7682 connectés
Sujet : VirtualDub plante avec le rippack ss w2k ???
mystartpage c'est a dire ?
Bruce Tu fait un gain ou non ?
mystartpage stream set to 128
mpv_open() : thread creation succeeded!
Parsing the file 'F:\out.vob'
MPEG-2 video resolution : <720 x 576>, coded format = YUV420
AVI frame rate ('-f2') = -1.#IO (fps),
Output AVI-resolution : <720 X 576> : pixFormat = 'YV12'
        AVI Video Compressor fccHandler='div3'
Frame#5552 : AVI (41444 KB) #KF=23 #FPS=12.71 #ET=00:07:16 #RT=00:00:00No mor
iles to parse
Frame#5557 : AVI (41444 KB) #KF=23 #FPS=12.71 #ET=00:07:16 #RT=00:00:00No mor
iles to parse
Frame#5558 : AVI (41444 KB) #KF=23 #FPS=12.72 #ET=00:07:17 #RT=-1:-4:-3800:07
Frame#5559 : AVI (41444 KB) #KF=23 #FPS=12.72 #ET=00:07:17 #RT=-1:-4:-3800:07
Frame#5560 : AVI (41444 KB) #KF=23 #FPS=12.72 #ET=00:07:17 #RT=-1:-4:-3800:07
Frame#5561 : AVI (41444 KB) #KF=23 #FPS=12.72 #ET=00:07:17 #RT=-1:-4:-3800:07
No more files to parse
Frame#5562 : AVI (41444 KB) #KF=23 #FPS=12.72 #ET=00:07:17 #RT=-1:-4:-3800:07
 Get_Hdr() : SEQUENCE_END_CODE !
::ReadAheadThread() : exiting...
my_close() : g_poStreamlist doesn't exist!
Closing output (AVI) file F:\movie.avi
Elapsed time = 8:17 minutes
'F:\movie.avi' AVI video statistics :
        (Key)/Frames = (23)/5564, KBytes = 41452KB
        Average AVI video bitrate : 186.3 KBPS  ( @25.000 fps )A(3 V0.8.19 (c
000 (www.ac3dec.com, built Jul 17 2000 10:53:42)
2.0 Mode 48 KHz    192 kbps Complete Main Audio Service
Source Audio is 2 channel 16bit at 48000hz
Codec selected :   (wFormatTag = 0x1)
Output Audio is 2 channel at 48000hz
output_wavefile_open() : acmStreamSize() 1024
output_wavefile_open() : Reserved WAVheader, 46 bytes
Bytes written,           Duration (HH:MM:SS) (seconds),    Output rate
[39.1Mb] DUR=03:33.504 (213.504secs) (867975/sec, 1:18.1)
demux_buffer::pull_data() request was 4, could only supply 1
Decoding complete.
 Skipped AC-3 frames          = 0 times
 Successfully decoded         = 6949 frames
 Duration                     = 03:42.368 secs (222.368secs)
 stereo-audio samples written = 10423.5Kb samples
 Time taken                   = 12.356  , mantisa=(2.9, 23.6%)
 Speed rate                   = 863774 Samples/sec , Realtime ratio 1:18.0
normalize v0.23 (c) 2000 Manuel Kasper <mk@neon1.net>.
All rights reserved.
Pass 1: Finding peak levels...
Minimum level found: -13604, maximum level found: 13040
Performing amplification of 7.635 dB
Amplifying...
100%
Done.
Time taken: 1.9 sec. (throughput: 20.956 MBps)
ca s'arrete la .......
HELP
mystartpage juste apres l'amplification ... ca lance vdub et ca fait strictement rien
Bruce Essaye en faisant étape par étape sans effacer les fichier, tu verra ou ça plante exactement...
mystartpage alors comment je vais faire mes divx moi ???
Bruce C zarb... Vdub est un des soft les plus stables que je connaisse...
mystartpage ouais
il plante .... pas de réponse quoi ...
et ca deja deux fois de suite .... 4 h de paumées ...
shongailzegway plante ? c'est à dire ??
Personne n'est devin sur ce forum !
Pour que ton prob se résolve, il faut donner le max d'explications !!!
Chez moi, VDub marche tres bien sous 98 ou 2000
mystartpage ca fait deux fois que je lance un encodage divx avec le rippack et que virtualdub plante ...
comment faire ???
