6964 connectés
Sujet : Pinnacle Studio DC10 plus comment on fait pour avoir le son ????
unptitdiable Mais de rien.
Faut bien s'aider un peu.
A+
A+
nosferatu OK ENCORE ET ENCORE MERCI POUR LES INFOS :love:  :love:
unptitdiable :hello:
Nosferatu >>>.
Voila les psecs completes de ton camescope :
Features:
Hi8 PAL Recording System (up to 400 lines)
Playback with PAL or Multisystem TV
450x / 40x Selectable Digital zoom (20x Optical zoom)
2.5" Colour LCD Monitor
NightShot (0 Lux minimum illumination)
Built-in Video Light
InfoLITHIUM L series battery
Automatic / Manual Focus
Automatic White Balance
Exposure Control
Automatic Gain Control
Preset and Custom Title Function
Fader Function
Date / Time Function
Digital Noise Reduction
Built-in Microphone (Mono) and Speaker
SP / LP Recording
Time Base Corrector
On-Screen Display
NTSC Playback on PAL TV
Video Out
S-Video Out
Audio Out (Mono)
Headphone Jack
Remote Commander
16:9 Recording
Supplied Accessories:
Worldwide AC Adapter
Batteries AA x 2
Lens Cap
Mono AV Cable
Remote commander
Shoulder Strap
Specifications:
Zoom: 450x / 40x Digital, 20x Optical, F: 1.4-2.9, f (Focal Distance): 3.6 - 72mm, f (35mm Conversion): 51.8 - 1036mm
Filter Diameter: 37mm
CCD: 1/6" 320,000 pixel
Minimum Illumination: 1 lux (0 Lux with NightShot)
Shutter Speed: 1/50 - 1/4000 (via Program AE)
Program AE: 6 modes
Viewfinder: Black and White
Picture Effects: 8
LCD: 61,600 pixel
Weight: 910g
Dimension (WxHxD): 104 x 109 x 223 mm
Optional 4 Hours and 8 Hours genuine Sony batteries available
Note: This Camcorder records on PAL System. You can playback on PAL TV or Multisystem TV. You cannot playback on PAL-M TV(Brazil), PAL-N TV(Argentina/Paraguay/Uruguay), nor NTSC American TV.
Return Policy :30 days Exchange, Replacement or Refund as long as item is returned with original factory packaging. We do not charge restocking fees. Shipping charges are non-refundable.
Sony TRV49E PAL Camcorder
Pour la Stereo en lieu et place du mono, ce n'est plus l'age qui determine ca mais le prix.
Pour l'image, il faut utiliser la sortie S-Video si elle est bien presente. L'image est vraiment beaucoup plus belle.
Y a pas photo.
Par contre, utilise quand meme un cable S-Video d'une qualite acceptable.
Astuce : Lorsque tu fais ton acquistion, dans les parametres de Studio 7, monte un peu le curseur de nettete, monte egalement celui de la saturation. N'hesite pas a jouer avec le contraste et la luminosite. Le resultat n'en sera que meilleur.
Pour l'Audio, utilise un cable mono si tu ne veux pas te faire " Couic ". Perso, je prefere, dans ce genre de situation, dupliquer le canal gauche sur le droit.
C'est mieux
Iancurtis >>>>
Tres bonne question.
La reponse n'est pas evidente.
Si tu veux, tout va dependre de ce que tu vas faire avec ta video.
Comme la DC10+ utilise un codec MJPEG hard qui genere des gros fichiers, je suppose que tu vas renvoyer ca sur un autre support ou compresser le tout.
Si c'est pour renvoyer sur une VHS, tu peux utiliser le reglage maxi.
Si c'est pour generer un fichier MPEG, c'est plus complique.
L'encodage MJPEG est radicalement different de l'encodage MPEG.
La gestion de l'image n'est pas identique.
Tout va dependre de ce que tu vas faire apres.
Si c'est pour un DVD, tu peux y aller en 6000Kbps
Si c'est pour un SVCD, ne depasse pas les 4000 ( perso, j'utilise 3550 pour faire mes SVCD ).
Si tu veux vraiment etre au top avec cette carte, je conseil la chose suivante ( je l'ai fais )
Prend un VHS de bonne qualite.
