5915 connectés
Sujet : est-ce un bon lecteur? (sony ST-SE370)
bozo le clown ba voila, je cherche de quoi remplacer une vielle chaine radio, et j ai trouvé ca
Main features
New 'E-Line' design
FM/MW/LW
Random 30 memory presets
Auto tuning
RDS
Advanced reception circuit
14 seg x 8 letter display
Technical Spec
Sensitivity/Mono 26dB S/N: 0.9uV/10.3dBf
Sensitivity/Stereo 46dB S/N: 23uV/38.5dBf
Signal to Noise/Mono > 76dB
Signal to Noise/Stereo > 70dB
Channel Separation > 45dB
Frequency Response: 30-15.000Hz;+0.5/-1dB
Ext. Antenna Terminal FM: 75 Ohm
Power Consumption: 10W
Power Requirement: 220-230V, 50/60Hz
Dimensions (WXHXD): 430 x 85 x 275 mm
Weight: 2.5kg
http://www.techtronics.com/uk/shop [...] uners.html
vous en pensez quoi? :hello:
Main features
New 'E-Line' design
FM/MW/LW
Auto tuning
RDS
Technical Spec
Weight: 2.5kg
