3865 connectés
Sujet : OUIIN ! vStrip est méchant avec moi !
Ciler OK merci, le texte je l'avais...
mais j'ai compris, c'est le vob bidon qui me manquait  :D
Bon allez, je rentre, je loue le Dracula de Coppola, je met DVD:Reaper à jour avec vStrip08 (maintenant que je comprend pourqoui qu'il marchait pas) et je teste...
Blacksun> Intégration du dernier vStrip pour demain, content ?
Bruce Halala...
Alors les commandes de vstrip sont :
vStrip - version 0.8a_css, by [maven] (maven@maven.de), CSS-code by R0TfL.
Usage:
  vStrip [@]In [-Options] [[=]IDs]
  In  denotes the input-file and has to be the first argument. If a '@'
      is prepended to the name, it is read as a streamlist (textfile).
  Options:
  -!  defaults to strip everything,
  -d  enables demux mode (not producing a VOB anymore),
  -e  disables VOB-assumptions (no 2048 byte sectors), enables demux,
  -g  only keeps GOP-Headers of the Video-Stream(s),
  -l  lists the CELL-Positions parsed from the IFO-file,
  -u  tries to parse (and output) UDF-filesystem on In (e.g. vStrip M:\ -u)
  -c  splits the VOB by CELL-ID,
  -v  splits the VOB by VOB-ID,
  -oM sets the output filename to M (add '+' in front to append),
  -iN sets the IFO-file filename to N,
  -jO sets default angle for IFO-Parsing to O (=1, 0 disables removal),
  -pP selects program-chain (PGC) P (from IFO-file) and enables IFO-Parsing,
  -$Q splits output-file(s) after Q megabytes (1024KB chunks),
  -aR changes the aspect-ratio to R,
  -fS changes the frame-rate to S,
  -sT seeks to LBA T (2048 byte sectors),
  -tU file IO: clib then ASPI (U=1), ASPI then clib (U=2), clib only (U=3),
  -kV sets the key to V (5 hex bytes, no spaces),
  -mW a key deduced from a padding-stream is worth W normal guesses (=2),
  -nX sets the number of times a key needs to repeat to X (=2),
  -qY sets percentage a candidate key has to have of all keys to Y (=75),
  -rZ key-search per VOB-ID (Z=1), CELL-ID (Z=2) or VOB- & CELL-ID (Z=3),
  IDs hex stream-ids (e.g. 0xe0), seperated by a space. If a '=' is
      prepended to the id, the last stream is remapped to this id.
Hints:
  - Demux mode can split, too (but "c" and "v" are exclusive),
  - All the options w/o an argument can be combined (e.g. "-!dc" )
  - Try a test-run on the VOB first (only filename as parameter),
  - Frame-rates:
    [1] 23.976 (24000/1001) fps    [5] 30 fps
    [2] 24 fps                     [6] 50 fps
    [3] 25 fps                     [7] 59.94 (60000/1001) fps
    [4] 29.97 (30000/1001) fps     [8] 60 fps
    [1] square pixels              [3] 16:9 display
    [2] 4:3 display                [4] 2.21:1 display
Examples:
  To get a list of the streams in a VOB:
    vStrip in.vob
  To keep video and AC3 stream 0x81 mapped to 0x80 using PGC 0 and 1GB chunks:
    vStrip @in.lst -iin.ifo -p0 -$1024 -!oout.vob 0xe0 0xbd 0x81 =0x80
  To demux the video-stream:
    vStrip in.vob -!doout.m2v 0xe0
On, donc exemple, tu veux lire l'ifo out.ifo :
vstrip 0.vob -i"d:\rip_dvd\out.ifo"
Le 0.vob est bidon... Mais vstrip as besoin d'un VOB ou d'un .lst d'entrée !!!
Ciler Mais je l'ai fait... comprend pas... J'arrive pas à touver la commande !
Bruce Lol, ok...
Bon, vstrip lis pas les ifo comme ça :lol:.
Tappe juste vstrip et regarde les commandes ;)
(si tu veux récupérer toutes les commandes tappe : vstrip >test.txt)
Ciler ...\vStrip.exe d:\rip_dvd\out.ifo (avec ou sans -u, même résultat).
Pas d'autentification, les vobs et le ifo sont sur mon dur !
Bruce C quoi ta ligne de commande ???
Tu as bien authentifié le DVD ?
Ciler J'espérais que Bruce...
Mais bon, je viens de repérer un topic vStrip sur Doom9
BlackSunSoft demande à maven
maven@maven.de
Ciler Déja fait, même erreur si je rajoute l'option -u "IFO parsing"
TheNicow Si je me souviens bien, vstrip + un nom de fichier, sans aucune autre option c'est pour scanner un VOB et non pas un IFO.
En gros avec le VOB, il va te dire tous les différents packets qu'il rencontre : video, son, sub etc...
Pour scanner l'ifo, il faut rajouter des options sur la ligne de commande...
Donc regarde dans la doc.
Ciler Up  :bounce:
Allez quoi, comment j'avance DVD:Reaper sinon ?
BlackSunSoft C'est quoi vStrip ?  :??:
Ciler Voila ce qu'il me fait quand j'essaie d'obtenir les infos sur un ifo qui est sur mon dur
http://ciler.multimania.com/vStrip.gif
la ligne de commande est donc "...\vstrip.exe ...\out.ifo"
POurquoi ça marche pas vu qu'avec vStrip_GUI il me les trouve les infos ?
[edtdd]--Message édité par ciler--[/edtdd]
