperature to AAM page
    * More fixes and informational messages to HDD AAM
    * Fixed GPF when no suitable 3D device was found
    * Fixes to 3D detection .. seems that 3DMark01 and Warcraft 3 problems are fixed now
    * Rendering window can no longer be resized, there's no stress gained from a bigger window anyways
    * Selection defaults to first HDD in AAM page
    * Added Harddisk Acoustic Management - yeah I know, not ATI related :)
    * Improved artifact detection on X800
    * Improved scanning on PS2.0 cards, you should get much higher temperatures now. Please verify that ATITool still works on non-ps2.0 cards.
    * Revamped memory timings editor: added support for R300, R350, R360, R420, RV350, RV360, RV370, RV380, RV410
    * Fixed RV410 detection and overclocking
    * The clock rate input boxes now allow "," as decimal seperator, too
    * Fixed multiple "Scan for artifacts running 00:00:00" messages
    * Normal users can now use ATITool and get the settings the Administrator has chosen when he ran ATITool with his account, changes to settings made by normal users are not saved.
    * Could not write to log file message will no longer pop up multiple times.
    * If MBM is not running, but is needed to send temp. data to it, ATITool will try to connect to MBM every 10 seconds.
    * Added "Click here to change" to font display in Settings -> Temp. Monitoring
    * Fixed AIW TV Tuner broken when ATITool is installed on the system (#8)
    * 2D Profile will be set to "disabled" after changing video cards.
    * Fixed race condition which resulted in a crash at quit sometimes
    * Reenabled Fan Control for 9600, seems to work on some cards.
    * Fixed wrong logging of set clock rates (#42)
[:alizean]
Message édité par Tangzzz le 12-01-2005 à 12:57:20
n°2961480
Antidote95
Posté le 22-01-2004 à 12:48:53  profilanswer
interessant je teste
n°2961489
pinguin007
a npe error
Posté le 22-01-2004 à 12:52:47  profilanswer
pas mal je vais tester aussi :)
 peut etre changer le titre en "ATI Tools : L'overclocking intelligent ?" ou un truc du genre plus parlant nan :??:
LoD 4 ever && PWC spirit|Le topak de l'iMP-450|inDATOUNEwe trust
n°2961493
baby-herma​n
Posté le 22-01-2004 à 12:55:01  profilanswer
drapal
n°2961505
bitubo
GT Turbo Addict
Posté le 22-01-2004 à 12:59:47  profilanswer
je prend aussi :D
n°2961514
bracame
Posté le 22-01-2004 à 13:02:09  profilanswer
il a tourné pendant 5 heures cette nuit chez moi -> pas convaincu.
 il bloque le core a 301 si je pars a la frequence d'origine (275)- il monte a 355 si je pars a 310.
 pour la ram il me trouve +/-312 mais en montant manuellement ça tient a 320...
 bref avec les resultat qu'il donne ça passe pas 3dmark03
 j'ai une 9500.
  pas encore au point je crois
Message édité par bracame le 22-01-2004 à 13:07:10
n°2961515
pinguin007
a npe error
Posté le 22-01-2004 à 13:02:59  profilanswer
Bracame a écrit :
il a tourné pend
touche tab ?
n°2961519
Tangzzz
Posté le 22-01-2004 à 13:04:10  profilanswer
Bracame a écrit :
il a tourné pend
 :lol:  :lol: freeze ??  :D
n°2961521
Antidote95
Posté le 22-01-2004 à 13:04:45  profilanswer
putin vnr ma memoire limite grave l'o/c:
8500le fdx @8500
gpu monte a 304.5 et la ram block a moin de 283mhz
n°2961528
Janfy
Observateur
Posté le 22-01-2004 à 13:07:10  profilanswer
8500le fdx @8500
Tu as le bios et le cooling d'origine sur ta fdx ?
n°2961534
SiN
How does it make you feel ?
