2433 connectés
  C++
  C++ Builder répertoire problème !!
n°2142218
Esselami
Posté le 13-05-2012 à 21:23:25  profilanswer
Bonjour à tous ,
j'ai une question concernant c++ builder, i made a program which plays mp3 and wav files but in FileName propriety i have to type the full path is there any function or a modification which allows me to play songs from the Exe (project) Directory the same as Delphi which uses ('\\YourSong.mp3');
thanks.
n°2142320
breizhbugs
Posté le 14-05-2012 à 14:37:03  profilanswer
U mean you have kind of an openfiledialog and you want it to open at your exe location?
You just have to initialize your dialog with your exe path!
Seul Google le sait...
n°2142385
Esselami
Posté le 14-05-2012 à 21:12:21  profilanswer
no its not like that okay let me explain better:
http://i49.tinypic.com/34r8xh0.jpg
u see those buttons i made, i wanna make them play sounds when user clicks them, so i created a MediaPlayer(visible=false) and the problem Was in MediaPlayer->FileName  it doesn't support \\Sounds\Music.mp3 (Sounds Folder contains music and sounds) which is included with the project.exe Because when i finish this program I'll use Install-shield to Copy Folders (music ..) with The Exe program to C:\Programs\MyProgram......(for Example) and create a shortcut in desktop.
So is there are any way to do that !
thanks.
n°2142388
breizhbugs
Posté le 14-05-2012 à 22:05:21  profilanswer
something like
MediaPlayer->FileName ="Sound\\music.mp3";
or
MediaPlayer->FileName =".\\sound\\music.mp3";
but that suppose the current working directory si the exe directory...
n°2142391
Esselami
Posté le 14-05-2012 à 22:46:23  profilanswer
tried it but it doesn't work Error bla bla bla...
  C++
[C] retourner un tableau de string[VB] problème de timer
Probleme OpenGL[C] Remplir un tableau 2 dimensions avec un fichier
Problème d'insertion de donnée ODB dans un QTableView[resolu] Nettoyer du code html pour enlever certaines balise inutiles
Renvoyer l'adresse d'un tableau en C[C] random sur un enum
Plus de sujets relatifs à : C++ Builder répertoire problème !!
