4968 connectés
  Etes vous au courant de ça ???
n°161509
freshmaker
Posté le 27-11-2001 à 14:09:54  profilanswer
Copying DVDs with your CD Writer/DVD reader !!
Devil writes "I found this article on JustCDR. Here is quote from the article:
A friend just today told me about something pretty amazing. It seems he's been burning fully functional DVD's with his CD-R drive. Here's the info:
He's got a Yamaha CD-R and a DVD-ROM (reader, not writer) in his PC. He uses the newest Nero (with DVD-copy enabled in "expert mode" settings). When the wizard comes up, he chooses to copy the DVD from the DVD reader to the CD-R
writer. He uses standard blank DVD-R's in his CD-R drive, and starts burning.
He has told me that there have been NO problems getting his CD-R dirve to copy a DVD onto DVD-R media!!
This is not DIVX or VCD we're talking about, it's actually using your CD-R drive to write as a DVD-R drive!! I will post more as more info comes out about this."
n°161511
HAL
Pas un jour sans un but
Posté le 27-11-2001 à 14:16:54  profilanswer
sachant que la longueure d'onde d'un graveur DVD n'est pas la même que celle d'un graveur de CD, ça me parait impossible.
n°161513
freshmaker
Posté le 27-11-2001 à 14:21:03  profilanswer
Ouais cela me parait louche !! mais bon
Sur ce site tu peux aussi voir de l'overclocking de graveur .
www.justcdr.fr.fm
n°161515
neokortex
Posté le 27-11-2001 à 14:22:31  profilanswer
y fo vite le dire aux constructeurs qui ne se casse pas la tete a fabriquer des graveurs  :lol:  :D
n°161526
Bruce
Music 4 your ears!
Posté le 27-11-2001 à 14:45:13  profilanswer
Bha si le DVD d'origine as moins de 700 Mo de données c pas impossible :)
A+++ Bruce - http://www.bheller.com
n°161532
freshmaker
Posté le 27-11-2001 à 15:06:00  profilanswer
Qui se lance pour faire le test ?????????
n°161603
Jul
Posté le 27-11-2001 à 17:19:55  profilanswer
Perso je pense pas que ça soit possible, la largeur des pistes d'un dvd est bcp plus faible que celles d'un cd, la distance entre les creux aussi...
Ou alors ca marche, mais le dvd apres la gravure est reconnu comme un cd, enfin je pense :)
n°161605
freshmaker
Posté le 27-11-2001 à 17:31:41  profilanswer
sauf si tu copies exactement la même chose ,ou si tu passes par vcdgui tu fais un vcd ou svcd  ( enfin la structure)
n°161616
Jul
Posté le 27-11-2001 à 17:57:24  profilanswer
Oui je parlais pas des données gravées, c sur qu'elles seront identiques à l'original...
Je voulais dire au niveau "physique", un graveur cd ne sera pas capable de graver aussi finement qu'un graveur dvd, donc à mon avis, que l'on utilise un cdr ou un dvdr, le resultat sera le meme -> un cd (et non pas un dvd)
n°162359
freshmaker
Posté le 28-11-2001 à 20:55:31  profilanswer
ouais peut être,
j'ai pas de dvddr sous la main ,est ce que quelqu'un en a un , car je ne sais pas combien de minute ou de mo indiquerai nero ou autre en lisant le dvdr
n°162376
davidmarli
Posté le 28-11-2001 à 21:33:26  profilanswer
de toute façon qui irait payer un dvd vierge à 100 ou 150 frs ??? Autant acheter le DVD neuf !!! (avec le boitier et tout)
En tout cas pour ma part c'est une blagche !!!
Par contre je connais un truc super : vous prenez un plateau 20go d'un disque dur, vous le mettez dans votre lecteur de disquette 5 1/4 et puis ce lecteur se transforme en disque dur pouvant capter les ondes tv et radio et en plus le satellite. Si vous voulez les plans c'est là : http://www.ilfautarreterderaconter [...] ns.gouv.fr
Matheux Fou - https://afficheur-tempo.fr - TEMPO BOX pour abonnés TEMPO EDF - Routeur Solaire
Durée max d'1 film sur 1 cd et paramètre courant.
Plus de sujets relatifs à : Etes vous au courant de ça ???