Selectionne une bonne scene.
Fais des acquisitions de cette scene en changenat le birate ( 6000, 4500, 3000, ...... pour exemple )
Encode chaque fichier avec les memes parametres.
Compare.
Je sais que c'est un peu lourd mais c'est le meilleur moyen pour faire quelque chose de bien.
Ce qui est valable chez moi ne l'est pas forcement chez les autres pour x raisons :
- Liaison
- Codecs utilises.
- parametres utilises.
.... etc ....
A+
IanCurtis salut,
G une DC10 + aussi : quel sont les reglages optimum, le meilleur rapport poids/qualite pour acquerir des scenes VHS de 5-6 minutes ?
Ian
nosferatu Merde alors tu es trop fort mec comment tu as trouvé tout ça :jap: , j'ai cherché et pas trouver ! Respect, je suis déçus j?aurais pas cru que certains caméscope récents étaient en mono  :fou: ! Je suis dégoûté. Beh tant pis alors il faut que j?utilise le câble s-video tu es sur que ça fait une différence car sur certain forum et site et même moi j?ai pas vu de différence ?
1 sortie audio = camescope avec sortie Mono.
Y a pas de probleme la dessus .
Voila les specs :
Exposure Control
Fader Function
SP / LP Recording
Time Base Corrector
On-Screen Display
Video Out
S-Video Out
Audio Out (Mono)
Headphone Jack
Remote Commander
16:9 Recording
Voila.
par contre, je constate qu'il a une prise S-Video Out.
J'espere que c'est ce que tu utilises pour l'acquisition.
La qualite d'image est tres largement sup. a la liaison Video composite.
Sinon, il te faut un cable mono ou faire ce que j'ai dis plus haut. ( copie/duplication  de canal )
A+
nosferatu 1 sorti audio et 1 video pas plus
c'est un sony ccd-TRV49E et dans le manuel il ne parle pas du format audio qu'il supporte y a marquer que
Rotary heads, FM system     :??:  :??:
je l'ai pas acheter cher ? il est pas trop puissant
unptitdiable tu as une ou deux sorties audio ?
Donne le modele, je donnerai la reponse.
A+
nosferatu il la a peine 6 mois le camescope je doute qui ne fait pas la stéreo  :eek2:
Ha ha .......... tres bonne question.
Voila la reponse.
Sur ton camescope, tu as une seule sortie audio. Cela signifie qu'il est mono ( pas de stereo ).
Si tu as un cable 2 RCA vers 1 jack, c'est que tu as un cable stereo.
Avec ce cable, tu n'auras du son que sur une voix.
Ce n'est pas tres grave si tu comptes monter la video acquise. Il suffit de copier la voix OK sur la voix qui n'a rien.
Les softs de montage savent tous faire ca.
Si tu ne monte pas ton film, il faut passer par un cable mono. 1 RCA vers 1 jack et ne pas oublier de faire l'enregistrement en mono.
Avec certains chips audio, tu peux faire du mono avec du stereo sur une voix mais la, c'est une autre histoire et je ne sais pas si c'est ton cas.
A+
nosferatu je viens d'acheter un cable jack -> 2 rca femelle !
le son marche mais que d'un coté chierrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
 :fou:
et oui y a 2 sorti femelle poru le jack
coment je fait j'ai le même cable mais avec 2 male je vais essayé
aiglon Pour l'acquisition  du son, ça marche! Merci pour tout!
Maintenant, un autre problème: la conversion en DivX grâce à Virtualdub/ La qualité vidéo n'est franchement pas super. Mais sans doute la compression est-elle trop forte. Je pars d'un fichier d'environ 10 Go pour aboutir à un fichier DivX de 300 Mo... Que faut-il faire pour régler une compression plus faible? Je précise que l'acquisition avec la DC10+ (et studio 7 version 13) s'est faite en sélectionnant qualité optimum pour la vidéo (d'où la taille de 10 Go du fichier!)
Merci encore!
 :bounce:
Pour commencer, AIGLON, quel OS as tu et quelle version de Studio ?
Sinon, 2 ou 3 petites choses.
dans tous les cas, il faut bien selectionner le bon peripherique d'enregistrement dans les proprietes de Windows ( surtout pour ceux qui ont carte son + codec AC97 ).
