7715 connectés
Sujet : [Xcard] Drivers 1.2
lexav1 en fait y le lecteur peu tjrs lire les divx avec MP3 VBR mais l'audio n'est pas synchro avec la video.
Y a tjrs pas de support pour divx audio alors que ca marchait avec la 1.0.
lexav1
- A new AVI Splitter DirectShow filter for the playback of
  MPEG 4 AVI's named : "Sigma Designs AVI Splitter".
- The DivX AVI files do not need to have the extension AVI.
  They'll get recognized by AVI Checker.
- Smoother playback of DivX files 5.xx with B-frames.
- Better recognition of DivX 5.xx files with AC-3 audio and
  not mistaking them as including the GMC feature.
- Support for alphabetically sorting the Play List. Right-click
  the list.
- Support for multiple audio tracks in SVCDs.
- Inserting a DVD/CD disc in the drive will launch the
  Xmedia Player and will start the playback (provided autoplay
  is turned on) even if the last use of the player was in
  Play List mode.
- You can use the "Title" button on the Remote Control or the
  keyboard to get the "Display Info" in the OSD display. This
  is not applicable when playing DVD titles since, in this case,
  it triggers the Title menu of the DVD contents.
- More descriptive error messages.
- No support for Variable Bit Rate VBR MP3 files.
Les bug fix sont nuls et ils ont enleve le support pour vbr de mieu en mieu  :heink:
