6906 connectés
Sujet : Aidez moi C mon premier rip.....Je coince!!!
dark Bruce exucuse C parce que j'avais pas changer de canal!!
C T le 0x81 et pas 0x80!!
Bon je vais essayer de terminer!!
Je vous tins au courant!!
Bruce Kalli : Non, non et non ! Rippe avec le rippack et non smartripper ! Il faut ripper en suivant le ifo...
Sinon Dark, met à jours ton rippack car tu semble avoir une version ancienne (qui affiche les cell...).
Ciler Ton DVD, c'est le français, non parce-que dans ce cas, y a de fortes chances que la piste française soit la première... :sol:
dark Ouai comme C mon premier je le fé pas a pas!!!
vStrip - version 0.6f_css, by [maven] (maven@maven.de), CSS-code by R0TfL.
VTS_01_0.IFO
Parsing "e:\VIDEO_TS\VTS_01_0.IFO"...
  0. Length: 00:01:05:64 in 1 cell(s).
  1. Length: 00:02:37:80 in 1 cell(s).
  2. Length: 00:03:88:64 in 1 cell(s).
  3. Length: 00:02:04:85 in 1 cell(s).
  4. Length: 00:02:05:96 in 1 cell(s).
  5. Length: 00:04:08:80 in 1 cell(s).
  6. Length: 00:02:53:69 in 1 cell(s).
  7. Length: 00:01:02:96 in 1 cell(s).
  8. Length: 00:03:52:69 in 1 cell(s).
  9. Length: 00:06:21:68 in 1 cell(s).
  10. Length: 00:06:21:68 in 1 cell(s).
Scanning for stream id's, press control-c to quit...
* Unable to open "0" for input
VTS_02_0.IFO
Parsing "e:\VIDEO_TS\VTS_02_0.IFO"...
  0. Length: 02:16:70:80 in 116 cell(s).
  1. Length: 00:00:18:96 in 1 cell(s).
  2. Length: 00:00:00:82 in 1 cell(s).
  3. Length: 00:00:00:82 in 1 cell(s).
  4. Length: 00:00:00:82 in 1 cell(s).
  5. Length: 02:16:70:80 in 116 cell(s).
  6. Length: 00:00:49:70 in 5 cell(s).
  7. Length: 00:02:56:68 in 5 cell(s).
  8. Length: 00:01:07:87 in 1 cell(s).
  9. Length: 00:00:88:69 in 1 cell(s).
  10. Length: 00:03:36:80 in 2 cell(s).
  11. Length: 00:01:16:83 in 1 cell(s).
  12. Length: 02:16:70:80 in 116 cell(s).
  13. Length: 02:16:70:80 in 116 cell(s).
  14. Length: 02:16:70:80 in 116 cell(s).
  15. Length: 00:00:00:82 in 1 cell(s).
  16. Length: 00:00:00:82 in 1 cell(s).
  17. Length: 00:00:00:82 in 1 cell(s).
VTS_03_0.IFO
Voila  moi j'ai essayer de faire le 2 et kan je préécoute avec le rippack de bruce C de l'anglais!!
Merci de m'aider!!
moikiki il faut ripper le 2éme ifo mais surtout ton pb, c'est que sous ac3dec, il faut que tu mettes la piste 0x81
Ciler T'as essayé en lisant le .htm d'aide qui va avec le rippack...
sinon, balance la liste des .ifo et je verrais si je peut t'aider
Kalli Rip ton DVD avec Smart Ripper, et utilise ensuite le rippack de Bruce.
dark :(??????????
dark :(:(:(
ssssiouplaittttttttttttttttttttttttttttttttttttttt
dark Voila j'essaye de ripper MATRIX en VF mais C une bande son anglaise qui me sort!!
J'utilise e rippack de BRUCE.
Pouvez vous me dire kel *.ifo il fo que je rip?????
Grand merci a celui qui me dira...
