6073 connectés
Sujet : audiograbber 1.81 dans la hotte du PN !
quess sorti hier ou avt hier
- CD-TEXT support (Check the CD menu and freedb settings).
- Internal WMA8 support (Install Spoon's WMA8 support for dBPowerAMP if you don't have WMA8 on your computer).
- Internal support for SONY ATRAC3 compression (ATRAC3 is what Sony use on Minidisc and their own MP3 competitor players). Get the acm encoder/decoder from Minidisc's site. http://www.minidisc.org/atrac3.zip. Unzip the two files and right click atrac3.inf and chose install.
-Better support for Algorithmix's noise reduction plugin for Audiograbbers line in sampling. It is now possible to listen to the recorded sound while it is being cleaned. Mute line in sound from going straight out to the speakers and check the new option "Play while recording" on Line in sampling. Make sure wave sound is going out to the speakers. This does not work with all soundcards but it does with most of them. Get the plugin from Algorithmix's site: http://www.algorithmix.com/home/index_products5.htm
- A few minor improvements has of course also been added, such as more available bitrates for internal OGG encoding and a shut down option on MP3 encoding for example. OGG encoder: http://www.audiograbber.net/vorbisdll.zip
- Still missing is secure ripping (rip and verify) but I thought it was important to release a new version with the play while recording option so users can take full advantage of the newly released noise reduction plugin from Algorithmix. (Hey, we've waited for that plugin for almost a year now! It is finally here and it is VERY good!)
Pour moi c'est le meilleur ripper de CD (après EAC bien entendu), et va très bien avec lame 3.90  :)