De plus, il ne faut pas oublier de selectionner l'entree ligne comme source d'enregistrement ( se trouve dans les proprietes de volume. Le petit HP dans la barre des taches puis proprietes, enregistrement et la, faut bien activer l entree ligne )
Raccordement a l'entree ligne de la carte son :
Il faut aller dans les proprietes de Studio et choisir l'entree ligne comme source Audio.
Ne pas oublier d'activer l'encodage du son avec la video.
Le vuemetre de droite ( fenetre acquisition ) doit bouger.
Raccordement a l'entree ligne d'un AC97 :
Il faut aller dans les proprietes de Studio et choisir l'entree Mix stereo comme source Audio.
Dans tous ls cas, attention aux differents volumes car il peut y avoir des soucis si ceux-ci sont mal regles.
A+
[/citation]
aiglon Mon OS: XP Pro
J'ai studio 7, version 7.13.6
Merci pour ta réponse, je teste et je te tiens au courant si déboires!
A+
aiglon Bonjour!
Alors moi, j'ai fait tout ça... J'ai bien du son dans les HP de mon PC quand je fais l'acquisition d'un film. Mais quand je relis le (gros) fichier récupéré, pas de son! Et bien sûr, celui-ci ne réapparait pas quand j'encode en DivX. A propos, les images en DivX obtenues à partir d'un fichier récupéré par la DC10+ (réglage qualité optimum) ne sont pas terribles.. Que faire, même si c'est au détriment de la compression? (je dispose d'un graveur de DVD (acheté 2000 francs à Tokyo), donc je suis large... (prix du DVD-RW à Tokyo = 17 francs ou 3 euros environ)
Merci pour les réponses...
Oui, elle encode le son avec la video mais il faut passer par une carte son pour avoir le son !
C'est la DC30+ qui a les deux. mais a 3x le prix de la DC10+, ca fait chere du chip audio.
A+
[/citation]
nosferatu  :love:
ok
merci pour tout c'est si rare
 :jap:  :jap:  :jap:
A+
nosferatu merci beaucoup unptitdiable
voila une explication claire et précis
le truc que j'avais pas compris c'est que sur la boite de la carte acquisition il marque l'encodage du son je croyais que cette carte pouvais prendre le son avec la video
burtonsnowboard >>>> DC10+ = carte analogique. Donc, pas de DV ( DV = numerique )
nosferatu >>>> Pour la video, il faut relier la sortie video-composite de ta source a l'entree composite de la DC10+ via un cable Video composite tout simple ( connecteur RCA ou CINCH pour avoir les termes possibles )
Si ta source possede une sortie S-VIDEO ( mini DIN 4 broches ), utilise cette connection. Avec ce genre de liaison, l'image  est bien plus belle.
Pour le son, il faut utiliser un cable RCA vers Jack 3.5
C'est trouvable n'importe ou ( grande surface, net, boutique electronique ...... ).
Tu peux meme le faire toi meme. C'est l'ideal et ca coute moins chere.
Ensuite, suffit de brancher le connecteur RCA sur ta source et la prise Jack dans l'entree ligne de ta carte son.
Voila.
burtonsnowboard Tu parles d'acquisition DV ?  :heink:
Si c'est le cas, tu es un peu à côté de la plaque...
nosferatu dernier truc ça s'achete ou ces cables dans n'importe quel grande surface ou magasin spécialiser ou alors par internet
merci  :jap:
nosferatu ah ok merci pour l'info
tu connais pas des sites en français si possible qui parle de l'aquisition merci :jap:
ACClarke un cable jack -> jack normalement
ou jack -> RCA ça depend
nosferatu c'est quoi le cable qu'il faut
ACClarke on recupere le son par la carte son (entree auxiliaire ou micro)
nosferatu :eek2:  :eek2: hellllllllllllllllllllllllllpppppppppppppppppp comprends rien !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
 :eek2:
nosferatu Je viens d'achater cette carte ! je prendre le fil jaune de mon camescope dans la prise jaune video in de la carte, la video fonctionne parfaitement!
mais avec le camescope j'ai un fils noir ou il y a le son
comment je recupere le son ? Quel fil il me faut
vous connaissez pas de site qui parle de ce probleme merci
