3977 connectés
  Ada
  Probleme de compilation avec GNAT
n°1433050
jess100
Posté le 29-08-2006 à 14:01:57  profilanswer
Bonjour a tous,
J'essaie de compiler un programme qui utilise AWS avec GNAT PRO 5.01a mais j'ai un probleme de lien. Voici les messages d'erreur:
gcc -c -Ic:\projects\AWS\lib -Ic:\projects\AWS\include -Ic:\projects\AWS\components -Ic:\projects\AWS\components -Ic:\projects\AWS\include awsuls.adb
a-stream.ads:69:04: run-time configuration error
gnatmake: "awsuls.adb" compilation error
gnatbind -aO./ -Ic:\AWS\lib -Ic:\AWS\include -Ic:\AWS\components -Ic:\AWS\components -Ic:\AWS\include -I- -x awsuls.ali
gnatlink awsuls.ali -Lc:\AWS\lib -laws
C:\GNATPRO\5.01a\lib\gcc-lib\pentium-mingw32msv\3.2.3\adalib\libgnat.a(g-socthi.o)(.text+0x83d):g-socthi.adb: undefined reference to `WSASetLastError@4'
C:\GNATPRO\5.01a\lib\gcc-lib\pentium-mingw32msv\3.2.3\adalib\libgnat.a(g-socket.o)(.text+0x11f2):g-socket.adb: undefined reference to `ioctlsocket@12'
C:\GNATPRO\5.01a\lib\gcc-lib\pentium-mingw32msv\3.2.3\adalib\libgnat.a(g-socket.o)(.text+0x12dd):g-socket.adb: undefined reference to `getsockname@12'
C:\GNATPRO\5.01a\lib\gcc-lib\pentium-mingw32msv\3.2.3\adalib\libgnat.a(g-socket.o)(.text+0x1618):g-socket.adb: undefined reference to `gethostbyaddr@12'
C:\GNATPRO\5.01a\lib\gcc-lib\pentium-mingw32msv\3.2.3\adalib\libgnat.a(g-socket.o)(.text+0x174e):g-socket.adb: undefined reference to `gethostbyname@4'
C:\GNATPRO\5.01a\lib\gcc-lib\pentium-mingw32msv\3.2.3\adalib\libgnat.a(g-socket.o)(.text+0x184d):g-socket.adb: undefined reference to `getpeername@12'
C:\GNATPRO\5.01a\lib\gcc-lib\pentium-mingw32msv\3.2.3\adalib\libgnat.a(g-socket.o)(.text+0x1989):g-socket.adb: undefined reference to `getservbyname@8'
C:\GNATPRO\5.01a\lib\gcc-lib\pentium-mingw32msv\3.2.3\adalib\libgnat.a(g-socket.o)(.text+0x1a76):g-socket.adb: undefined reference to `getservbyport@8'
C:\GNATPRO\5.01a\lib\gcc-lib\pentium-mingw32msv\3.2.3\adalib\libgnat.a(g-socket.o)(.text+0x1b80):g-socket.adb: undefined reference to `getsockname@12'
C:\GNATPRO\5.01a\lib\gcc-lib\pentium-mingw32msv\3.2.3\adalib\libgnat.a(g-socket.o)(.text+0x1d7d):g-socket.adb: undefined reference to `getsockopt@20'
C:\GNATPRO\5.01a\lib\gcc-lib\pentium-mingw32msv\3.2.3\adalib\libgnat.a(g-socket.o)(.text+0x202e):g-socket.adb: undefined reference to `gethostname@8'
gnatmake: *** link failed.
Quelqu'un a deja eu ce genre de probleme?
n°1433224
apprentitu​x
Posté le 29-08-2006 à 17:05:03  profilanswer
apparemment t'as un problème dès la compilation (gcc), essaye de voir à quoi correspond ce "run-time configuration error "
Vu que t'as une erreur après gcc, tu ne peux pas linker donc pas la peine d'aller plus loin.
n°1433491
jess100
Posté le 30-08-2006 à 08:41:01  profilanswer
Desole j'ai mal copie ma sortie. J'ai pas les deux premieres lignes. Voici exactement ce que j'obtiens :
gnatbind -aO./ -Ic:\AWS\lib -Ic:\AWS\include -Ic:\AWS\components -I- -x awsuls.ali
gnatlink awsuls.ali -Lc:\AWS\lib -Lc:\AWS\components -Lc:\AWS\include -laws
n°1433656
Loki du pl​acard
Posté le 30-08-2006 à 13:15:45  profilanswer
Visiblement, il ne trouve pas le package gnat.sockets. C'est étonnant parce qu'il est livré en standard. D'ou une question, es tu sure que ton installation de gnat est correcte.
n°1433677
jess100
Posté le 30-08-2006 à 13:30:33  profilanswer
[quotemsg=14336
n°1433684
jess100
Posté le 30-08-2006 à 13:34:43  profilanswer
[quotemsg=143365
n°1433699
jess100
Posté le 30-08-2006 à 13:50:36  profilanswer
[quotemsg=1433656,4,166511
n°1433704
jess100
Posté le 30-08-2006 à 13:55:07  profilanswer
n°1434894
jess100
Posté le 01-09-2006 à 10:11:06  profilanswer
Bon j'ai avance un petit peu sur mon probleme. Les fonctions qu'il mentionne sont celles decrites dans une dll. J'ai trouve cette dll et le probleme est le suivant je pense : le nom des fonctions de cette dll ne sont pas suivis du @ et du nombre d'octets pour les parametres. D'apres ce que 'ai pu comprendre il s'agit d'un probleme de convention d'appel mais je ne connait pas grand chose la dessus.
J'ai essaye de modifie le nom des fonctions dans le fichier .def que j'ai genere avec l'outil dlltodef mais ca ne change rien. Apres un dumpbin le nom de mes fonctions restent les memes (sans le @n).
Comment est-ce que je peux faire pour modifier ces noms? Quelqu'un a deja eu a faire ce genre de choses?
n°1435139
jess100
Posté le 01-09-2006 à 14:48:12  profilanswer
Personne ne peut m'aider??
J'ai genere une librairie .lib et .a a partir de ma dll et qund je fais un dumpbin j'ai bien le @n pour les procedures appelees mais j'ai un underscore devant chacune. Vu que le link ne marche toujours pas je suppose que c'est a cause de ces underscores...
Quelqu'un sait comment les enlever? Je n'arrive vraiment pas a trouver de la doc la dessus
n°1435289
apprentitu​x
Posté le 01-09-2006 à 17:17:48  profilanswer
Désolé de pas pouvoir t'aider, mais ça sort un peu du langage là ...
  Ada
Probleme de lecture d'objet[RESOLU]Probleme d'affichage avec firefox
Problème avec VB 6![javascript/html/php]Problème Tableau html / Back IE
Compilation Module SAPI phpproblème : méthode Cells de l'objet global a échoué
Probleme connexion BD freeProblème de présentation en vb
Probleme de stylesProblème Coppermine : "Template error"
Plus de sujets relatifs à : Probleme de compilation avec GNAT
