4404 connectés
Sujet : un nouveau mpeg2avi !!!!!
tiburs1 Et cerise sur le gateau, il a l'air encore plus rapide.
je dirais de l'ordre de 8-10%.
Je suis presqu'en temps réel sur le Divx 3.11 (23 fps)
et de l'ordre de 19 fps sur Divx 4 :D
A+.
Tiburs1.
A+.
Tiburs1.
Bruce Oui il marche, je l'ai annoné hiers soir dans le thread du rippack et sur www.mpeg4-fr.com !
alaflamout Si ca fait tout ce que ca dit, c'est enorme.
Je vais essayer de l'utiliser avec le rippack V3
Merci pour le tuyau en tout cas
ACClarke oups j'ai oublier l'auteur !!
MPEG2AVI PX3 modded by OGO
This work is based on the good m2apx3g 0.1.5a from PX3 which has stopped any further developpement on it.
I plan to make more work on it in a near future, but for now i'm just :
 - cleaning the code
 - fixing bugs i find
 - adding little features
ACClarke Bon c'est pas PX3 qui reprend du service (malheuresement) mais ça a l'air interessant quand meme voyer vous meme :
0.1.5c: released 16/09/2001
 * fixed the bug that made mpeg2avi wait forever without quitting at the end of the 1 pass in a DIVX4 2 pass session
 * fixed a crash that occured occasionnaly when hitting "cancel encoding"
 * crude but working error reporting
 * better avi file size estimation indicator
 * code cleaning ... Removed all non GUI stuff and a lot of old unused code
0.1.5b: released 15/09/2001
 * fixed a very annoying bug in the codec selection where no codec was listed at all (DIVX codec disparition bug)
 * fixed memory allocation bugs in avi file routines that for sure make the thing crash sometimes
 * added avi file size estimation in dialog. Useful when you use fixed quality encoding in DIVX4 and want to have an estimation of the file size
 * added achieved bitrate indicator in dialog (DIVX4 bitrate ie 1kpbs = 1000 bits)
 * changed units from KB to MB in dialog
 * code cleaning ...
Telechargeable comme d'hab sur http://www.doom9.org
