3329 connectés
n°2081596
jhon44
Posté le 09-06-2011 à 15:57:52  profilanswer
quelqu'un pourrait modifier ce script pour récuperer l'inventaire de tous les disques connectés sur mon poste.
ce script marche seulement pour les disques locaux
en vous remerciant
' Script de description des Hdd dans une page web
Dim cnt
dim Aff()
dim Aff0()
dim Aff1()
dim Aff2()
dim Aff3()
dim Aff4()
cnt = 0
Redim Aff(cnt)
Redim Aff0(cnt)
Redim Aff1(cnt)
Redim Aff2(cnt)
Redim Aff3(cnt)
Redim Aff4(cnt)
Select Case WScript.Arguments.Count
Case 0
' Default if none specified is local computer ("." )
Set objWMIService = GetObject( "winmgmts://./root/cimv2" )
Set colItems = objWMIService.ExecQuery( "Select * from Win32_ComputerSystem", , 48 )
For Each objItem in colItems
strComputer = objItem.Name
Next
Case 1
' Command line parameter can either be a computer name
' or "/?" to request online help
strComputer = Wscript.Arguments(0)
if InStr( strComputer, "?" ) > 0 Then Syntax
Case Else
' Maximum is 1 command line parameter
Syntax
End Select
Display( strComputer )
Function Display( strComputer )
On Error Resume Next
Set objWMIService = GetObject( "winmgmts://" & strComputer & "/root/cimv2" )
If Err.Number Then
WScript.Echo vbCrLf & "Error # " & CStr( Err.Number ) & _
" " & Err.Description
Err.Clear
Syntax
End If
On Error GoTo 0
' Set colItems = objWMIService.ExecQuery("Select * from Win32_LogicalDisk where MediaType=12",,48)
Set colItems = objWMIService.ExecQuery("Select * from Win32_LogicalDisk where DriveType=3",,48)
Aff(cnt) = strComputer
Aff0(cnt) = objItem.Name & vbTab
Aff1(cnt) = CStr( Int( 0.5 + ( objItem.Size / 1073741824 ) ) )
Aff2(cnt) = CStr( Int( 0.5 + ( objItem.FreeSpace / 1073741824 ) ) )
Aff4(cnt) = Aff1(cnt) - Aff2(cnt)
Aff3(cnt) = CStr( Int( 0.5 + ( 100 * objItem.FreeSpace / objItem.Size) ) ) & _
vbCrLf
cnt = cnt + 1
Redim Preserve Aff(cnt)
Redim Preserve Aff0(cnt)
Redim Preserve Aff1(cnt)
Redim Preserve Aff2(cnt)
Redim Preserve Aff3(cnt)
Redim Preserve Aff4(cnt)
Next
End Function
Dim fso
Set fso = WScript.CreateObject("Scripting.FileSystemObject" )
DestHTML = "hd.HTML"
CreateHTML DestHTML
Sub CreateHTML(filename)
dim ts
set ts=fso.CreateTextFile(filename,true)
ts.writeline "<HTML>"
ts.WriteLine "<BODY>"
ts.WriteLine "<b><CENTER><H3>Affiche les informations des HDD</H3></b>"
ts.writeline "<table border=1 cellspacing=1 width=100%>"
ts.writeline "<tr>"
ts.writeline "<td width=15%>"
ts.writeline "<p align=center><b>Name</b></td>"
ts.writeline "<p align=center><b>Drive</b></td>"
ts.writeline "<p align=center><b>Size</b></td>"
ts.writeline "<p align=center><b>Free</b></td>"
ts.writeline "<p align=center><b>Use</b></td>"
ts.writeline "<p align=center><b>% Free</b></td>"
ts.writeline "</tr>"
ts.writeline "<tr>"
for i = 0 to cnt
ts.writeline "<td width=15%><p align=center><b><font color=#FF0000>" & Aff(i) & "</font></b></td>"
ts.writeline "<td width=15%><p align=center><b><font color=#FF0000>" & Aff0(i) & "</font></b></td>"
ts.writeline "<td width=15%><p align=center><b><font color=#FF0000>" & Aff1(i) & "</font></b></td>"
ts.writeline "<td width=15%><p align=center><b><font color=#FF0000>" & Aff2(i) & "</font></b></td>"
ts.writeline "<td width=15%><p align=center><b><font color=#FF0000>" & Aff4(i) & "</font></b></td>"
ts.writeline "<td width=15%><p align=center><b><font color=#FF0000>" & Aff3(i) & "</font></b></td>"
next
ts.writeline "</table>"
ts.writeline "<p> </p>"
ts.writeline "<b><font size=2>Fait le " & now & " Pascal </font></b>"
ts.WriteLine "</CENTER></BODY>"
ts.WriteLine "</HTML>"
ts.close
End Sub
Probléme argv[JS ] Conflit ***.js avec prototype.js
Plus de sujets relatifs à : ***
