4918 connectés
Sujet : avec koi j'peux convertir des OGG en MP3 ???
Eniac Blade ou Lame c'est l'encodeur, prend Lame et pose pas questions ;)
Pour le VBR/CBR :
What is Variable Bitrate (VBR) Encoding?
Variable Bitrate encoding is a method that ensures consistently high audio quality throughout an encoded file by making intelligent bit-allocation decisions during the encoding process based on a scale you set in the XingMP3 Encoder settings dialog.
When the Encoder encounters difficult sections in the audio source (for example, sections containing a relatively wide stereo separation), it allocates additional bits to that section, ensuring the audio quality.
When the Encoder encounters easy sections (for example, sections containing silence or a relatively narrow stereo separation), it allocates fewer bits to the section, reducing unused bits.
As a result, your MP3 file consists of variable bitrates throughout the file because the Encoder puts the bits where they are most needed.
When to Use Variable Bitrate (VBR) Encoding
VBR encoding was developed for use when consistent audio quality is the top priority and constant or predictable encoded MP3 file size is not critical.
Variable Bitrate (VBR) Encoding Restrictions
· Because a VBR-encoded MP3 file consists of variable bitrates throughout the file, the MP3 file size is not easily predicted. Variable Bitrate encoding should not be used when you need to predict and/or limit the size of the MP3 file.
· Many MP3 players may inaccurately report the duration of VBR-encoded files. If the MP3 player cannot accurately determine the time, seeking in the file may also be unpredictable.
What is Constant Bitrate (CBR) Encoding?
Constant Bitrate Encoding is a method that ensures a consistent bitrate throughout an encoded file at the expense of audio quality and/or Encoder efficiency. The Encoder allocates the same number of bits to difficult sections (for example, sections containing a relatively wide stereo separation), and easy sections (for example, sections containing silence or a relatively narrow stereo separation). As a result, difficult sections may suffer quality degradation while easy sections may include unused bits.
When to Use Constant Bitrate (CBR) Encoding
Use CBR encoding when you need to limit the size of the MP3 file or produce consistent and predictable file sizes.
Constant Bitrate (CBR) Encoding Benefits
CBR encoding produces MP3 file sizes that are easily predicted by multiplying the bitrate by the Duration.
A+
Pour le VBR/CBR :
A+
DANLEJ bein, re merci ESSAIR ça marche pil poil finger in the noze  :bounce:  :D
heu... sinon dans le choix de convert y propose MP3 BLADE ou LAME c'est koi la diff?
et dans l'encoding y'a CONSTANT BIT RATE & VARIABLE BIT RATE là aussi c'est koi?
DANLEJ bein, j'ai lu k'un lecteur de MP3 woiture inclu un DD de 10 Go, ça leur trouerai l'cul d'y inclure un soft comme winamp ou autre afin ke cela devienne autre chose k'un simple lecteur :fou:
j'trouve ke pour la woiture les constructeurs on beaucoup fait pour la radio mais po trop pour la lecture final'ment :(
Maxime bah ca ne lit que le MP3 normalement ( y en a peut-etre qui sont "upgradable" pour d'autre format comme le MP3 Pro )
DANLEJ bein, merci ESSAIR  ;)
MAXIME si y'a une autre soluce j'suis preneur, mais en attendant de pouvoir mettre un lecteur de MP3 dans ma woiture faut bien ke j'les mette en .WAV.
heu... sinon est-ce ke les lecteurs MP3 pour woiture peuvent lirent tous les formats ?
Maxime tu perdra de la qualite en faissant cette operation  :benetton:
essair Utilises dBpowerAmp, il te permettra de convertir tes fichiers ogg directement en mp3 . Le lien est ici : http://admin.dbpoweramp.com/
DANLEJ bein, j'ai essayé avec MODPLUG, EASY CD EXTRACTOR mais ils ne le gère pas, y'a ke winamp ki le lit mais j'sais po comment faire pour convertir :cry:
