4772 connectés
  SQL/NoSQL
  [Code inside] Conversion entre UTF-8 et ANSI (utf8 ansi transact sql)
n°1513568
Cyberpat92
Posté le 12-02-2007 à 13:54:12  profilanswer
Voici les versions Transact-SQL des fonctions d'encodage/décodage UTF-8 que j'ai déjà posté dans ce forum pour VB :
Encode une chaîne de caractères au format UTF8 / Unicode
CREATE FUNCTION [dbo].[Encode_UTF8] (@ASTR nvarchar(4000))
RETURNS nvarchar(4000)
AS
BEGIN
 declare @c int,@n int, @utftext nvarchar(4000)
 declare @res nvarchar(4000)
 set @utftext = ''
 set @n = 1
 WHILE (@n <= Len(@ASTR))
 BEGIN
  set @c = unicode(substring(@ASTR, @n, 1))
  if @c < 128
  begin
         set @utftext  = @utftext + substring(@ASTR, @n, 1)
  end
        else
  begin
   if @c >= 128 And @c < 2048
   begin
    set @utftext = @utftext + CHAR(((@c / 64) | 192))
    set @utftext = @utftext + CHAR(((@c & 63) | 128))
   end
   else
   begin
    if @c >= 2048 And @c < 65536
    begin
     set @utftext = @utftext + CHAR(((@c / 4096) | 224))
     set @utftext = @utftext + CHAR((((@c / 64) & 63) | 128))
    end
    else -- @c >= 65536
    begin
     set @utftext = @utftext + CHAR(((@c / 262144) | 240))
     set @utftext = @utftext + CHAR((((@c / 4096) & 63) | 128))
    end
   end
  end
  set @n = @n + 1
 END
 return (@utftext)
END
go
Décode une chaîne de caractères au format UTF8 / Unicode
CREATE FUNCTION [dbo].[Decode_UTF8]  (@ASTR nvarchar(4000))
AS
BEGIN
 Declare @c0 int, @c1 int, @c2 int, @c3 int, @n int ,@unitext nvarchar(4000)
 set @unitext = ''
 set @n = 1
 if dbo.is_Utf8(@astr) = 0
 begin
  RETURN(@ASTR)
 end
 WHILE @n <= len(@ASTR)
    BEGIN
        set @c0 = ascii(substring(@astr, @n, 1))
        If @n <= Len(@astr) - 1
  begin
            set @c1 = ascii(substring(@astr, @n + 1, 1))
  end
        Else
  begin
            set @c1 = 0
        End
        If @n <= Len(@astr) - 2
  begin
            set @c2 = ascii(substring(@astr, @n + 2, 1))
  end
        Else
  begin
            set @c2 = 0
        End
        If @n <= Len(@astr) - 3
  begin
            set @c3 = ascii(substring(@astr, @n + 3, 1))
        End
        Else
  begin
            set @c3 = 0
        End
        If (@c0 & 240) = 240 And (@c1 & 128) = 128 And (@c2 & 128) = 128 And (@c3 & 128) = 128
  begin
            set @unitext = @unitext + nchar((@c0 - 240) * 65536 + (@c1 - 128) * 4096) + (@c2 - 128) * 64 + (@c3 - 128)
            set @n = @n + 4
  end
        Else
  begin
   If (@c0 & 224) = 224 And (@c1 & 128) = 128 And (@c2 & 128) = 128
   begin
             set @unitext = @unitext + nchar((@c0 - 224) * 4096 + (@c1 - 128) * 64 + (@c2 - 128))
          set @n = @n + 3
   end
   else
   begin
    If (@c0 & 192) = 192 And (@c1 & 128) = 128
    begin
              set @unitext = @unitext + nchar((@c0 - 192) * 64 + (@c1 - 128))
        set @n = @n + 2
    end
    Else
    begin
     If (@c0 & 128) = 128
     begin
      set @unitext = @unitext + nchar(@c0 & 127)
      set @n = @n + 1
     end
     Else -- c0 < 128
     begin
      set @unitext = @unitext + nchar(@c0)
      set @n = @n + 1
     end
    end
   end
        End
 END
 RETURN(@unitext)
END
go
Vérifie qu'une chaîne de caractères est au format UTF8 / Unicode
CREATE FUNCTION [dbo].[Is_UTF8](@ASTR nvarchar(4000))
RETURNS tinyint
AS
BEGIN
 declare @c0 int, @c1 int, @c2 int, @c3 int, @n int
 set @n = 1
 while @n <= Len(@ASTR)
 begin
  set @c0 = ascii(substring(@ASTR, @n, 1))
  if (@n <= Len(@ASTR) - 1)
   set @c1 = ascii(substring(@ASTR, @n + 1, 1))
  else
   set @c1 = 0
  if (@n <= Len(@ASTR) - 2 )
   set @c2 = ascii(substring(@ASTR, @n + 2, 1))
  else
   set @c2 = 0
  if (@n <= Len(@ASTR) - 3 )
   set @c3 = ascii(substring(@ASTR, @n + 3, 1))
  else
   set @c3 = 0
  begin
            If (@c1 & 128) = 128 And (@c2 & 128) = 128 And (@c3 & 128) = 128
                set @n = @n + 4
            Else
    return 0
  end
        Else
  begin
   begin
     set @n = @n + 3
    Else
     return 0
   end
   Else
   begin
    begin
      set @n = @n + 2
     Else
      return 0
    end
    Else
    begin
     If (@c0 & 128) = 0
      set @n = @n + 1
     Else
      return 0
    end
   end
  end
    end
 return 1
END
go
Message édité par Cyberpat92 le 12-02-2007 à 13:54:59
n°2146652
Gizmo_091
Posté le 21-06-2012 à 14:33:40  profilanswer
Je trouve ce post apres moulte recherche et la je viens de revivre. Apres 3 heures de galères sur l'affichage de symbole de devise récupéré dans une base SQLServer 2000, tu me sauve la vie.
Je ne sais pas si c'est la methode la plus aproprié mais les utf8_encode, mb_convert_encoding et autre iconv n'ont rien donnés. Je prend ta fonction, je fait mon select direct avec ça et pouf je kif ....
Merci beaucoup
Edit : Apres avoir encore rechercher car je voulais trouver une solution php pure . J'ai trouvé ce thread http://stackoverflow.com/questions [...] hing-utf-8 . La meilleur réponse à un lien avec un class d'encodage qui marche du tonner :)
Message édité par Gizmo_091 le 21-06-2012 à 14:46:59
Mon FeedBack
  SQL/NoSQL
Ajax : exécution d'un code javascript dans la page appelée , IE grrr[resolu]gros doute par rapport à l'affichage écran d'un code
code html dans fonction javascriptConversion Chiffres Anglais/Français Français/Anglais sous WORD
probleme code php readdir():Conversion décimal/binaire/hexadécimal
injection de code dans fichier PEConversion de int et float en string en C
Conversion XSD en DTDC++ Conversion de string vers long
Plus de sujets relatifs à : [Code inside] Conversion entre UTF-8 et ANSI (utf8 ansi transact sql)
