2987 connectés
  HTML/CSS
  [JS] Pb avec un page de javascripts et module open flash chart
n°1921833
jay-jay69
Posté le 07-09-2009 à 11:47:58  profilanswer
J'utilise dans le cadre de mon site le module open flash chart, pour faire des graphes en flash. Il existe un module qui permet de faire des sauvegardes en PNG directement sur le serveur... J'ai utilisé les exemples de cette page : http://teethgrinder.co.uk/open-fla [...] -image.php pour construire ma page...
Code :
  1. <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
  2. <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
  3. <head>
  4. <meta name="Description" content="XX, XX, XX" />
  5. <meta name="Keywords" content="XX, XX" />
  6. <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
  7. <meta name="Distribution" content="Global" />
  8. <meta name="Author" content="XX" />
  9. <meta name="Robots" content="index,follow" />
  10. <script type="text/javascript" src="js/swfobject.js"></script>
  11. <script type="text/javascript">
  12. swfobject.embedSWF(
  13.   "open-flash-chart.swf", "my_chart",
  14.   "550", "250", "9.0.0", "expressInstall.swf",
  15.   {"data-file":"data_irma3.php", "id":"eden"} );
  16. </script>
  17. <script type="text/javascript">
  18. // The chart object
  19. function chart(name) {
  20.    this.name = name;
  21.    this.image_saved = function(id) {
  22.       alert('saved:'+this.name+', id:'+id );
  23.    };
  24. }
  25. // create a new chart object
  26. var my_chart = new chart('chart 1');
  27. function done(id)
  28. {
  29.    alert("Finished upload. Id:"+id);
  30. }
  31. function post_image(debug)
  32. {
  33.    //
  34.    // My computer at home is called 'eden'
  35.    // so I want to POST the image to the
  36.    // ofc_upload_image.php script. I am also
  37.    // passing the name of the image file in
  38.    // as a GET variable.
  39.    //
  40.    url = "php-ofc-library/ofc_upload_image.php?name=tmp.png";
  41.    //
  42.    // call the save function in the flash chart,
  43.    // ofc == open flash chart
  44.    //
  45.    var ofc = findSWF("my_chart" );
  46.    // call the done() function when the image has been POSTed
  47.    x = ofc.post_image( url, 'done', debug );
  48. }
  49. function post_image_2(debug)
  50. {
  51.    url = "php-ofc-library/ofc_upload_image.php?name=tmp.png";
  52.    var ofc = findSWF("my_chart" );
  53.    // call our objects image_saved() method when finished
  54.    x = ofc.post_image( url, 'my_chart.image_saved', debug );
  55. }
  56. function ofc_ready()
  57. {
  58.    alert('ofc_ready');
  59. }
  60. function findSWF(movieName) {
  61.    if (navigator.appName.indexOf("Microsoft" )!= -1) {
  62.       return window[movieName];
  63.    } else {
  64.       return document[movieName];
  65.    }
  66. }
  67. </script>
  68. </head>
  69. <body>
  70. <script language="JavaScript" type="text/JavaScript">
  71. <!--
  72. post_image();
  73. //-->
  74. </script>
  75. </body></html>
Mais bizarrement absolument rien ne se passe sur ma page...
Je ne connais pas grand chose en JS, mais peut-être que vous y voyez qq chose ?
Merci d'avance,
n°1921850
bobby76
Posté le 07-09-2009 à 12:15:38  profilanswer
Bonjour je n'y connai pas grand chose en .js mais l'appel du script n'a pas l'air correct, c'est plus comme ca normalement :
Code :
  1. <html>
  2. <head>
  3. <script type="text/javascript">
  4. </script>
  5. </head>
  6. <body>
  7.      ton appell de la fonction javascript
  8. </body>
  9. </html>
Retire l'appel du script de la partie <body> et les "commentaires" (<!-- et //--> )
Message édité par bobby76 le 07-09-2009 à 12:48:06
n°2038626
jose40
Posté le 26-11-2010 à 11:52:36  profilanswer
Avez vous trouvé comment on peut ouvrir avec open flash chart un fichier contenant du json car au lancement de ma page il me dit qu'il y a une erreur  ligne 1 et qu'il ne peut pas ouvrir ce fichier json.
Si vous avez trouvé la solution je serais bien dépanné
  HTML/CSS
page de messagecréer page automatiquement en php membre
[Joomla - Phpbb3] Module complémentaire liaison des 2 systèmesComment télécharger ce fichier flash avec des paramètres dans l'url ?
Beaucoup d'images sur une meme page.pb d'affichage de page
sendAndLoad // Boucle For + onRelease(valeur i)PB de Div PA sous IE
sendAndLoad pas de retour sous flash {résolu}Image par dessus un applet flash
Plus de sujets relatifs à : [JS] Pb avec un page de javascripts et module open flash chart