Posté le 22-01-2004 à 13:07:57  profilanswer
c vraiment efficace ce truc? si pas d'artefact dans le prog ca ve dire que c stable ??
drapal déguisé.... :jap:
Message édité par SiN le 22-01-2004 à 13:09:08
>>> VTR-Hardware.com
n°2961535
Antidote95
Posté le 22-01-2004 à 13:08:03  profilanswer
euh non j'ai le bios 1009 et un cooling maison: une ventirad de socket 7 sur le gpui et des rad sur les chip mem
Message édité par Antidote95 le 22-01-2004 à 13:08:41
n°2961538
bracame
Posté le 22-01-2004 à 13:08:38  profilanswer
Bracame a écrit :
 il a tourné pend
touche tab ?
 je sais pas quelle touche mais elle doit etre grosse car c'est pas la premiere fois
n°2961544
bracame
Posté le 22-01-2004 à 13:10:34  profilanswer
en plus ça utilise le CPU a 99% et ça je sais pas pkoi
n°2961572
keos92
This is the way..
Posté le 22-01-2004 à 13:22:11  profilanswer
quelqu un sait pendant combien de temps il tourne le Mr..... ?
n°2961579
pinguin007
a npe error
Posté le 22-01-2004 à 13:23:48  profilanswer
idem chez moi ca bouffe un max de cpu :/
n°2961582
keos92
This is the way..
Posté le 22-01-2004 à 13:24:31  profilanswer
ah oui 50%.... mais c'est juste pendant les test je suppose ?
n°2961584
pinguin007
a npe error
Posté le 22-01-2004 à 13:26:03  profilanswer
c'est plus proche de 100% chez moi :/
edit : boulaÿ powa c'est uniquemnt pendant les test  [:tilleul]
Message édité par pinguin007 le 22-01-2004 à 13:26:47
n°2961591
keos92
This is the way..
Posté le 22-01-2004 à 13:28:09  profilanswer
et justement les test dure combien de temps ?
n°2961607
cassoux
Posté le 22-01-2004 à 13:32:30  profilanswer
héhé, j'ai pas encore ma 9800pro pour test :)
n°2961628
bracame
Posté le 22-01-2004 à 13:37:42  profilanswer
je crois qu'il s'arrete jamais mais au bout de 3heures sans erreurs ça doit etre bon
n°2961635
keos92
This is the way..
Posté le 22-01-2004 à 13:39:59  profilanswer
bon ben je laisse tourner... il est rendu a 396/364.5
n°2961649
Thyast
Posté le 22-01-2004 à 13:47:05  profilanswer
 j'ai une 9500.
Bah non c'est normal, il doit procéder mhz par mhz et faire une batterie de tests à chaque fois pour faire chauffer un peu. Donc si tu démarre trop bas, il perd du temps. Et normalement il s'arrête quand il trouve des artefacts. Il vaut mieux commencer au plus près de la limite connue de la carte (10 mhz en dessous ?)
n°2961666
keos92
This is the way..
Posté le 22-01-2004 à 13:51:29  profilanswer
ce qui est bizarre c'est que il etait a 396 et est redescendu a 395.5... ?
n°2961679
bracame
Posté le 22-01-2004 à 13:54:14  profilanswer
 le probleme c'est qu'il me trouve des erreurs a 305 et redescend donc pour se stabiliser vers 301.5/302.
n°2961682
bracame
Posté le 22-01-2004 à 13:54:51  profilanswer
il redescend des qu'il trouve des erreurs
n°2961973
tsrz
Posté le 22-01-2004 à 16:07:02  profilanswer
arrêtes, moi j'attends ma 9800pro 256Mo pour le 9 février (font c..er ces fournisseurs qui tiennent pas les délais). Le pire c'est qu'aujourd'hui j'ai reçu mon vga-silencer ... raaaahhhh vivement février !!!!!
n°2962052
Thyast
Posté le 22-01-2004 à 16:55:22  profilanswer
Ah ouais là c'est zarb
Message édité par Thyast le 22-01-2004 à 16:55:38
n°2962134
alexreunio​n
Posté le 22-01-2004 à 17:27:59  profilanswer
Mon Vga Silencer je suis un peu déçu mais bon peut etre que je l'ai mal monté.
