6930 connectés
Sujet : Format AVI et slx demo 3.5
vthand up
vthand up
vthand Bonsoir
Lorsque j'essaye d'ouvrir un fichier avi produit par premiere 6.0 j'ai droit au message suivant
Failed to decompress AVI video stream. Possible reason: cannot find appropriate video codec. AVI file may be corrupted or uses an unsupported video compression format. Please specify valid input file name and directory.
dans l'aide, il y a ça :
This error is generated when Windows is unable to decode the AVI input file. The most common cause is that the AVI was compressed with a codec that is not installed on the system being used. You can check this by trying to play the file with Active Movie or Windows Media Player, or by checking for the codec in the Windows Control Panel Multimedia settings. In order for LSX-MPEG Encoder to decode the file for the transcoding process, the same AVI codec must be properly installed on the same system.
lorsque je clique sur les propriétés du fichier avi , j'ai " Format inconnu ".
Votre avis , docteur ?
