2277 connectés
  PHP
  [PHP] probleme #Ressource #Fichier sur manip image
n°2228313
erwan83
Du Shift DEL tu te méfieras !
Posté le 18-05-2014 à 10:24:56  profilanswer
Code :
  1. $allowedExts = array("bmp", "BMP", "jpg", "JPG", "jpeg", "JPEG", "png", "PNG", "ico", "ICO", "tiff", "TIFF", "tif", "TIF" );
  2. $extension = pathinfo($_FILES['file']['name'], PATHINFO_EXTENSION);
  3. if (
  4.     (($_FILES["file"]["type"] == "image/jpeg" ) ||
  5.     ($_FILES["file"]["type"] == "image/pjpeg" ) ||
  6.     ($_FILES["file"]["type"] == "image/png" ) ||
  7.     ($_FILES["file"]["type"] == "image/x-png" ) ||
  8.     ($_FILES["file"]["type"] == "image/tiff" ) ||
  9.     ($_FILES["file"]["type"] == "image/vnd.microsoft.icon" ) ||
  10.     ($_FILES["file"]["type"] == "image/bmp" ) ||
  11.     ($_FILES["file"]["type"] == "image/x-ms-bmp" ) ||
  12.     ($_FILES["file"]["type"] == "image/gif" ))
  13.      && ($_FILES["file"]["size"] < 8500000) && in_array($extension, $allowedExts)
  14. )
  15.   {
  16.   if ($_FILES["file"]["error"] > 0)
  17.     {
  18.     echo "Return Code: " . $_FILES["file"]["error"] . "<br />";
  19.     }
  20.   else
  21.     {
  22. $img_src_resource = imagecreatefromstring(file_get_contents($_FILES["file"]['tmp_name']));
  23. $exif = exif_read_data($_FILES["file"]["tmp_name"],0,true);
  24. foreach ($exif as $key => $section)
  25. {
  26. foreach ($section as $name => $val)
  27.  {
  28.  if ( ($name == "Height" ) &&  (gettype($val) == "integer" )  )
  29.   {
  30.   $height = $val;
  31.   }
  32.  if ( ($name == "Width" ) &&  (gettype($val) == "integer" )  )
  33.   {
  34.   $width = $val;
  35.   }
  36.  if ($name == "Orientation" )
  37.   {
  38.    unset($tourner);
  39.    switch($val)
  40.    {
  41.    case 8:// renvoyé quand iphone tête en bas
  42.     $tourner="180";
  43.     break;
  44.    case 3:// renvoyé quand iphone tourné à droite de 90°
  45.     $tourner="90";
  46.     break;
  47.    case 6:// renvoyé par iphone en position tete en haut
  48.     $tourner="00";
  49.     break;
  50.    case 1:// renvoyé par iphone tourné à gauche de 90°
  51.     $tourner="-90";
  52.     break;
  53.    }
  54.   }
  55.  }
  56. }
  57. $thumb = imagecreate($width, $height);
  58. if (isset($tourner))
  59. {
  60. switch($tourner)
  61.  {
  62.  case "00":
  63.   $thumb = imagerotate($thumb,45,0);
  64.   break;
  65.  case "90":
  66.   $thumb = imagerotate($thumb,135,0);
  67.   break;
  68.  case "-90":
  69.   $thumb = imagerotate($thumb,-45,0);
  70.   break;
  71.  case "180":
  72.   $thumb = imagerotate($thumb,135,0);
  73.   break;
  74.  case "-180":
  75.   $thumb = imagerotate($thumb,-135,0);
  76.   break;
  77.  }
  78. }
  79. $thumb = imagerotate($thumb,-135,0);
  80. $dossier = 'users/'.......'/images/';
  81. $fichier = $dossier.time().$_FILES['file']['name'];
  82. $fichier = strtolower($fichier);
  83. imagecopy($thumb,$img_src_resource, 0, 0, 0, 0, $width, $height);
Bonjour. Le problème qui se pose à moi: j'uploade une photo mais je n'arrive pas à "jouer" sur la ressource.
on dirait que la photo va directement se stocker sans tourner si besoin.
en fait aucune manip n'est effectuée.
Pourriez-vous m'expliquer où je me plante, sachant que je veux redresser les images issues d'appareils numériques.
Merci.
PS j'ai déjà consulté toutes les pages de php.net...
Message édité par erwan83 le 18-05-2014 à 10:26:44
  PHP
[BATCH] Génerer un fichier texte et écrire dedans [...]Petit probleme
Xcopy et rename problème[Script Shell] utilisation de la commande tar
problème type char* et char*[20]Panier en PHP
Problème ProgrammationBase de données ou fichier de données ?
Procédure Stocké & PHPProjet en Java's cool, effet sur image
Plus de sujets relatifs à : [PHP] probleme #Ressource #Fichier sur manip image
