14386 connectés
Sujet : help sur vstrip
sanmei ok merci
j'avais des erreurs de syntaxe.
sanmei ok merci
Bruce Tu as mis quoi EXACTEMENT en commande ?
N'oublie pas de mettre le "-" devans le "!" !!!!
sanmei J'ai tapé ce que tu montres!
pb sur "!"
Bruce Si tu lisais ce qu'affiche vstrip ? Il te donne la syntaxe EXACTE :
vStrip - version 0.8c_css, by [maven] (maven@maven.de), CSS-code by R0TfL.
Usage:
  vStrip [@]In [-Options] [[=]IDs]
  In  denotes the input-file and has to be the first argument. If a '@'
      is prepended to the name, it is read as a streamlist (textfile).
  Options:
  -!  defaults to strip everything,
  -d  enables demux mode (not producing a VOB anymore),
  -e  disables VOB-assumptions (no 2048 byte sectors), enables demux,
  -g  only keeps GOP-Headers of the Video-Stream(s),
  -l  lists the CELL-Positions parsed from the IFO-file,
  -u  tries to parse (and output) UDF-filesystem on In (e.g. vStrip M:\ -u)
  -c  splits the VOB by CELL-ID,
  -v  splits the VOB by VOB-ID,
  -oM sets the output filename to M (add '+' in front to append),
  -iN sets the IFO-file filename to N,
  -jO sets default angle for IFO-Parsing to O (=1, 0 disables removal),
  -pP selects program-chain (PGC) P (from IFO-file) and enables IFO-Parsing,
  -$Q splits output-file(s) after Q megabytes (1024KB chunks),
  -aR changes the aspect-ratio to R,
  -fS changes the frame-rate to S,
  -sT seeks to LBA T (2048 byte sectors),
  -tU file IO: clib then ASPI (U=1), ASPI then clib (U=2), clib only (U=3),
  -kV sets the key to V (5 hex bytes, no spaces),
  -mW a key deduced from a padding-stream is worth W normal guesses (=2),
  -nX sets the number of times a key needs to repeat to X (=2),
  -qY sets percentage a candidate key has to have of all keys to Y (=75),
  -rZ key-search per VOB-ID (Z=1), CELL-ID (Z=2) or VOB- & CELL-ID (Z=3),
  IDs hex stream-ids (e.g. 0xe0), seperated by a space. If a '=' is
      prepended to the id, the last stream is remapped to this id.
Hints:
  - Demux mode can split, too (but "c" and "v" are exclusive),
  - All the options w/o an argument can be combined (e.g. "-!dc" )
  - Try a test-run on the VOB first (only filename as parameter),
  - Frame-rates:
    [1] 23.976 (24000/1001) fps    [5] 30 fps
    [2] 24 fps                     [6] 50 fps
    [3] 25 fps                     [7] 59.94 (60000/1001) fps
    [4] 29.97 (30000/1001) fps     [8] 60 fps
  - Aspect-ratios:
    [1] square pixels              [3] 16:9 display
    [2] 4:3 display                [4] 2.21:1 display
Examples:
  To get a list of the streams in a VOB:
    vStrip in.vob
  To keep video and AC3 stream 0x81 mapped to 0x80 using PGC 0 and 1GB chunks:
    vStrip @in.lst -iin.ifo -p0 -$1024 -!oout.vob 0xe0 0xbd 0x81 =0x80
  To demux the video-stream:
    vStrip in.vob -!doout.m2v 0xe0
sanmei merci de ton aide mais j'ai déjà fait ce que tu proposes.
j'ai essayé la syntaxe qu'ils proposent.
qui connait un lien cool qui explique soit le gui soit les commandes dos!
jai trouvé doom9,mais je cherche un lien plus complet!
fcosinus propose des bat aussi.
Ciler Je peut t'aider si tu me balance l'aide de vStrip (je connais pas les items de la ligne de commande par coeur).
Pour ce faire, il faut lancer l'invite de commande DOS et utiliser la commande
vStrip.exe > Help.txt
en étant dans le réopertoire de vStrip. L'aide apparait dans le fichier texte en question
sanmei personne connait?
sanmei j'essaye de récupérer un vob avec vidéo+son french only
ma ligne de commande:
vstrip vts_01_1.vob toto.vob ! 0xe0 0xbd 0x81 =0x80
ma piste en français étant en 1.
j'ai un message d'erreur sur "!".
je tourne en rond.
