8228 connectés
Sujet : [Player DivX] PowerDivX NextGen 3.12 & [DVD-BACKUP] DVD:Reaper 3.2
Ninipc voir topic "TCMP"
DJMoissoneuseBateuse a écrit a écrit :
Bon, en esperant que le Powerdivx suivant sorte un jour..:/
Alors ? C'est mort ?  :??:
Honte à moÿ, je suis passé à BSplayer, la claque  :ouch:
Lancement rapide, c est hyper léger à l utilisation, ca plante pas, pleins de trucs sympas (style l affichage du son en % vert sur le film pendant 2 sec, pratique) etc..
BlackSunSoft Reprise du premier post (génération automatique) :
Désolé j'ai pas eu le temps de traduire.
PowerDivX NextGen 3.07:
This player offer all the features for the best video experience and provides a better looking interface:
 - Support for DivX(tm) video compression technology.
 - Specialized in AVI with AC3 streams
 - Support SPDIF, 4 Speakers, 6 Speakers, Dolby Surround, Stereo, Mono, 3D Audio
 - PowerDivX NextGen introduce the DiviDivX which can reproduce DVD menus
 - Support for AVI with multiple audio streams (BivX) up to five audio streams
 - PowerDivX NextGen introduce a new easy subtitles format, but also support MicroDVD subtitles
 - Realtime Sound Dynamic Range Compression
 - No slowdown while a keyframe is played
 - Skins support
 - Multiple Rate speed
 - Multiple custom aspect ratio support
 - DivX G400/Geforce overlay support provided by PRR
 - An option to disable the screen saver
 - DivX setting like CPU Quality, Brightness, Contrast, Hue and Saturation
 - WMA and DivX Audio equalizer
 - A tweaker for K6-2 with chipset MVP3/southbridge VT82C586B
 - An option to jump to the desired time
 - A DivX Antifreeze filter provided by PRR
 - A repeat mode
 - Playlist
 - Shell Integration
 - Shortcuts
 - Drag & Drop
 - DVD Subtitles supported by the DirectVobSub filter
 - Full access to the filter properties
DVD:Reaper 3.1:
A very simple all in one ripper/encoder, fast !! This software is specialized in AVI/AC3/MP3, It is all that you need to backup your DVD ! With DVD:Reaper, you can do DivX 3.11a VBR, DivX 4.0, you have a bitrate calculator, etc. You can also encode several movies with the job control (DVD:Reaper is faster than FlaskMpeg). Now DVD:Reaper is available in French, English and Italian.
[edtdd]--Message édité par BlackSunSoft--[/edtdd]
