4039 connectés
  Technologies Mobiles
  GPS / PDA
  problème avec Pocketdivxencoder
n°128583
stef942
Posté le 14-10-2005 à 18:24:58  profilanswer
je voulais encoder 2-3 dvd pour les lire sur mon loox mais impossible de faire fonctionner pocketdivxencoder,
à chaque fois l'encodage dure 2 secondes et le fichier avi est illisible :(  :??:
un extrait du fichier log généré :
./cat.exe "F:\VIDEO_TS\VTS_01_1.vob" "F:\VIDEO_TS\VTS_01_2.vob" "F:\VIDEO_TS\VTS_01_3.vob" "F:\VIDEO_TS\VTS_01_4.vob" "F:\VIDEO_TS\VTS_01_5.vob" "F:\VIDEO_TS\VTS_01_6.vob" "F:\VIDEO_TS\VTS_01_7.vob" | ./mencoder.exe   -af volume=15 -aid 128 -oac mp3lame -lameopts mode=2:cbr:br=80    -vf scale=320:240,eq2=1.0:1.0:0.03:1.0 -sws 2   -ovc lavc -lavcopts vcodec=mpeg4:vhq:vbitrate=150 -ffourcc DX50 -o "D:\temp\VTS_01_1_PocketPC.avi" - >> 1.txt 2>> 2.txt
MEncoder dev-CVS-031126-06:00-3.3.1 (C) 2000-2003 MPlayer Team
CPU: Advanced Micro Devices  1671 MHz (Family: 8, Stepping: 0)
Detected cache-line size is 64 bytes
CPUflags: Type: 8 MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 1
Compiled with Runtime CPU Detection - WARNING - this is not optimal!
To get best performance, recompile MPlayer with --disable-runtime-cpudetection.
Reading config file d:\Temp\mencoder.iniFont d:\Temp\font/font.desc loaded successfully! (206 chars)
Reading from stdin...
success: format: 0  data: 0x0 - 0x0
Cannot seek backward in linear streams!
MPEG-PS file format detected.
VIDEO:  MPEG1  720x576  (aspect 3)  25.000 fps  8500.0 kbps (1062.5 kbyte/s)
[V] filefmt:2  fourcc:0x10000001  size:720x576  fps:25.00  ftime:=0.0400
Opening audio decoder: [liba52] AC3 decoding with liba52
AC3: 5.1 (3f+2r+lfe)  48000 Hz  448.0 kbit/s
AUDIO: 48000 Hz, 2 ch, 16 bit (0x10), ratio: 56000->192000 (448.0 kbit)
Selected audio codec: [a52] afm:liba52 (AC3-liba52)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1  (-1=autodetect) osd: 1
Opening video filter: [eq2=1.0:1.0:0.03:1.0]
Opening video filter: [scale w=320 h=240]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 576 (preferred csp: Mpeg PES)
VDecoder init failed :(
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.3.1
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
MP3 audio selected
Building audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
a52: CRC check failed!
VDec: vo config request - 720 x 576 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
SwScaler: reducing / aligning filtersize 10 -> 12
SwScaler: reducing / aligning filtersize 11 -> 10
SwScaler: BICUBIC scaler, from Planar YV12 to Planar YV12 using MMX2
Encrypted VOB file! Read DOCS/HTML/en/dvd.html.
Using SSE optimized IMDCT transform
Using MMX optimized resampler
a52: error at resampling
etc....
Quelqu'un pourrait il m'aider ?? merci  :jap:
Message édité par stef942 le 14-10-2005 à 18:25:59
n°128584
nighthawki​i
Posté le 14-10-2005 à 20:17:48  profilanswer
essaye plutot avec neodivx ;)
Bien démarrer avec un PDA -_- Bien choisir son GPS -_- Tuto surf et synchro via WiFi
n°128585
stef942
Posté le 15-10-2005 à 11:52:17  profilanswer
je vais essayer, merci :jap:
n°128586
stigmate10​1
Posté le 17-04-2006 à 12:52:52  profilanswer
Moi aussi j'ai un pb avec PocketDivXEncoder
Je cherche à reencoder un DivX pour qu'il soit lu avec mon Pocket PC.
L'encodage commence et bloque. Il bloque tellement bien que mon PC et completement planté, tout sourie,Ctrl+AltGr+Suppr etc...
 :o  :o  :o  seul sulution reset  :o  :o  :o
  GPS / PDA
Problème avec Dell Axim X3PocketDivXEncoder 0.3.60 plante mon PC
ETEN M600: Problème de notification intempestiveProblème pour installer Framework 2.0 sur Acer N35
problème avec ma carte micro SDProblème Siemens sp65
problème W300i couleur de caractère des sms blancheProblème pc studio
gros probleme avec A920 helpprobleme de chargement sony ericsson W850i
Plus de sujets relatifs à : problème avec Pocketdivxencoder
