6130 connectés
  Traitement Audio
  a partir de quelle sources encoder en WMA multicanal ?
n°469242
3Phach4
Posté le 09-06-2003 à 11:22:35  profilanswer
Salut
Le nouveau WM9 permet l'encodage en multicanal, mais voila j'ai essayé a partir d'un extrait d'un DVD d'encoder la bande son au format WMA multicanal. Mais impossible, en fichier sources : .ac3 ; .wav multicanal , rien n'y fait impossible de lancer l'encodage. Est ce que quelqu'un a deja essayé de faire cela, a t il reussi ??
C'est a titre d'essai, pour me rendre compte des possibilités de ce format.
merci d'avance
Message édité par !cricri le 09-06-2003 à 11:22:56
J'écoute FIP sur le net !
n°469251
3Phach4
Posté le 09-06-2003 à 11:47:22  profilanswer
je me repond a moi meme :
Encoding Multichannel Audio
You can encode multichannel audio for a surround-sound playback in six (5.1 audio) or eight (7.1 audio) channels. The format is specifically designed for CD, DVD, high definition television, and digital cinema audio applications. Your audio source must be one of the following:
A single 6-channel or 8-channel WAVE_FORMAT_EXTENSIBLE file. If you are sourcing from an 8-channel file, it is recommended that the sampling rate and bits per sample of the source file and the encoded content match.
Six mono channel WAV files. First, use an audio editing program to fold down your audio to six files, one for each channel. Then, when you set up your source in the encoding session, specify which channel each file is associated with. Each WAV file cannot exceed 2 gigabytes (GB) in size.
One way to set this up is by using Windows Media Encoder; specify the mono channel WAV files and then save the configuration to a .wme file. Then, load the configuration using the Load method from IWMEncoder or WMEncoder. You can also set the mono channel WAV file using the property bag (IPropertyBag). The properties are listed in the following C++ example.
An existing multichannel Windows Media Audio (WMA) file to encode at a different bit rate. This feature does not work on a computer running Windows 2000.
You must use the Windows Media Audio 9 Professional codec and an audio format that supports multichannel encoding when encoding multichannel content. In addition, the user playing your content must have Microsoft Windows XP and a player that is based on the Windows Media Format 9 Series Software Development Kit (SDK). Otherwise, the audio will be folded down automatically to two channels for stereo speakers.
The encoding process automatically folds the channels down to two for playback with stereo speakers. If you are encoding 5.1 audio, you can control the fold-down distribution between the surround, center, and subwoofer channels. Add an attribute for each channel using IWMEncAttributes; use the attribute names in the following table, and specify attribute values indicating the decibels (between 0 to -144).
Channel Attribute name
Surround mix WMENC_AUDIO_SURROUND_MIX
Center mix WMENC_AUDIO_CENTER_MIX
Low-frequency effects mix WMENC_AUDIO_SUBWOOFER_MIX
pourtant j'avais bien cherché sur le net avant mais jamais lu ca !
Y a t il des personnes qui ont deja essayé ??
  Traitement Audio
recherche soft pour faire un div-x a partir de *.vobStructure et specs du format WMA
Ou trouver des tests comparatifs MP3/WMA/OGG/MPC ?Advanced WMA Workshop
encoder un avi en mpeg (pour mettre sur vcd) ?Faire un screenshoot a partir d'un mpg?
Quel soft pour DVD => MPEG/AVI à partir d'un .vob ?Encoder du wav en mp3 en specifiant la taille du fichier de sortie ?
Mp3, Wma ou Ogg?[??] Paramétrage DivX 5 pour encoder des clips
Plus de sujets relatifs à : a partir de quelle sources encoder en WMA multicanal ?