Je vais reessayer.
Mon feedback
n°2962137
alexreunio​n
Posté le 22-01-2004 à 17:28:53  profilanswer
Sinon pour ATItool moi il me donne
452/394 sur ma 9600Pro PowerColor
oui 394 ---> 788 DDR
Message édité par alexreunion le 22-01-2004 à 17:29:16
Mon feedback
n°2962244
tharkie
Effaré par l'idiotie humaine
Posté le 22-01-2004 à 18:04:21  profilanswer
9800 pro :)
435/365 stable :/
attention de bien baisser l'O/C du proc et la RAM... qu'ils ne soient pas générateurs d'erreurs !!!
pas mal ce truc :)
Sujet sur les cartes son audiophiles pour mélomanes et musiciens & DAC+ADC
n°2962264
Posté le 22-01-2004 à 18:12:45  answer
pour moi il ma trouver 421/369
suis pas convaincu :/
n°2962266
pinguin007
a npe error
Posté le 22-01-2004 à 18:13:02  profilanswer
par contre j'ai pas tout compris, quand je lui demande de tester ma ram, il fait ses test mais au lieu de monter la frequence il la baisse :heink:
n°2962379
Mang
Posté le 22-01-2004 à 19:02:58  profilanswer
9600 XT Fireblade
603.82/328.91
n°2962410
ze nerdz
gné ?
Posté le 22-01-2004 à 19:20:50  profilanswer
drapal !
je trouve l utilitaire gnial du fait qu il ne s installe pas, qu il change la frequence de la ram et du core, par la valeur que l on veut, qu il permet de tester le reglage et qu il est super léger. De plus il prends en charge les profils, avec hotkeys! brezf du tout bon !
n°2962462
kosovard77
Posté le 22-01-2004 à 19:44:28  profilanswer
comprend rien a cet utilitaire lol
n°2962480
tharkie
Posté le 22-01-2004 à 19:50:33  profilanswer
bon...
l'augmentation de la tension AGP ne change rien :/
435/365 !
vais essayer en O/C le bus AGP... :o
Message édité par tharkie le 23-01-2004 à 14:44:18
n°2962492
Space
Profil: Maux des rateurs
Posté le 22-01-2004 à 19:53:25  profilanswer
Cet utilitaire présente de nombreux avantages par rapport aux autres softs d'overclocking : On notera surtout la possiblité de détecter les fréquences maximum supportées par la carte sans qu'il y ait des artefacts, et ce grâce à la présence d'un mode de recherche des artefacts intégré directement dans le programme. Très utile pour les overclockers en herbe
les logiciels de "detectage" d artefact,ca jamais ete vraiment ca :/
n°2962550
Shaman Liz​ardKing
Blanc2poulet
Posté le 22-01-2004 à 20:11:35  profilanswer
Ca dure combien de temps les tests ??
Le Smiley de la mort !! (8÷þ
n°2962556
judreamer
Posté le 22-01-2004 à 20:14:19  profilanswer
De mon coté j'en suis bien content.
Sur ma 9800, les limites en fréquences par défaut sont à 423 pour le core et 350 pour la mémoire. En combinant les 2 j'arrive à 414/341. Ca permet de se donner une petite idée en direct de ce que l'on fait et c'est pas plus mal ;)
Page Précédente
Quel est votre version de Bios de votre Asus A7N8X ?Problème avec ATi Radeon All in wonder 9000 pro
ATI ou nVidia (Boouuuuhhhhh ATI!!!!)ATI ou nVidia (bâââââââââ nVidia) ???
ATi 9200 , G4TI 4200 ou fx5200?ATI Radeon 9600XT Bug « J'ai besoin d'une vraie aide
update ...ATI Cat3.10: comment desactiver AA+Anisotropie?
[Mobo] Comment savoir la version de ma K7S5A ???Div-X sur la télé et surfer sur le moniteur avec une ATI possible?
Plus de sujets relatifs à : ATI Tools : L'overclocking intelligent ? UPDATE 12/1/05 => version .23
